I am using zephyr application. I need your guidance on how to set phy to 125 kbps?
I enabled some configurations regarding this please verify that and let me know is that enough to set phy to 125 kbps.
Hi
You should only need the following to set the application to use Coded PHY (125 kbps) in NCS:
Hi simonr
Thanks or the reply I am using zephyr application.
I did the following but the range didn't improve as per our expectation the range is arround 15 Meters
Okay, how have you set up your advertising in your application then? Please refer to the Coded PHY sample in the SDK to see how to set up a device running in the Coded PHY: Bluetooth: Peripheral Heart Rate Monitor with Coded PHY
Simon
Thanks for the reply
I had gone through long range throughput example to know about how to set Coded phy and I am able set coded phy in my software still not getting long Range
Okay
Can you provide some details on what devices exactly you're testing, what kind of environment you're testing in and show some logs of what you're doing and what happens when you go "out of range"?
A sniffer log using a Bluetooth Sniffer or the nRF Sniffer and Wireshark might be useful to see what's going on over the air exactly.
Simon
