NRF_ERROR_SD_RPC_H5_TRANSPORT_STATE error when trying to connect via Bluetooth using the bt_nus_shell.py script on Windows
Hello everyone,
I am having trouble using the bt_nus_shell.py script and a NRF52840 development board to send shell commands. I am trying to follow the instructions mentioned here. I reverted to an older version of Python (3.7) because the BLE driver (pc-ble-driver-py) will not work with a new Python version. Right now I have installed pc-ble-driver-py v0.17.0, as well as all the dependencies of the bt_nus_shell.py script by typing:
pip install --user -r scripts/shell/requirements.txt
The issues start after I connect the NRF52840 development board to my PC. I connect it and then type the following command to run the script:
python bt_nus_shell.py --name BT_NUS_shell --com COM237 --family NRF52 --snr 1050278085
I get the following message:
PS C:\ncs\v2.3.0\nrf\scripts\shell> python bt_nus_shell.py --name BT_NUS_shell --com COM237 --family NRF52 --snr 1050278085
Flashing connectivity firmware...
Connectivity firmware flashed.
Socket created
Socket bind complete
Socket now listening
Then I open Putty, set the Connection Type to Raw and the Destination Address to 127.0.0.1:8889. Then I get the following error:
Starting BLESerial failed. Error: Failed to open. Error code: NRF_ERROR_SD_RPC_H5_TRANSPORT_STATE
SOCKET CLOSED
This is my problem and I do not know how to get past this error.
While looking online for a possible solution, I found a forum topic that suggested to disable the mass storage class on J-Link. So, I opened the J-Link commander app and connected to the nRF52840 development board (Device: NRF52, Interface: SWD, Speed: 4000). I typed "MSDDisable" and the J-Link app responded that the command was accepted. However, when I power-cycled the development board, and tried to run the python script again, I got this error:
  File "C:\Users\Administrator\AppData\Roaming\Python\Python37\site-packages\pc_ble_driver_py\ble_driver.py", line 3207, in call_cmd
    return subprocess.check_output(argstr, stderr=subprocess.STDOUT, shell=True)
  File "C:\Users\Administrator\.pyenv\pyenv-win\versions\3.7.9\lib\subprocess.py", line 411, in check_output
    **kwargs).stdout
  File "C:\Users\Administrator\.pyenv\pyenv-win\versions\3.7.9\lib\subprocess.py", line 512, in run
    output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command 'nrfjprog --snr 1050278085 --memrd 327680 --w 8 --n 24 --family nrf52' returned non-zero exit status 16.
During handling of the above exception, another exception occurred:
  File "bt_nus_shell.py", line 222, in <module>
    flash_connectivity(args.com[0], args.snr[0])
  File "bt_nus_shell.py", line 173, in flash_connectivity
    if flasher.fw_check():
  File "C:\Users\Administrator\AppData\Roaming\Python\Python37\site-packages\pc_ble_driver_py\ble_driver.py", line 3160, in fw_check
    fw_struct = Flasher.parse_fw_struct(self.read_fw_struct())
  File "C:\Users\Administrator\AppData\Roaming\Python\Python37\site-packages\pc_ble_driver_py\ble_driver.py", line 3183, in read_fw_struct
    data = self.call_cmd(args)
  File "C:\Users\Administrator\AppData\Roaming\Python\Python37\site-packages\wrapt\decorators.py", line 470, in _synchronized
    return wrapped(*args, **kwargs)
  File "C:\Users\Administrator\AppData\Roaming\Python\Python37\site-packages\pc_ble_driver_py\ble_driver.py", line 3212, in call_cmd
    raise RuntimeError(f"{e.__str__()}\n{e.output}")
RuntimeError: Command 'nrfjprog --snr 1050278085 --memrd 327680 --w 8 --n 24 --family nrf52' returned non-zero exit status 16.
b"[error] [ Client] - Encountered error -90: Command read_device_info executed for 15 milliseconds with result -90\r\n[error] [ Worker] - Access protection is enabled, can't read device version.\r\n[error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 15 milliseconds with result -90\r\n[error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.\r\n[error] [ Client] - Encountered error -90: Command read executed for 370 milliseconds with result -90\r\n[error] [ Worker] - Access protection is enabled, can't access memory.\r\nERROR: The operation attempted is unavailable due to readback protection in\r\nERROR: your device. Please use --recover to unlock the device.\r\nNOTE: For additional output, try running again with logging enabled (--log).\r\nNOTE: Any generated log error messages will be displayed.\r\n"
As suggested by the error message, I ran:
Which suggests to run:
nrfjprog --snr 1050278085 --recover
The latter command re-establishes communication with the development board but negates the effects of "MSDDisable". So, I'm back where I started.
Any ideas? I am a beginner in development so any help will be appreciated.
    Are you sure that you have J-Link still connected to the device when you ran the script?
    Have you checked that you use proper COM port and serial number in your "python bt_nus_shell.py" command?
    Dejan
  • Hi Dejan,
    I wasn't aware that I had to leave the J-Link connected to the development board while trying to connect. The guide mentions that we're supposed to power cycle the board. Maybe the guide needs an update.
    In any case, I have made some improvements and see a different error now.
    I connected the development board to my PC and checked the COM ports using the device manager. I saw two COM ports (COM7, COM8) assigned to the development board.
    So, then I ran the python script with COM7:
    python bt_nus_shell.py --name BT_NUS_shell --com COM7 --family NRF52 --snr 1050278085
    Then I opened the J-Link commander app, connected, and typed "MSDDisable". I kept the app open and did not power-cycle the development board.
    Then I opened Putty and tried to connect. This time I saw the following error:
    Successfully opened COM7. Baud rate: 1000000. Flow control: none. Parity: none.
    BLE: ble_enable with local ATT MTU: 247
    BLE: Scanning...
    ad_len is zero, discarding rest of ad_list
    Starting BLESerial failed. Error: Timeout. Target device not found.
    SOCKET CLOSED
    I also tried with COM8 and got the following error:
    Successfully opened COM8. Baud rate: 1000000. Flow control: none. Parity: none.
    Starting BLESerial failed. Error: Failed to open. Error code: NRF_ERROR_TIMEOUT
    SOCKET CLOSED
    Any ideas?
    ds755 said:
    Any ideas?
    I tried to reproduce the error shown in your previous reply, but I was not successful in doing that. There must be something that we are doing differently. Could you provide all necessary steps (detailed instructions) for reproducing the issue?
    Dejan
  • 2024-07-29 15-23-55.zip
    Here is a video of me recording my screen while doing the procedure. I have already connected the development board to my PC and then I type everything you see on the video. The error appears at the end.
    Thank you for providing the video. I have followed your steps, and I was able to reproduce your issue shown below.
    SOCKET CLOSED
    We will further look into this internally. I expect to come back to you by the end of this week.
    Dejan
