how to set phy to 125 kbps in nrf 52840?
I am using zephyr application. I need your guidance on how to set phy to 125 kbps?
I enabled some configurations regarding this please verify that and let me know is that enough to set phy to 125 kbps.
CONFIG_BT_AUTO_PHY_UPDATE=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_PHY_UPDATE=y
    thanks for the reply i gone through Heart rate example and try to set extended advertisement with coded phy i's giving error -134 ?
    BT_LE_ADV_PARAM_INIT(BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_CODED |
                             BT_LE_ADV_OPT_USE_NAME,
                             BT_GAP_ADV_FAST_INT_MIN_2,
                             BT_GAP_ADV_FAST_INT_MAX_2,
                             NULL);
    this is my advertising parameter and
    bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd)); this function generating error. As I gone through some of the nordic support query regarding this issue i noticed that ad data and sd data can not be used concurrently so i tried with ad data only then the beacon device is not getting connected to central.
    Please provide some suggestions
  • Hi
    Please compare the prj.conf files of the heart rate Coded PHY sample and yours to make sure the Bluetooth configs match. Error -134 refers to "Not supported" so one or more of the parameters you've set is not supported by your project.
    Simon
