USB over Console not working on custom board
Hello
im using basic usb over console exaple on my custom board .
i believe this task wont require any pins to be configured as my custom board is routed properly to all 4 pins required for USB
But i dont see any new serial com port when i flash this example to my custom board
this is my overlay file
	chosen {
		zephyr,console = &cdc_acm_uart0;
&zephyr_udc0 {
	cdc_acm_uart0: cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
my prj config file is this
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="Zephyr USB console sample"
CONFIG_USB_DEVICE_PID=0x0004
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_CDC_ACM=y
this is my dtsfile
 * Copyright (c) 2019 Nordic Semiconductor ASA
/dts-v1/;
#include <nordic/nrf52833_qiaa.dtsi>
#include "nrf52833dk_nrf52833-pinctrl.dtsi"
	model = "Nordic nRF52833 DK NRF52833";
	compatible = "nordic,nrf52833-dk-nrf52833";
	chosen {
		zephyr,console = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,bt-mon-uart = &uart0;
		zephyr,bt-c2h-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,ieee802154 = &ieee802154;
	leds {
		compatible = "gpio-leds";
		led0: led_0 {
			gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
			label = "Green LED 0";
		led1: led_1 {
			gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
			label = "Green LED 1";
		led2: led_2 {
			gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
			label = "Green LED 2";
		led3: led_3 {
			gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
			label = "Green LED 3";
	pwmleds {
		compatible = "pwm-leds";
		pwm_led0: pwm_led_0 {
			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
	buttons {
		compatible = "gpio-keys";
		button0: button_0 {
			gpios = <&gpio0 11 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 0";
		button1: button_1 {
			gpios = <&gpio0 12 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 1";
		button2: button_2 {
			gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 2";
		button3: button_3 {
			gpios = <&gpio0 25 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "Push button switch 3";
	arduino_header: connector {
		compatible = "arduino-header-r3";
		#gpio-cells = <2>;
		gpio-map-mask = <0xffffffff 0xffffffc0>;
		gpio-map-pass-thru = <0 0x3f>;
		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
			   <1 0 &gpio0 4 0>,	/* A1 */
			   <2 0 &gpio0 28 0>,	/* A2 */
			   <3 0 &gpio0 29 0>,	/* A3 */
			   <4 0 &gpio0 30 0>,	/* A4 */
			   <5 0 &gpio0 31 0>,	/* A5 */
			   <6 0 &gpio1 1 0>,	/* D0 */
			   <7 0 &gpio1 2 0>,	/* D1 */
			   <8 0 &gpio1 3 0>,	/* D2 */
			   <9 0 &gpio1 4 0>,	/* D3 */
			   <10 0 &gpio1 5 0>,	/* D4 */
			   <11 0 &gpio1 6 0>,	/* D5 */
			   <12 0 &gpio1 7 0>,	/* D6 */
			   <13 0 &gpio1 8 0>,	/* D7 */
			   <14 0 &gpio0 17 0>,	/* D8 */
			   <15 0 &gpio0 19 0>,	/* D9 */
			   <16 0 &gpio0 20 0>,	/* D10 */
			   <17 0 &gpio0 21 0>,	/* D11 */
			   <18 0 &gpio0 22 0>,	/* D12 */
			   <19 0 &gpio0 23 0>,	/* D13 */
			   <20 0 &gpio0 26 0>,	/* D14 */
			   <21 0 &gpio0 27 0>;	/* D15 */
	/* These aliases are provided for compatibility with samples */
	aliases {
		led0 = &led0;
		led1 = &led1;
		led2 = &led2;
		led3 = &led3;
		pwm-led0 = &pwm_led0;
		sw0 = &button0;
		sw1 = &button1;
		sw2 = &button2;
		sw3 = &button3;
		bootloader-led0 = &led0;
		mcuboot-button0 = &button0;
		mcuboot-led0 = &led0;
		watchdog0 = &wdt0;
		//added , avoid this
		//spiflash0 = &w25q64;
&adc {
	status = "okay";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&uart0 {
	compatible = "nordic,nrf-uart";
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
arduino_serial: &uart1 {
	pinctrl-0 = <&uart1_default>;
	pinctrl-1 = <&uart1_sleep>;
arduino_i2c: &i2c0 {
	compatible = "nordic,nrf-twi";
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
&i2c1 {
	/* Cannot be used together with spi1. */
	/* status = "okay"; */
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
&spi0 {
	compatible = "nordic,nrf-spi";
	/* Cannot be used together with i2c0. */
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
&spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
arduino_spi: &spi3 {
	status = "okay";
	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
	pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
&ieee802154 {
	status = "okay";
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0xC000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x37000>;
		slot1_partition: partition@43000 {
			label = "image-1";
			reg = <0x00043000 0x37000>;
		storage_partition: partition@7a000 {
			label = "storage";
			reg = <0x0007A000 0x00006000>;
zephyr_udc0: &usbd {
	compatible = "nordic,nrf-usbd";
	status = "okay";
i invoke the device using same get device command that this example has
still i cant see any serial port
please help
S
    Which NCS version do you use?
    Could you provide a link to the sample which you use?
    Dejan
  • Hello Dejan
    I am having a very tough time regarding this issue .
    I am using sdk 2.6.0 but now I have downgraded to 2.3.0
    same with tool chain .
    sample I use is , zephyr/samples/subsys/usb/console
    please help ,
    after your valuable feedback please answer X1
    X1-  If we upgrade on sdk will the way of using samples also changes ?
  • Hi sir   waiting for your reply .
    I have a custom board that has a USB port .
    i use J-Link which has vdd, swdio,swdclk ,reset, and ground wires that connect to custom board .
    also another nordic product we work on has NO USB port , only a jlink connecter to flash the firmware .
    please tell me how i can see logs/traces on both of these devices/custom boards
    There is an unofficial hello_world_usb sample which demonstrates how to use CDC ACM USB for logging. Can you try it out?
    Dejan
  • HI  thanks for the example , we workred it out it works fine on bare device without any external spi flash configured .
    our custom board uses external flash for littleFS . so when we use this usb console with the flash and littleFS configuration , we have failed to use usb again, means we dont see any COM port of USB when we flash the code.
    Any idea what might be causing this ?
    my device tree looks like this
    	chosen {
    	leds {
    		led0: led_0 {
    			gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
    		led1: led_1 {
    		led2: led_2 {
    		led3: led_3 {
    	pwmleds {
    	buttons {
    		button0: button_0 {
    			gpios = <&gpio0 20 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    		button1: button_1 {
    		button2: button_2 {
    		button3: button_3 {
    		#gpio-cells = <2>;
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		watchdog0 = &wdt0;
    &adc {
    	status = "okay";
    &gpiote {
    	status = "okay";
    &gpio0 {
    	status = "okay";
    &gpio1 {
    	status = "okay";
    &uart0 {
    	status = "okay";
    	status = "okay";
    	status = "okay";
    &i2c1 {
    &pwm0 {
    	status = "okay";
    &spi0 {
    &spi1 {
    	cs-gpios = 	< &gpio0 9 GPIO_ACTIVE_LOW>;
    	status = "okay";
    	w25q64: w25q64jv@0 {
            compatible = "jedec,spi-nor";
            reg = <0>;
    		spi-max-frequency = <8000000>; //spi-max-frequency = <33000000>;
            jedec-id = [ef 40 17];
    		size = <67108864>; //8 Mb //<0x400000>; //4 Mb
            has-dpd;
            t-enter-dpd = <3500>;
            t-exit-dpd = <3500>;
    		sfdp-bfp = [
    			e5 20 f9 ff  ff ff ff 03  44 eb 08 6b  08 3b 42 bb
    			fe ff ff ff  ff ff 00 00  ff ff 40 eb  0c 20 0f 52
    			10 d8 00 00  36 02 a6 00  82 ea 14 c4  e9 63 76 33
    			7a 75 7a 75  f7 a2 d5 5c  19 f7 4d ff  e9 30 f8 80
    		partitions {
    			#size-cells = <1>;
    			lfs1_part: partition@71000 { //438272 bytes by ext secondary | 500,000 byte(approx) , total =  8,388,608 byte
    				label = "storage";
    				reg = <0x71000 0x800000>; //0x400000 //0x00010000(65k) //0x800000(8MB)
    and main file and overlay file is same as example you provided in previous comment .
    please let me know what i am missing .
    S
