The partition of nrf5340 audio application
During my test of the nrf5340 audio application which in the V2.6.0 SDK, Because of i need to store at least 13K data to the flash.
But when i build the project, i found the "\build\partitions.yml" file shows that.
EMPTY_0:
  address: 0xfe000
  end_address: 0x100000
  placement:
    after:
    - settings_storage
  region: flash_primary
app:
  address: 0x0
  end_address: 0xf6000
nvs_storage:
  address: 0xf6000
  end_address: 0xfc000
  placement:
    before:
    - end
otp:
  address: 0xff8100
  end_address: 0xff83fc
  region: otp
rpmsg_nrf53_sram:
  address: 0x20070000
  end_address: 0x20080000
  placement:
    before:
    - end
  region: sram_primary
settings_storage:
  address: 0xfc000
  end_address: 0xfe000
  placement:
    align:
      start: 0x4000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20070000
You can see there is only 0x2000 size for "EMPTY_0", but the app size is almost close to 1M.
But i want i can use at least 0x4000 size, But I dare not use 'settings storage' because I think the project may have used this partition to store some settings.
And i found that seems like the project enable the "USE_PARTITION_MANAGER", which i guess that makes the partition for flash0 in the device tree files invalid.
And I can't find where to adjust the size of these partitions. If i can, I think maybe I can reduce the sizd of app partitions appropriately.
So if i do not want to use the external flash, what should i do now?
  • And i found that seems like the project enable the "USE_PARTITION_MANAGER", which i guess that makes the partition for flash0 in the device tree files invalid.
    Yep
    If you use static partitioning, it will be exactly like that. You can change the pm_static.yml file though.
    You need to get the space from somewhere.
    If you cannot take it from the app, try to use parts of the EMPTY_0 (this is not used for anyhing else), NVS or the setting partition.
    For the last two, you should be a bit careful, but maybe you can do some tests to see how much of them are used in an example?
  • Hello Sigurd
    Thank you very much. Your reply is very helpful to me.
    I also want to find the yml file, but in the project i can not find any yml files, and i have not enable the DFU, so i think the yml file in dfu folder is not enabled. I am still searching in the SDK folder, but I am still unable to determine which yml file it is, it seems that none of the yml files have been called by this project because the partitions cannot correspond one-to-one with the "partitions. yml" generated in the build folder.
    Thank you very much and looking forward to your reply!
  • Right, I read wrong for the file-name.
    pm_static.yml will statically freeze your partitioning. When you are done with your project, you can copy build/partitions.yml to pm_static.yml, to make sure partitioning never changes (cause that could break DFU).
    For a custom partition, make pm_static.yml, but only define the one partition you need.
    For other partitions, use Kconfig options, as explained here.
    To learn more, see our corse over at https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic/multi-image-builds-and-the-partition-manager/
  • Hello Sigurd
    Thank you!
    After reading your reply, I think I understand a bit now.
    So does this mean that as long as I enable "USE_PARTITION_MANAGER" and do not use "pm_datic. yml" to statically set partitions, there may be a situation where the partition position and size will change according to the relevant configuration of my project after each build?
    So may be i can use the "partitions.yml" file to make a "pm_static.yml" to statically set partitions? And if there are no issue of the size, i can modify something in this file too?
    USE_PARTITION_MANAGER is not user-configurable, but set indirectly by other configurations, such as CONFIG_BOOTLOADER_MCUBOOT.
    Yes.
    Yes. But in my experience it is hard to change parititons manually, cause you must make sure all other partitions change accordingly.
    If you for example make a partition bigger, something else have to become smaller. And the math must check out.
