I'm alter the overlay file to adapt my board.
In my board,I try to use pin 9,10 as uart_tx and uart_rx,without cts and rts.
I wirte it in my app.overlay as follow:
* Copyright (c) 2023 Nordic Semiconductor ASA
&pinctrl {
uart1_default: uart1_default {
group1 {
psels = <NRF_PSEL(UART_TX, 0, 9)>,
<NRF_PSEL(UART_RX, 0, 10)>;
uart1_sleep: uart1_sleep {
group1 {
low-power-enable;
/* The timer instance to use. */
chosen {
ncs,dm-timer = &timer2;
/* The selected pins will be used by Distance Measurement module for debug purposes. */
dm_gpio {
compatible = "gpio-leds";
dm_ranging: dm-ranging {
gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
label = "DM Ranging Pin";
dm_add_request: dm-add-request {
gpios = <&gpio0 26 GPIO_ACTIVE_LOW>;
label = "DM Add request Pin";
leds {
led1:led_1 {
gpios = < &gpio0 22 GPIO_ACTIVE_LOW>;
label = "Red LED 1";
uart_self:&uart0{
status = "okay";
current-speed = <9600>;
pinctrl-0 = <&uart1_default>;
pinctrl-1 = <&uart1_sleep>;
The build error output as that:
devicetree error: c:/ncs_project_library/dm_test/app.overlay:47 (column 12): parse error: expected node or property name -- In: C:/ncs_project_library/dm_test/build/zephyr, command: C:/ncs/toolchains/cf2149caf2/opt/bin/python.exe;C:/ncs/zephyr/scripts/dts/gen_defines.py;--dts;C:/ncs_project_library/dm_test/build/zephyr/zephyr.dts.pre;--dtc-flags;'-Wno-unique_unit_address_if_enabled';--bindings-dirs;C:/ncs/nrf/dts/bindings;C:/ncs/zephyr/dts/bindings;--header-out;C:/ncs_project_library/dm_test/build/zephyr/include/generated/devicetree_generated.h.new;--dts-out;C:/ncs_project_library/dm_test/build/zephyr/zephyr.dts.new;--edt-pickle-out;C:/ncs_project_library/dm_test/build/zephyr/edt.pickle;--vendor-prefixes;C:/ncs/nrf/dts/bindings/vendor-prefixes.txt;--vendor-prefixes;C:/ncs/zephyr/dts/bindings/vendor-prefixes.txt CMake Error at C:/ncs/zephyr/cmake/modules/dts.cmake:268 (message): gen_defines.py failed with return code: 1 Call Stack (most recent call first): C:/ncs/zephyr/cmake/modules/zephyr_default.cmake:129 (include) C:/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) C:/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate) CMakeLists.txt:8 (find_package)
It seem like device tree problem.
How should I write in overlay file?
