Following instruction here for setting up NRF52840-Dongle as a radio coprocessor for use with OpenThread Border Router.
The error is at the second step when executing "nrfutil pkg generate --hw-version 52 --sd-req=0x00 \ --application build/zephyr/zephyr.hex --application-version 1 build/zephyr/zephyr.zip". It fails with "FileNotFoundError: [Errno 2] No such file or directory: 'build/zephyr/zephyr.hex".
Logs:
NRF_802154_SWI_PRIORITY=1
[415/415] Linking CXX executable zephyr/zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 154132 B 988 KB 15.23%
RAM: 45632 B 256 KB 17.41%
IDT_LIST: 0 GB 32 KB 0.00%
Generating files from /opt/nordic/ncs/v2.7.0/build/coprocessor/zephyr/zephyr.elf for board: nrf52840dongle
[10/10] Generating ../merged.hex
/opt/nordic/ncs/v2.7.0$ nrfutil pkg generate --hw-version 52 --sd-req=0x00 \
|You are not providing a signature key, which means the DFU |
|files will not be signed, and are vulnerable to tampering. |
|This is only compatible with a signature-less bootloader and is|
|not suitable for production environments. |
File "nordicsemi/__main__.py", line 1555, in <module>
File "click/core.py", line 1137, in __call__
File "click/core.py", line 1062, in main
File "click/core.py", line 1668, in invoke
File "click/core.py", line 1404, in invoke
File "click/core.py", line 763, in invoke
File "nordicsemi/__main__.py", line 899, in generate
File "nordicsemi/dfu/package.py", line 434, in generate_package
File "nordicsemi/dfu/package.py", line 631, in normalize_firmware_to_bin
File "nordicsemi/dfu/nrfhex.py", line 75, in __init__
File "intelhex/__init__.py", line 249, in loadfile
File "intelhex/__init__.py", line 199, in loadhex
FileNotFoundError: [Errno 2] No such file or directory: 'build/zephyr/zephyr.hex'
[17316] Failed to execute script '__main__' due to unhandled exception!
