I am currently migrating from NCS 2.6.0 to NCS 2.7.0 on my board with an NRF9160.
During that process I switched to the new hardware model and to sysbuild. As far as I see everything works as expected after the migration with NCS 2.7.0, except for writing to the SPI-NOR-Flash on my board. Reading from the SPI-NOR-Flash works with NCS 2.7.0.
I could narrow the issue down to the the requires_ulbpr setting, which is defined in the device tree for the SPI-NOR on my board:
It seems in NCS 2.7.0 the setting is not evaluated correctly in spi_nor.c. In this version it is mapped to a bitfield, but the bit does not seem to be set, even if the requires-ulbpr is defined in the device-tree.
If I do the check the same it was done in NCS 2.6.0 instead of using the cfg->requires_ulbpr_exist bit (in function spi_nor_write_protection_set() of spi_nor.c) the setting is recognized correctly and writing is possible:
Am I missing something? Is the bit field filled automatically or does it now require some initialization call for the SPI driver so it is working correctly?
Best regards
rw
