Hi!
Absolute beginner here. I'm trying to use npm1300 (using the evaluation kit for now) with an RP2040 microcontroller (also using RPi Pico dev board). I am powering RP2040 (which requires a 3.3v supply) from VOUT2, which is configured with a resistor on VSET2 to provide 3.3v power for the entire project. VOUT2 is connected to Pico's VSYS power input.
This setup works great with my battery, but now I would also like to use the gauge feature to display the battery charge on screen.
1. Can I use standard I2C protocol to request battery charge data from npm1300? Or should I rather use the npmx driver from https://github.com/NordicSemiconductor/npmx ? Does npmx driver work with RPi Pico SDK? Are there any resources on using it with 3rd party SDKs?
2. With the battery unplugged, connecting USB power to npm1300-EK board won't immediately supply power on VOUT2. If a battery is connected and disconnected later, VOUT2 would continue to power up RP2040. Does npm1300 require any extra settings to power the load from USB if a battery is disconnected or discharged?
3. Can I use SHPHLD as a trigger input for powering on/off the load completely? For my project I would like to have a single switch to power it off completely no matter if there's still USB or battery power. Can I use any npm1300 features such as SHPHLD to implement this?
Apologies for mutiple questions at once. Thanks a lot for any tips on these topics!
