Not Getting I2S Data.
I have been working with I2S Mic sph0645lm4h-b and nRF5340 audio DK. I configured mic and while I'm reading the data it throughs an error code of -5. I'm Sharing the code below
#include <zephyr/kernel.h>
#include <zephyr/drivers/i2s.h>
#define I2S_RX_NODE  DT_NODELABEL(i2s_rx)
#define SAMPLE_FREQUENCY    16000
#define SAMPLE_BIT_WIDTH    32
#define BYTES_PER_SAMPLE    sizeof(int16_t)
#define NUMBER_OF_CHANNELS  1
#define SAMPLES_PER_BLOCK   ((SAMPLE_FREQUENCY / 10) * NUMBER_OF_CHANNELS)
#define INITIAL_BLOCKS      2
#define TIMEOUT             1000
#define BLOCK_SIZE  (BYTES_PER_SAMPLE * SAMPLES_PER_BLOCK)
#define BLOCK_COUNT (INITIAL_BLOCKS + 2)
K_MEM_SLAB_DEFINE_STATIC(mem_slab, BLOCK_SIZE, BLOCK_COUNT, 4);
static const struct device *i2s_dev_rx;
static struct i2s_config config;
static int ret;
static void audInit(void){
	i2s_dev_rx = DEVICE_DT_GET(I2S_RX_NODE);
	if(!i2s_dev_rx){
		printk("Unable to find i2s_rxtx device \n");
	else{
		printk("Found i2s_rxtx device \n");
	config.word_size = SAMPLE_BIT_WIDTH;
	config.channels = NUMBER_OF_CHANNELS;
	config.format = I2S_FMT_DATA_FORMAT_I2S;
	config.options = I2S_OPT_BIT_CLK_MASTER | I2S_OPT_FRAME_CLK_MASTER;
	config.frame_clk_freq = SAMPLE_FREQUENCY;
	config.mem_slab = &mem_slab;
	config.block_size = BLOCK_SIZE;
	config.timeout = TIMEOUT;
	ret = i2s_configure(i2s_dev_rx, I2S_DIR_RX, &config);
	if (ret!=0) {
		printk("i2s_config failed %d \n", ret);
	else{
		printk("i2s_config Pass \n");
	audInit();
	ret = i2s_trigger(i2s_dev_rx, I2S_DIR_RX, I2S_TRIGGER_START);
	if (ret != 0) {
	    printk("i2s_trigger failed %d \n", ret);
	else{
		printk("i2s_trigger Pass \n");
	void *mem_block;
	uint32_t block_size;
	int16_t sampleData;
	while (1) {
		ret = i2s_read(i2s_dev_rx, &mem_block, &block_size);
		if (ret < 0) {
			printk("Failed to read data: %d\n", ret);
		for (int i = 0; i < SAMPLES_PER_BLOCK; ++i) {
                        sampleData = ((int16_t *)mem_block)[i] >> 16;
						// printk("data: %d\n", sampleData);
	k_free(mem_block);
	return 0;
Output:
Also I'm sharing the overlay code
&pinctrl {
    i2s0_default: i2s0_default {
        group1 {
            psels = <NRF_PSEL(I2S_MCK, 0, 12)>;
            nordic,drive-mode = <NRF_DRIVE_H0H1>;
        group2 {
            psels = <NRF_PSEL(I2S_SCK_M, 0, 26)>,
                <NRF_PSEL(I2S_LRCK_M, 0, 25)>,
                <NRF_PSEL(I2S_SDOUT, 1, 14)>,
                <NRF_PSEL(I2S_SDIN, 0, 7)>;
    i2s0_sleep: i2s0_sleep {
        group1 {
            psels = <NRF_PSEL(I2S_MCK, 0, 12)>,
            low-power-enable;
i2s_rx:&i2s0 {
    compatible = "nordic,nrf-i2s";
    status = "okay";
    pinctrl-0 = <&i2s0_default>;
    pinctrl-1 = <&i2s0_sleep>;
clock: clock@5000 {
	compatible = "nordic,nrf-clock";
	reg = <0x5000 0x1000>;
	interrupts = <5 NRF_DEFAULT_IRQ_PRIORITY>;
	status = "okay";
	hfclkaudio-frequency = <11289600>;
In proj.conf I have also enabled I2S using "CONFIG_I2S=y"
Help me out here. Am I dong any mistake here, just correct me out.
Thanks in advance,
Laksh
  • Your code is missing the required k_mem_slab_free()  call inside the while loop. The k_free() call is both wrong function and in the wrong place.
  • Hi Turbo,
    Can you elaborate a bit, so that I can proceed further. As you mentioned i cahnged the code
    while (1) {
    		if (ret < 0) {
    		else{
    			printk("Read Data Success \n");
    		k_mem_slab_free(&mem_slab, mem_block);
    After this im getting the data as only 0 and -1 since Im using mic I know the data is wrong.
    Also, When I checked the BCLK pin in oscillosocpe its not generating any clock signal.
    Thanks
  • Looking at the code it looks like you started with the \zephyr\samples\drivers\i2s\echo\src\main.c project, I suggest to revert back a bit, and provide a bit more information about what change caused it to fail to start with.
    Kenneth
  • In \zephyr\samples\drivers\i2s\echo\src\main.c project I made modifications to only init and get data. There is nothing much I did in that code. I have shared the code
    Laksh
    I Managed to get the data but the thing is when i print the data with printk it throws a read error of -5. The error indicates -EIO. As I checked it is related to memory slab. Can anyone help me on this issue. Im Sharing the code here.
    #include <string.h>
    #define I2S_RX_NODE DT_NODELABEL(i2s_rxtx)
    static int16_t echo_block[SAMPLES_PER_BLOCK];
    uint8_t loopCnt = 0;
    static void process_block_data(void *mem_block, uint32_t number_of_samples)
    	for (int i = 0; i < number_of_samples; ++i)
    		int16_t *sample = &((int16_t *)mem_block)[i];
    		echo_block[i] = *sample;
    		printk("%d\n", echo_block[i]);
    static bool configure_streams(const struct device *i2s_dev_rx, const struct i2s_config *config)
    	int ret = i2s_configure(i2s_dev_rx, I2S_DIR_RX, config);
    	if (ret == 0)
    		printk("Configure Stream Successful.\n");
    		return true;
    	printk("Failed to configure streams: %d\n", ret);
    	return false;
    static bool trigger_command(const struct device *i2s_dev_rx, enum i2s_trigger_cmd cmd)
    	int ret = i2s_trigger(i2s_dev_rx, I2S_DIR_RX, cmd);
    	if (ret == 0)
    		printk("Trigger Command Successful.\n");
    		return true;
    	printk("Failed to trigger command %d: %d\n", cmd, ret);
    	return false;
    	const struct device *const i2s_dev_rx = DEVICE_DT_GET(I2S_RX_NODE);
    	printk("I2S echo sample\n");
    	if (!device_is_ready(i2s_dev_rx))
    		printk("%s is not ready\n", i2s_dev_rx->name);
    		return 0;
    	if (!configure_streams(i2s_dev_rx, &config))
    		return 0;
    	if (!trigger_command(i2s_dev_rx, I2S_TRIGGER_START))
    		return 0;
    	printk("Streams started\n");
    	while (1)
    		void *mem_block;
    		int ret;
    		if (ret < 0)
    		process_block_data(mem_block, block_size);
    		printk("Loop: %d\n", loopCnt);
    		loopCnt++;
    	printk("Exiting main loop\n");
    	return 0;
    Thanks in advance
    Laksh
