I am implemented the uart functionality, I'm getting below issue.
[00:00:00.445,526] <err> Throughput: Failed to set UART callback (err -88)
[00:00:00.445,556] <err> Throughput: uart_init failed (err -88)
I checked with the logic analyzer and I am getting the signals Please find below image,
pri.config:
#Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE1=y
CONFIG_SERIAL=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_LOG_PRINTK=y
CONFIG_ASSERT=y
CONFIG_UART_1_INTERRUPT_DRIVEN=y
main.c:
#include <zephyr/kernel.h>
#include <nrfx_clock.h>
#include <stdio.h>
#include <stddef.h>
#include <errno.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/device.h>
#include <zephyr/settings/settings.h>
#include <zephyr/drivers/uart.h>
#define LOG_MODULE_NAME Throughput
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 20
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(100)
#define UART_RX_TIMEOUT 60000 /* Wait for RX complete event time in microseconds. */
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
static struct k_work_delayable uart_work;
struct uart_data_t {
void *fifo_reserved;
uint8_t data[UART_BUF_SIZE];
uint16_t len;
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
ARG_UNUSED(dev);
static size_t aborted_len;
struct uart_data_t *buf;
static uint8_t *aborted_buf;
static bool disable_req;
switch (evt->type) {
case UART_TX_DONE:
LOG_DBG("UART_TX_DONE");
if (!evt->data.tx.buf || evt->data.tx.len == 0) {
return;
if (aborted_buf) {
buf = CONTAINER_OF(aborted_buf, struct uart_data_t, data[0]);
aborted_buf = NULL;
aborted_len = 0;
} else {
buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t, data[0]);
k_free(buf);
buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
if (buf) {
if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
LOG_WRN("Failed to send data over UART");
case UART_RX_RDY:
LOG_DBG("UART_RX_RDY");
buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data[0]);
buf->len += evt->data.rx.len;
if (disable_req) {
return;
if (evt->data.rx.buf[buf->len - 1] == '\n' || evt->data.rx.buf[buf->len - 1] == '\r') {
disable_req = true;
uart_rx_disable(uart);
case UART_RX_DISABLED:
LOG_DBG("UART_RX_DISABLED");
disable_req = false;
buf = k_malloc(sizeof(*buf));
if (buf) {
buf->len = 0;
uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_RX_TIMEOUT);
} else {
LOG_WRN("Not able to allocate UART receive buffer");
k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
case UART_RX_BUF_REQUEST:
LOG_DBG("UART_RX_BUF_REQUEST");
if (buf) {
buf->len = 0;
uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
} else {
case UART_RX_BUF_RELEASED:
LOG_DBG("UART_RX_BUF_RELEASED");
buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t, data[0]);
if (buf->len > 0) {
k_fifo_put(&fifo_uart_rx_data, buf);
} else {
k_free(buf);
case UART_TX_ABORTED:
LOG_DBG("UART_TX_ABORTED");
if (!aborted_buf) {
aborted_buf = (uint8_t *)evt->data.tx.buf;
aborted_len += evt->data.tx.len;
uart_tx(uart, &buf->data[aborted_len], buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
if (buf) {
buf->len = 0;
} else {
return;
static int uart_init(void)
int err;
int pos;
struct uart_data_t *tx;
struct uart_data_t *rx;
if (!device_is_ready(uart)) {
LOG_ERR("UART device not ready");
return -ENODEV;
rx = k_malloc(sizeof(*rx));
if (!rx) {
return -ENOMEM;
rx->len = 0;
k_work_init_delayable(&uart_work, uart_work_handler);
err = uart_callback_set(uart, uart_cb, NULL);
if (err) {
LOG_ERR("Failed to set UART callback (err %d)", err);
return err;
printk("UART initialized successfully");
tx = k_malloc(sizeof(*tx));
if (tx) {
pos = snprintf(tx->data, sizeof(tx->data), "WELCOME NOrdic\r\n");
if ((pos < 0) || (pos >= sizeof(tx->data))) {
k_free(tx);
LOG_ERR("snprintf returned %d", pos);
return;
tx->len = pos;
} else {
return;
err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
if (err) {
k_free(tx);
LOG_ERR("Cannot display welcome message (err: %d)", err);
return;
return uart_rx_enable(uart, rx->data, sizeof(rx->data),
UART_RX_TIMEOUT);
int err;
err = uart_init();
if (err != 0) {
LOG_ERR("uart_init failed (err %d)", err);
return 0;
I'm using the nRF7002dk, I configured the uart pins as mention in the below overlay file
&pinctrl {
uart1_default: uart1_default {
group1 {
psels = <NRF_PSEL(UART_TX, 1, 1)>,
<NRF_PSEL(UART_RX, 1, 2)>;
uart1_sleep: uart1_sleep {
group1 {
low-power-enable;
&uart1 {
status = "okay";
current-speed = <115200>;
pinctrl-0 = <&uart1_default>;
pinctrl-1 = <&uart1_sleep>;
YOUR HELP IS MUCH APPRICIATED,
Thanks & Regards,
SUDHAKAR V.
