When following instructions for setting up the NRF52840-dongle as RCP coprocessor, I'm getting this error: ModuleNotFoundError: No module named 'intelhex'
/opt/nordic/ncs/v2.7.0$ west build -p always -b nrf52840dongle/nrf52840 nrf/samples/openthread/coprocessor/
[415/415] Linking CXX executable zephyr/zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 154132 B 988 KB 15.23%
RAM: 45632 B 256 KB 17.41%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.elf for board: nrf52840dongle
[10/10] Generating ../merged.hex
FAILED: merged.hex /opt/nordic/ncs/v2.7.0/build/merged.hex
cd /opt/nordic/ncs/v2.7.0/build/_sysbuild && /opt/homebrew/opt/[email protected]/bin/python3.12 /opt/nordic/ncs/v2.7.0/zephyr/scripts/build/mergehex.py -o /opt/nordic/ncs/v2.7.0/build/merged.hex --overlap=replace /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.hex
File "/opt/nordic/ncs/v2.7.0/zephyr/scripts/build/mergehex.py", line 10, in <module>
from intelhex import IntelHex
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v2.7.0/build
Full log:
/opt/nordic/ncs/v2.7.0$ west build -p always -b nrf52840dongle/nrf52840 nrf/samples/openthread/coprocessor/ -- west build: generating a build system Loading Zephyr module(s) (Zephyr base): sysbuild_default -- Found Python3: /opt/homebrew/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/redacted/Library/Caches/zephyr -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52840dongle, qualifiers: nrf52840 Parsing /opt/nordic/ncs/v2.7.0/zephyr/share/sysbuild/Kconfig Loaded configuration '/opt/nordic/ncs/v2.7.0/build/_sysbuild/empty.conf' Merged configuration '/opt/nordic/ncs/v2.7.0/build/_sysbuild/empty.conf' Configuration saved to '/opt/nordic/ncs/v2.7.0/build/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/v2.7.0/build/_sysbuild/autoconf.h' -- ********************************* * Running CMake for coprocessor * ********************************* Loading Zephyr default modules (Zephyr base). -- Application: /opt/nordic/ncs/v2.7.0/nrf/samples/openthread/coprocessor -- CMake version: 3.30.1 -- Using NCS Toolchain 2.7.20240620.1065210518403 for building. (/opt/nordic/ncs/toolchains/f8037e9b83/cmake) -- Found Python3: /opt/nordic/ncs/toolchains/f8037e9b83/bin/python3 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/redacted/Library/Caches/zephyr -- Zephyr version: 3.6.99 (/opt/nordic/ncs/v2.7.0/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf52840dongle, qualifiers: nrf52840 -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/f8037e9b83/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.7.0/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840.dts -- Found devicetree overlay: /opt/nordic/ncs/v2.7.0/nrf/samples/openthread/coprocessor/boards/nrf52840dongle_nrf52840.overlay -- Generated zephyr.dts: /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.dts -- Generated devicetree_generated.h: /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.7.0/nrf/samples/openthread/coprocessor/Kconfig Loaded configuration '/opt/nordic/ncs/v2.7.0/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840_defconfig' Merged configuration '/opt/nordic/ncs/v2.7.0/nrf/samples/openthread/coprocessor/prj.conf' Merged configuration '/opt/nordic/ncs/v2.7.0/nrf/samples/openthread/coprocessor/boards/nrf52840dongle_nrf52840.conf' Merged configuration '/opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/.config.sysbuild' Configuration saved to '/opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/.config' Kconfig header saved to '/opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: /opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -- OpenThread Source Directory: /opt/nordic/ncs/v2.7.0/modules/lib/openthread -- OT_APP_CLI=ON -- OT_APP_NCP=ON -- OT_APP_RCP=ON -- OT_FTD=ON -- OT_MTD=OFF -- OT_RCP=ON -- - - - - - - - - - - - - - - - - -- OpenThread ON/OFF/Unspecified Configs -- OT_15_4=ON --> OPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 -- OT_ANDROID_NDK="" -- OT_ANYCAST_LOCATOR=OFF --> OPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 -- OT_ASSERT=OFF --> OPENTHREAD_CONFIG_ASSERT_ENABLE=0 -- OT_BACKBONE_ROUTER=OFF --> OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 -- OT_BACKBONE_ROUTER_DUA_NDPROXYING=OFF --> OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 -- OT_BACKBONE_ROUTER_MULTICAST_ROUTING=OFF --> OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 -- OT_BLE_TCAT=OFF --> OPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 -- OT_BORDER_AGENT=OFF --> OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 -- OT_BORDER_AGENT_EPSKC="" -- OT_BORDER_AGENT_ID="" -- OT_BORDER_ROUTER=OFF --> OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 -- OT_BORDER_ROUTING=OFF --> OPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 -- OT_BORDER_ROUTING_DHCP6_PD=OFF --> OPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 -- OT_BORDER_ROUTING_COUNTERS=OFF --> OPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 -- OT_CHANNEL_MANAGER=OFF --> OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 -- OT_CHANNEL_MANAGER_CSL="" -- OT_CHANNEL_MONITOR=OFF --> OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 -- OT_COAP=OFF --> OPENTHREAD_CONFIG_COAP_API_ENABLE=0 -- OT_COAP_BLOCK=OFF --> OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 -- OT_COAP_OBSERVE=OFF --> OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 -- OT_COAPS=OFF --> OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 -- OT_COMMISSIONER=OFF --> OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 -- OT_CSL_AUTO_SYNC=ON --> OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1 -- OT_CSL_DEBUG=OFF --> OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 -- OT_CSL_RECEIVER=ON --> OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1 -- OT_CSL_RECEIVER_LOCAL_TIME_SYNC=OFF --> OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 -- OT_DATASET_UPDATER=OFF --> OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 -- OT_DEVICE_PROP_LEADER_WEIGHT=OFF --> OPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 -- OT_DHCP6_CLIENT=OFF --> OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 -- OT_DHCP6_SERVER=OFF --> OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 -- OT_DIAGNOSTIC=OFF --> OPENTHREAD_CONFIG_DIAG_ENABLE=0 -- OT_DNS_CLIENT=OFF --> OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 -- OT_DNS_CLIENT_OVER_TCP=OFF --> OPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 -- OT_DNS_DSO=OFF --> OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 -- OT_DNS_UPSTREAM_QUERY=OFF --> OPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 -- OT_DNSSD_SERVER=OFF --> OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 -- OT_DUA=OFF --> OPENTHREAD_CONFIG_DUA_ENABLE=0 -- OT_ECDSA=OFF --> OPENTHREAD_CONFIG_ECDSA_ENABLE=0 -- OT_EXTERNAL_HEAP=OFF --> OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 -- OT_FIREWALL=OFF --> OPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 -- OT_HISTORY_TRACKER=OFF --> OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 -- OT_IP6_FRAGM=OFF --> OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 -- OT_JAM_DETECTION=OFF --> OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 -- OT_JOINER=OFF --> OPENTHREAD_CONFIG_JOINER_ENABLE=0 -- OT_LINK_METRICS_INITIATOR=ON --> OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1 -- OT_LINK_METRICS_MANAGER=OFF --> OPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 -- OT_LINK_METRICS_SUBJECT=ON --> OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1 -- OT_LINK_RAW=OFF --> OPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 -- OT_LOG_LEVEL_DYNAMIC=OFF --> OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 -- OT_MAC_FILTER=OFF --> OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 -- OT_MDNS="" -- OT_MESH_DIAG=OFF --> OPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 -- OT_MESSAGE_USE_HEAP=OFF --> OPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 -- OT_MLE_LONG_ROUTES=OFF --> OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 -- OT_MLR=OFF --> OPENTHREAD_CONFIG_MLR_ENABLE=0 -- OT_MULTIPAN_RCP=OFF --> OPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 -- OT_MULTIPLE_INSTANCE=OFF --> OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 -- OT_NAT64_BORDER_ROUTING=OFF --> OPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 -- OT_NAT64_TRANSLATOR=OFF --> OPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 -- OT_NEIGHBOR_DISCOVERY_AGENT=OFF --> OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 -- OT_NETDATA_PUBLISHER=OFF --> OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 -- OT_NETDIAG_CLIENT=OFF --> OPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 -- OT_OPERATIONAL_DATASET_AUTO_INIT=ON --> OPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 -- OT_OTNS=OFF --> OPENTHREAD_CONFIG_OTNS_ENABLE=0 -- OT_PING_SENDER=ON --> OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1 -- OT_PLATFORM_BOOTLOADER_MODE=ON --> OPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=1 -- OT_PLATFORM_KEY_REF=OFF --> OPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 -- OT_PLATFORM_LOG_CRASH_DUMP="" -- OT_PLATFORM_NETIF=OFF --> OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 -- OT_PLATFORM_POWER_CALIBRATION=OFF --> OPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 -- OT_PLATFORM_UDP=OFF --> OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 -- OT_REFERENCE_DEVICE=OFF --> OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 -- OT_SERVICE=OFF --> OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 -- OT_SETTINGS_RAM=OFF --> OPENTHREAD_SETTINGS_RAM=0 -- OT_SLAAC=OFF --> OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 -- OT_SNTP_CLIENT=OFF --> OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 -- OT_SRP_ADV_PROXY=OFF --> OPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 -- OT_SRP_CLIENT=OFF --> OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 -- OT_SRP_SERVER=OFF --> OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 -- OT_TCP=OFF --> OPENTHREAD_CONFIG_TCP_ENABLE=0 -- OT_TIME_SYNC=OFF --> OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 -- OT_TREL=OFF --> OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 -- OT_TX_BEACON_PAYLOAD=OFF --> OPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 -- OT_TX_QUEUE_STATS=OFF --> OPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 -- OT_UDP_FORWARD=OFF --> OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 -- OT_UPTIME=ON --> OPENTHREAD_CONFIG_UPTIME_ENABLE=1 -- OT_VERHOEFF_CHECKSUM="" -- - - - - - - - - - - - - - - - - -- OT_PLATFORM="zephyr" -- OT_THREAD_VERSION="1.3" -> OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3 -- OT_LOG_LEVEL="" -- OT_LOG_OUTPUT="" -- OT_VENDOR_NAME="" -- OT_VENDOR_MODEL="" -- OT_VENDOR_SW_VERSION="" -- OT_POWER_SUPPLY="EXTERNAL" --> OPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL -- OT_MLE_MAX_CHILDREN="" -- OT_RCP_RESTORATION_MAX_COUNT="" -- OT_RCP_TX_WAIT_TIME_SECS="" -- Package Name: OPENTHREAD -- Setting default package version: a57d927b0 -- Package Version: a57d927b0 -- Using ccache: /opt/nordic/ncs/toolchains/f8037e9b83/bin/ccache -- Configuring done (4.4s) -- Generating done (0.3s) -- Build files have been written to: /opt/nordic/ncs/v2.7.0/build/coprocessor -- Configuring done (6.4s) -- Generating done (0.0s) -- Build files have been written to: /opt/nordic/ncs/v2.7.0/build -- west build: building application [5/10] Performing build step for 'coprocessor' [1/415] Preparing syscall dependency handling [6/415] Generating include/generated/version.h -- Zephyr version: 3.6.99 (/opt/nordic/ncs/v2.7.0/zephyr), build: v3.6.99-ncs2 [7/415] cd /opt/nordic/ncs/v2.7.0/build/coprocessor/modules/openthread/buil...Y=1" -P /opt/nordic/ncs/v2.7.0/modules/lib/openthread/etc/cmake/print.cmake OPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1 OPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0 OPENTHREAD_CONFIG_ASSERT_ENABLE=0 OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0 OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0 OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0 OPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0 OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0 OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0 OPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0 OPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0 OPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0 OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0 OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0 OPENTHREAD_CONFIG_COAP_API_ENABLE=0 OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0 OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0 OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0 OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0 OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1 OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0 OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1 OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0 OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0 OPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0 OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0 OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0 OPENTHREAD_CONFIG_DIAG_ENABLE=0 OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=0 OPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0 OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0 OPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0 OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0 OPENTHREAD_CONFIG_DUA_ENABLE=0 OPENTHREAD_CONFIG_ECDSA_ENABLE=0 OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=0 OPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0 OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0 OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=0 OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0 OPENTHREAD_CONFIG_JOINER_ENABLE=0 OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=1 OPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0 OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=1 OPENTHREAD_CONFIG_LINK_RAW_ENABLE=0 OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0 OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0 OPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0 OPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0 OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0 OPENTHREAD_CONFIG_MLR_ENABLE=0 OPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0 OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0 OPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0 OPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0 OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0 OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0 OPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=0 OPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1 OPENTHREAD_CONFIG_OTNS_ENABLE=0 OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1 OPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=1 OPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=0 OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0 OPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0 OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0 OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0 OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0 OPENTHREAD_SETTINGS_RAM=0 OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=0 OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0 OPENTHREAD_CONFIG_SRP_SERVER_ADVERTISING_PROXY_ENABLE=0 OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=0 OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0 OPENTHREAD_CONFIG_TCP_ENABLE=0 OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0 OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0 OPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0 OPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0 OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0 OPENTHREAD_CONFIG_UPTIME_ENABLE=1 OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3 OPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0 OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0 PACKAGE_NAME=OPENTHREAD OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1 KERNEL __ZEPHYR__=1 _ANSI_SOURCE __LINUX_ERRNO_EXTENSIONS__ USE_PARTITION_MANAGER=1 __PROGRAM_START NRF52840_XXAA K_HEAP_MEM_POOL_SIZE=0 MBEDTLS_CONFIG_FILE=nrf-config.h MBEDTLS_PSA_CRYPTO_CONFIG_FILE=nrf-psa-crypto-want-config.h MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=nrf-psa-crypto-config.h MBEDTLS_PSA_CRYPTO_CONFIG NRF_802154_SERIALIZATION_HOST=0 NRF_802154_USE_RAW_API=1 NRF_802154_PENDING_SHORT_ADDRESSES=16 NRF_802154_PENDING_EXTENDED_ADDRESSES=16 NRF_802154_RX_BUFFERS=16 NRF_802154_TX_STARTED_NOTIFY_ENABLED=1 NRF_802154_ACK_TIMEOUT_ENABLED=1 NRF_802154_CCA_CORR_LIMIT_DEFAULT=2 NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45 NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45 NRF_802154_SECURITY_KEY_STORAGE_SIZE=3 NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED NRF_802154_ENCRYPTION_ENABLED=1 NRF_802154_SECURITY_WRITER_ENABLED=1 NRF_802154_IE_WRITER_ENABLED=1 NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0 NRF_802154_CARRIER_FUNCTIONS_ENABLED=0 NRF_802154_PLATFORM_ASSERT_INCLUDE=nrf_802154_assert_zephyr.h NRF_802154_ECB_PRIORITY=-1 NRF_802154_SWI_PRIORITY=1 [415/415] Linking CXX executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 154132 B 988 KB 15.23% RAM: 45632 B 256 KB 17.41% IDT_LIST: 0 GB 32 KB 0.00% Generating files from /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.elf for board: nrf52840dongle [10/10] Generating ../merged.hex FAILED: merged.hex /opt/nordic/ncs/v2.7.0/build/merged.hex cd /opt/nordic/ncs/v2.7.0/build/_sysbuild && /opt/homebrew/opt/[email protected]/bin/python3.12 /opt/nordic/ncs/v2.7.0/zephyr/scripts/build/mergehex.py -o /opt/nordic/ncs/v2.7.0/build/merged.hex --overlap=replace /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.hex Traceback (most recent call last): File "/opt/nordic/ncs/v2.7.0/zephyr/scripts/build/mergehex.py", line 10, in <module> from intelhex import IntelHex ModuleNotFoundError: No module named 'intelhex' ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /opt/nordic/ncs/v2.7.0/build
