use NOR FLASH with QSPI in nRF5340
My custom board uses Raytac MDBT53v, which has nRF5340 as its MCU.
My SW is based on the example audio code, and I want to use my external NOR FLAH IC (Macronix MX25R6435F), which is connected through QSPI.
The default devicetree configuration is suitable (in terms of pinout) and I'm trying to figure out how to enable this peripheral and which flash/qspi library would be favorable.
I tried running Zephyr's "spi_flash" example, that should be compatible with QSPI, but the use of DEVICE_DT_GET fails:
#define QSPI_NL DT_NODELABEL(qspi) //qspi is taken from nrf5340_cpuapp_peripherals.dtsi
PINCTRL_DT_DEFINE(QSPI_NL);
const struct device *flashQspiHandle = DEVICE_DT_GET(QSPI_NL); //fails when compiling
ERROR received:
c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: App/libapp.a(ext_flash.c.obj):C:/Projects/SixEye/FWs/HandUnit/App/ext_flash.c:25: undefined reference to `__device_dts_ord_100'
I'd appreciate guidance for simply configuring QSPI communication and executing flash operations.
In addition, I'd like to know about efficient ways for flashing the external flash IC in production line. I'd like to store a constant data there. How can it be achieved easily?
Dekel
