DAP - Debug access port flexibility
I am new to the nRF52840 and the whole Nordic environment, so this may be a pretty basic question. I couldn't find any other blog entries that fit.
I am developing a manufacturing PCBA level test for a nRF52840 based product. We are developing custom firmware for this mfg test. The only port that I have access to without building a bed-of-nails fixture is the  DAP - Debug access port.
Can the  DAP - Debug access port be configured as a standard serial or I2C port, etc.? Can I send commands over this port and get responses back if my firmware supports that?
I'm not sure of the restrictions on using the  DAP - Debug access port, and reading the documentation and web searches have not answered this question.
Thanks so much for your help.
    From the product specification:
    The debug access port (DAP) implements a standard ARMRegistered CoreSightTm serial wire debug port (SW-DP), which implements the serial wire debug protocol (SWD). SWD is a two-pin serial interface, see SWDCLK and SWDIO in Debug and trace overview.
    The SWDCLK and SWDIO pins does not have GPIO functionality, as you can see in Pin assignments. These pins can therefore not be used for standard serial or I2C ports.
    The DAP/SWD can support things like reading/writing memory (Flash/RAM/peripheral registers, etc) and control the CPU. We provide support for Segger RTT, which works similar to a serial interface to the chip over the SWD interface. This can be used as a backend for the Zephyr Shell to send and received commands to and from the device, or for the Logger module to receive logs from the device.
    Jørgen
  • Hi Jørgen,
     Thank you for the quick response. I do have a few additional questions.
     I have had to do a bit of reading to make sense of your response; I’ve been a LabView developer in test environments for the past 15 years so much of this is quite new for me.
     As some background, we have a product based on the nRF52840. My desire is to attach some type of external host for program control to this product, and from this host send commands to the nRF52840 to access and control the on-board peripherals of the product that are attached to the nRF52840. I hope this is making sense.
     I was hoping that there was a more generic connection available to the nRF52840 so that I wasn’t restricted to some type of debug device, but instead could use a PC running LabView, or a Raspberry Pi, Arduino, etc. I see that isn’t the case.
     It appears that the most practical solution would be to use the nRF52840-DK (dev kit) and communicate via the AHB access port. So, my question is, would this method give me enough control to access all the on-board peripherals attached to the nRF52840.
     Also, what flexibility/capabilities would Zephyr add for this project? And, would that still be compatible with the debug port?
     I appreciate all your help on this and your patience while I come up to speed.
     Have a great day.
     Tusen Takk
    Dayle Swensen
    This should be possible. Can you elaborate a bit more on which on-board peripherals you want to control?
    It might be possible to use something like a Raspberry Pi with OpenOCD to achieve this, it looks like it supports RTT. We do not provide support for this, but OpenOCD should have support for Nordic chips.
    This depends a bit on what you are referring to by "all the on-board peripherals". You get access to the memory of the device and can read/write peripheral registers, but it might make more sense to write application firmware running on the device that handles the communication with the peripherals based on commands sent over the SWD interface to a shell or command line interface.
    The previously linked Shell available in Zephyr is quite powerful already, and can be extended with additional custom commands for your specific use-cases.
    Yes, the SWD port can be used for debugging and RTT/shell based on what application connects to it.
    Jørgen
  • Hi Jørgen,
    Again, I appreciate your patience and help.
    You made a couple of comments that are interesting. But first, I wanted to answer your question about the peripherals. These are LEDs, Hall effect sensors, a buzzer, a motor driver; all of these are connected to standard digital I/O ports.
    Your comment below, in quotes, describes what my intent was; creating custom firmware to accept commands over some port, execute the command and return a result. You mention the SWD port, but the SWD port, as I understand implements a JTAG protocol, so as long as I used that protocol could I send commands and receive data back from the custom firmware?
    "You get access to the memory of the device and can read/write peripheral registers, but it might make more sense to write application firmware running on the device that handles the communication with the peripherals based on commands sent over the SWD interface to a shell or command line interface."
    I was hoping to implement something like a command line interface. I'm not familiar with OpenOCD, and that may be a solution. Could Zephyr implement a command line interface? We could add our custom commands to Zephyr if that was the case. That would be more flexible I think. I could use any device that send ASCII text to the custom firmware and get a response back.
    I hope this makes things a bit more clear.
    Have a wonderful day.
    Dayle
  • Hi Dayle,
    This should be possible. SWD is a serial wire protocol used for programming, similar to JTAG, but like I explained previously, it supports J-Link RTT, which is a protocol for sending data over SWD through RAM buffers. This is typically used to send debug information and commands in ASCII format.
    RTT is supported as a backend for the Shell in Zephyr, (which is a command-line interface that can be used for this exact purpose.
    OpenOCD is an open-source debugger implementation. It can be used as an alternative to J-Link or other debuggers, and can for instance work with a bit-bang implementation of the SWD protocol on the GPIOs of a Raspberry Pi. Note that this is not officially supported by Nordic, we only provide support for Segger/J-Link debuggers.
    Yes, see above Shell.
    If you want a more flexible solution without the need for using a debugger through the SWD interface, I would recommend that you expose two GPIOs on your board that can be used for UART (also supported as a Zephyr shell backend)
    Jørgen
