Hello, I am trying to debug why my device is failing to work 100% of the time. What happens is an app makes a connection to the device, sends a command to the device, receives a command, sends a command and then disconnects. However, this becomes unstable and does not always send the command.
When making a connection, and writing from the phone to the device. The series of events that occur is what should happen.
38026 3086.366039 4e:b7:b6:93:29:5d c0:bb:d9:86:a7:21 LE LL 60 CONNECT_IND 38027 3086.410650 Master_0x62a34df9 Slave_0x62a34df9 LE LL 35 Control Opcode: LL_FEATURE_REQ 38028 3086.410952 Slave_0x62a34df9 Master_0x62a34df9 ATT 33 Rcvd Exchange MTU Request, Client Rx MTU: 247 38029 3086.455650 Master_0x62a34df9 Slave_0x62a34df9 ATT 33 Sent Exchange MTU Response, Server Rx MTU: 247 38030 3086.455936 Slave_0x62a34df9 Master_0x62a34df9 LE LL 35 Control Opcode: LL_FEATURE_RSP 38031 3086.500650 Master_0x62a34df9 Slave_0x62a34df9 LE LL 35 Control Opcode: LL_LENGTH_REQ 38032 3086.500952 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38033 3086.501182 Master_0x62a34df9 Slave_0x62a34df9 ATT 33 Sent Exchange MTU Request, Client Rx MTU: 50 38034 3086.590651 Master_0x62a34df9 Slave_0x62a34df9 ATT 33 Sent Exchange MTU Request, Client Rx MTU: 50 38035 3086.590938 Slave_0x62a34df9 Master_0x62a34df9 LE LL 35 Control Opcode: LL_LENGTH_RSP 38036 3086.635652 Master_0x62a34df9 Slave_0x62a34df9 LE LL 49 Control Opcode: LL_ENC_REQ 38037 3086.636066 Slave_0x62a34df9 Master_0x62a34df9 ATT 33 Rcvd Exchange MTU Response, Server Rx MTU: 247 38038 3086.680652 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38039 3086.680882 Slave_0x62a34df9 Master_0x62a34df9 LE LL 39 Control Opcode: LL_ENC_RSP 38040 3086.725652 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38041 3086.725883 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38042 3086.770653 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38043 3086.770883 Slave_0x62a34df9 Master_0x62a34df9 LE LL 27 Control Opcode: LL_START_ENC_REQ 38044 3086.815653 Master_0x62a34df9 Slave_0x62a34df9 LE LL 27 Control Opcode: LL_START_ENC_RSP 38045 3086.815924 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38046 3086.860654 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38047 3086.860884 Slave_0x62a34df9 Master_0x62a34df9 LE LL 27 Control Opcode: LL_START_ENC_RSP 38048 3086.905654 Master_0x62a34df9 Slave_0x62a34df9 LE LL 38 Control Opcode: LL_CONNECTION_UPDATE_IND 38049 3086.906013 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38050 3086.906243 Master_0x62a34df9 Slave_0x62a34df9 ATT 35 Sent Write Request, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 38051 3086.950654 Master_0x62a34df9 Slave_0x62a34df9 ATT 35 Sent Write Request, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 38052 3086.950989 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38053 3086.995655 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38054 3086.995885 Slave_0x62a34df9 Master_0x62a34df9 ATT 31 Rcvd Write Response, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 38055 3087.040655 Master_0x62a34df9 Slave_0x62a34df9 ATT 37 Sent Read By Type Request, Server Supported Features, Handles: 0x0001..0xffff 38056 3087.041005 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38057 3087.085656 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38058 3087.085886 Slave_0x62a34df9 Master_0x62a34df9 ATT 35 Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access) 38059 3087.130656 Master_0x62a34df9 Slave_0x62a34df9 ATT 39 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 38060 3087.131023 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38061 3087.175657 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38062 3087.175886 Slave_0x62a34df9 Master_0x62a34df9 ATT 31 Rcvd Write Response, Handle: 0x0018 (Unknown: Unknown) 38063 3087.176188 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38064 3087.176419 Slave_0x62a34df9 Master_0x62a34df9 ATT 37 Rcvd Handle Value Notification, Handle: 0x0018 (Unknown: Unknown) 38065 3087.220658 Master_0x62a34df9 Slave_0x62a34df9 LE LL 53 L2CAP Fragment Start 38066 3087.221136 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38067 3087.221366 Master_0x62a34df9 Slave_0x62a34df9 ATT 38 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 38068 3087.221724 Slave_0x62a34df9 Master_0x62a34df9 LE LL 26 Empty PDU 38069 3087.265658 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38070 3087.265888 Slave_0x62a34df9 Master_0x62a34df9 ATT 31 Rcvd Write Response, Handle: 0x0018 (Unknown: Unknown) 38071 3087.310659 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU 38072 3087.310889 Slave_0x62a34df9 Master_0x62a34df9 LE LL 28 Control Opcode: LL_TERMINATE_IND 38073 3087.325659 Master_0x62a34df9 Slave_0x62a34df9 LE LL 26 Empty PDU
When it doesn't work these events occur
41203 3331.339432 5e:52:e4:32:78:39 c0:bb:d9:86:a7:21 LE LL 60 CONNECT_IND 41204 3331.347992 Master_0x688111c1 Slave_0x688111c1 LE LL 35 Control Opcode: LL_FEATURE_REQ 41205 3331.348294 Slave_0x688111c1 Master_0x688111c1 ATT 33 Rcvd Exchange MTU Request, Client Rx MTU: 247 41206 3331.392993 Master_0x688111c1 Slave_0x688111c1 ATT 33 Sent Exchange MTU Response, Server Rx MTU: 247 41207 3331.393280 Slave_0x688111c1 Master_0x688111c1 LE LL 35 Control Opcode: LL_FEATURE_RSP 41208 3331.393582 Master_0x688111c1 Slave_0x688111c1 ATT 33 Sent Exchange MTU Request, Client Rx MTU: 50 41209 3331.437994 Master_0x688111c1 Slave_0x688111c1 ATT 33 Sent Exchange MTU Request, Client Rx MTU: 50 41210 3331.438280 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41211 3331.438510 Master_0x688111c1 Slave_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_REQ 41212 3331.482994 Master_0x688111c1 Slave_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_REQ 41213 3331.483297 Slave_0x688111c1 Master_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_REQ 41214 3331.483599 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41215 3331.527995 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41216 3331.528225 Slave_0x688111c1 Master_0x688111c1 ATT 33 Rcvd Exchange MTU Response, Server Rx MTU: 247 41217 3331.528511 Master_0x688111c1 Slave_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_RSP 41218 3331.572995 Master_0x688111c1 Slave_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_RSP 41219 3331.573297 Slave_0x688111c1 Master_0x688111c1 LE LL 35 Control Opcode: LL_LENGTH_RSP 41220 3331.573599 Master_0x688111c1 Slave_0x688111c1 ATT 35 Sent Write Request, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 41221 3331.617996 Master_0x688111c1 Slave_0x688111c1 ATT 35 Sent Write Request, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 41222 3331.618297 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41223 3331.618527 Master_0x688111c1 Slave_0x688111c1 LE LL 49 Control Opcode: LL_ENC_REQ 41224 3331.662996 Master_0x688111c1 Slave_0x688111c1 LE LL 49 Control Opcode: LL_ENC_REQ 41225 3331.663410 Slave_0x688111c1 Master_0x688111c1 ATT 31 Rcvd Write Response, Handle: 0x0019 (Unknown: Unknown: Client Characteristic Configuration) 41226 3331.707996 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41227 3331.708227 Slave_0x688111c1 Master_0x688111c1 LE LL 39 Control Opcode: LL_ENC_RSP 41228 3331.752997 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41229 3331.753227 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41230 3331.797997 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41231 3331.798227 Slave_0x688111c1 Master_0x688111c1 LE LL 27 Control Opcode: LL_START_ENC_REQ 41232 3331.842998 Master_0x688111c1 Slave_0x688111c1 LE LL 27 Control Opcode: LL_START_ENC_RSP 41233 3331.843268 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41234 3331.887998 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41235 3331.888228 Slave_0x688111c1 Master_0x688111c1 LE LL 27 Control Opcode: LL_START_ENC_RSP 41236 3331.932999 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41237 3331.933229 Slave_0x688111c1 Master_0x688111c1 LE LL 27 Control Opcode: LL_START_ENC_RSP 41238 3332.022999 Master_0x688111c1 Slave_0x688111c1 LE LL 38 Control Opcode: LL_CONNECTION_UPDATE_IND 41239 3332.023358 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41240 3332.023588 Master_0x688111c1 Slave_0x688111c1 ATT 39 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41241 3332.068000 Master_0x688111c1 Slave_0x688111c1 ATT 39 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41242 3332.068366 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41243 3332.113000 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41244 3332.113231 Slave_0x688111c1 Master_0x688111c1 ATT 31 Rcvd Write Response, Handle: 0x0018 (Unknown: Unknown) 41245 3332.113533 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41246 3332.113763 Slave_0x688111c1 Master_0x688111c1 ATT 37 Rcvd Handle Value Notification, Handle: 0x0018 (Unknown: Unknown) 41247 3332.158001 Master_0x688111c1 Slave_0x688111c1 ATT 37 Sent Read By Type Request, Server Supported Features, Handles: 0x0001..0xffff 41248 3332.158351 Slave_0x688111c1 Master_0x688111c1 LE LL 26 Empty PDU 41249 3332.203001 Master_0x688111c1 Slave_0x688111c1 LE LL 26 Empty PDU 41250 3332.203232 Slave_0x688111c1 Master_0x688111c1 ATT 35 Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access) 41251 3332.248002 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41252 3332.293003 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41253 3332.383004 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41254 3332.428004 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41255 3332.443004 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41256 3332.458004 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41257 3332.473004 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41258 3332.488005 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41259 3332.503005 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41260 3332.518005 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41261 3332.533005 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41262 3332.548006 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41263 3332.563006 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41264 3332.578006 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41265 3332.593007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41266 3332.608007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41267 3332.623007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41268 3332.638007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41269 3332.653007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41270 3332.668007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41271 3332.683007 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41272 3332.698009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41273 3332.713009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41274 3332.728009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41275 3332.743009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41276 3332.758009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41277 3332.773009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41278 3332.788009 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41279 3332.803010 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41280 3332.818010 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41281 3332.833010 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41282 3332.863010 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41283 3332.878010 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41284 3332.893011 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41285 3332.908011 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41286 3332.923012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41287 3332.938012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41288 3332.953012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41289 3332.968012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41290 3332.983012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41291 3332.998012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41292 3333.013012 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41293 3333.028013 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41294 3333.043014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41295 3333.058014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41296 3333.073014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41297 3333.088014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41298 3333.103014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41299 3333.118014 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41300 3333.133015 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41301 3333.148015 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41302 3333.163015 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41303 3333.178015 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41304 3333.193016 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41305 3333.208016 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41306 3333.223016 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41307 3333.238016 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41308 3333.253017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41309 3333.268017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41310 3333.283017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41311 3333.298017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41312 3333.313017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41313 3333.328017 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41314 3333.343018 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41315 3333.358019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41316 3333.373019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41317 3333.388019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41318 3333.403019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41319 3333.418019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41320 3333.433019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41321 3333.448019 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41322 3333.463020 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41323 3333.478020 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41324 3333.493021 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41325 3333.508021 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41326 3333.523021 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41327 3333.538021 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41328 3333.553021 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41329 3333.568022 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41330 3333.583022 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41331 3333.598022 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41332 3333.613022 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41333 3333.628022 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41334 3333.643023 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41335 3333.658023 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41336 3333.673024 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41337 3333.688024 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41338 3333.718024 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41339 3333.733024 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41340 3333.748024 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41341 3333.793025 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41342 3333.823025 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41343 3333.853025 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41344 3333.868025 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41345 3333.883025 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41346 3333.898026 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41347 3333.913026 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41348 3333.928026 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41349 3333.943027 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41350 3333.958027 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41351 3333.973027 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41352 3333.988027 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41353 3334.003028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41354 3334.018028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41355 3334.033028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41356 3334.048028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41357 3334.063028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41358 3334.078028 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41359 3334.093029 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41360 3334.108030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41361 3334.123030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41362 3334.138030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41363 3334.168030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41364 3334.183030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41365 3334.198030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41366 3334.213030 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41367 3334.228031 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41368 3334.243031 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41369 3334.258031 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41370 3334.273031 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41371 3334.288032 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41372 3334.303032 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41373 3334.318032 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41374 3334.348033 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41375 3334.363033 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41376 3334.378033 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41377 3334.393033 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41378 3334.423033 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41379 3334.438034 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41380 3334.453034 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41381 3334.468034 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41382 3334.483034 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41383 3334.498034 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41384 3334.513035 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41385 3334.528035 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41386 3334.543035 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41387 3334.558036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41388 3334.573036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41389 3334.588036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41390 3334.603036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41391 3334.618036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Encrypted packet decrypted incorrectly (bad CRC) 41392 3334.633036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41393 3334.648036 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41394 3334.663038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41395 3334.678038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41396 3334.693038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41397 3334.708038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41398 3334.723038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41399 3334.738038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41400 3334.753038 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41401 3334.768039 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41402 3334.783039 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41403 3334.798039 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41404 3334.813040 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41405 3334.828040 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41406 3334.843040 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41407 3334.858040 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41408 3334.873041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41409 3334.903041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41410 3334.918041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41411 3334.933041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41412 3334.948041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41413 3334.963041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41414 3334.978041 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41415 3334.993042 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41416 3335.008043 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41417 3335.023043 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41418 3335.053043 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41419 3335.068043 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41420 3335.083043 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41421 3335.098044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41422 3335.113044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41423 3335.128044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41424 3335.143044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41425 3335.158044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41426 3335.173044 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41427 3335.188045 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41428 3335.203046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41429 3335.218046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41430 3335.233046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41431 3335.248046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41432 3335.263046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41433 3335.278046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41434 3335.293046 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41435 3335.308047 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41436 3335.323047 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41437 3335.338047 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41438 3335.353048 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41439 3335.368048 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41440 3335.383048 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41441 3335.398048 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41442 3335.413048 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41443 3335.428049 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41444 3335.443049 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41445 3335.458049 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41446 3335.473049 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41447 3335.488049 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41448 3335.503050 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41449 3335.518050 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41450 3335.533051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41451 3335.548051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41452 3335.563051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41453 3335.578051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41454 3335.593051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41455 3335.608051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41456 3335.623051 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41457 3335.638052 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41458 3335.653053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41459 3335.668053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41460 3335.683053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41461 3335.698053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41462 3335.713053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41463 3335.728053 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41464 3335.758054 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41465 3335.773054 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41466 3335.788054 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41467 3335.803054 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41468 3335.818054 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41469 3335.833055 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41470 3335.863055 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41471 3335.878056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41472 3335.893056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41473 3335.908056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41474 3335.923056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41475 3335.938056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41476 3335.953056 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41477 3335.968057 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41478 3335.983057 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41479 3335.998057 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41480 3336.013057 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41481 3336.028058 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41482 3336.043058 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41483 3336.058058 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41484 3336.073059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41485 3336.088059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41486 3336.103059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41487 3336.118059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41488 3336.133059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41489 3336.148059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41490 3336.163059 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41491 3336.178061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41492 3336.193061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41493 3336.208061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41494 3336.223061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41495 3336.238061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41496 3336.253061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41497 3336.268061 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41498 3336.283062 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41499 3336.298062 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41500 3336.313062 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41501 3336.328063 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41502 3336.343063 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41503 3336.358063 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41504 3336.373063 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41505 3336.388063 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41506 3336.403064 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41507 3336.418064 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41508 3336.433064 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41509 3336.448064 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41510 3336.463064 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41511 3336.478065 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41512 3336.493065 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41513 3336.508066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41514 3336.523066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41515 3336.538066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41516 3336.553066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41517 3336.568066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41518 3336.583066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41519 3336.598066 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41520 3336.613067 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41521 3336.628067 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41522 3336.643068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41523 3336.658068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41524 3336.673068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41525 3336.688068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41526 3336.703068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41527 3336.718068 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41528 3336.733069 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41529 3336.763069 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41530 3336.778069 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41531 3336.793069 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41532 3336.808069 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41533 3336.823070 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41534 3336.838071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41535 3336.853071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41536 3336.868071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41537 3336.883071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41538 3336.898071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41539 3336.913071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41540 3336.928071 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41541 3336.943072 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41542 3336.958072 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41543 3336.973073 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41544 3336.988073 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41545 3337.018073 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41546 3337.033073 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41547 3337.048074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41548 3337.063074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41549 3337.078074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41550 3337.093074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41551 3337.108074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41552 3337.123074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41553 3337.138074 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41554 3337.153075 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41555 3337.168076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41556 3337.183076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41557 3337.198076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41558 3337.213076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41559 3337.228076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41560 3337.243076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41561 3337.258076 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41562 3337.273077 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41563 3337.288077 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41564 3337.303077 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41565 3337.318078 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41566 3337.333078 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41567 3337.348078 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41568 3337.363078 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41569 3337.378079 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41570 3337.393079 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41571 3337.408079 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41572 3337.423079 Master_0x688111c1 Slave_0x688111c1 ATT 65 Sent Write Request, Handle: 0x0018 (Unknown: Unknown) 41573 3342.531017 c0:bb:d9:86:a7:21 Broadcast LE LL 62 ADV_IND
One of the differences I've noticed is that when the sequence works, it starts by Sent Read By Type Request, Server Supported Features, Handles: 0x0001..0xffff, then gets the Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access), and then sends the commands.
However, when it doesn't work, it gets halfway through sending and receiving the commands list at the top, then sends Sent Read By Type Request, Server Supported Features, Handles: 0x0001..0xffff, then gets the Rcvd Error Response - Attribute Not Found, Handle: 0x0001 (Generic Access), and then tries to send the last part of the sequence.
What exactly are these messages, why is it out of sequence, and what would be the fix?
Debugging this on the nRF the last three BLE events are:
<debug> nrf_sdh_ble: BLE event: 0x57.
<debug> nrf_sdh_ble: BLE event: 0x12.
<debug> nrf_sdh_ble: BLE event: 0x11.
