I'm trying to use to gpio pins in order to wake up a system from sleep mode.(PIN1= P0.24 PIN2 =P1.1 )
If I use the GPIOTEs separately in my project, it works and sytem wakes up, but if I use both GPIOTEs at the same time, it doesnt work.
below is my code:
void bma400_int_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
NRF_LOG_INFO("Activity detected");
void check_pod_handle(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
NRF_LOG_INFO("check pod detected");
void gpiote_init(void)
ret_code_t err_code;
if (!nrf_drv_gpiote_is_init())
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
in_config.pull = NRF_GPIO_PIN_NOPULL;
err_code = nrf_drv_gpiote_in_init(BMA400_INT, &in_config, bma400_int_handler);
err_code = nrf_drv_gpiote_in_init(CHECK_POD_PIN, &in_config, check_pod_handle);
nrf_drv_gpiote_in_event_enable(BMA400_INT, true);
nrf_drv_gpiote_in_event_enable(CHECK_POD_PIN, true);
nrf_gpio_cfg_sense_input(BMA400_INT, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
nrf_gpio_cfg_sense_input(CHECK_POD_PIN, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
i am using nrf52840, sdk 17.02, custom board,segger embedded studio
Can you help with setting up those pins for wake-up?
Thanks
Emrah
