nRF51 dongle Arduino / ATmega AVR with TWI ANT
I have a few nRF51 dongles I wish to use with ANT+ for wireless mesh communication between some robots. I want to connect each to one ATmega 1284p and another Arduino Mega with ATmega 2560, both 5v chips. Can I connect them directly to the GPIO edge pins to interface with TWI or will it destroy the nRF chip?
Edit; www.nordicsemi.com/.../nRF51-Dongle
  • If you connect the TWI (I2C) pullups to the nRF51 3V supply, that should be OK - so long as nothing on the Arduino is pulling-up to 5V...
  • I've not used the nRF51 I2C, but the way to check is the same as for any microcontroller:
    1. Look at the chip datasheet to see what pins can function as I2C;
    2. Look at the dongle schematics to see if any of the available connections map to the I2C-capable pins identified above.
    The radio scheme you describe should be possible, but is certainly not a beginner project. You should plan to take some time to get familiar with ANT and the Nordic systems and experiment with simple connections before attempting the mesh ...
