I want to use LPCOMP in nrf52832 to detect a rising edge of voltage. And my code is:
static void lpcomp_event_handler(nrf_lpcomp_event_t event) { ret_code_t err_code; if (event == NRF_LPCOMP_EVENT_UP) { NRF_LOG_INFO("up!"); } } static void lpcomp_init(void) { uint32_t err_code; nrf_drv_lpcomp_config_t config; config.input =NRF_LPCOMP_INPUT_0; uint32_t ref = NRF_LPCOMP_INPUT_1;//NRF_LPCOMP_REF_SUPPLY_4_8 config.hal.reference = (nrf_lpcomp_ref_t)ref; config.hal.detection = LPCOMP_ANADETECT_ANADETECT_Up; config.hal.hyst = LPCOMP_HYST_HYST_Hyst50mV; err_code = nrf_drv_lpcomp_init(&config, lpcomp_event_handler); APP_ERROR_CHECK(err_code); nrf_drv_lpcomp_enable(); }
I set the reference as NRF_LPCOMP_INPUT_1 or NRF_LPCOMP_REF_SUPPLY_4_8, the event is not triggered only when the input pin is not connected to anything or grounded.
Even if it's connecting a wire or inputting a high level, it will continuously trigger events. It triggered too many rising edge events, this is very confusing for me.
I noticed this: when I use a voltmeter to measure the voltage at the input pin, it's not zero. Should I connect a pull-down resistor or do you have any other suggestions?
