After installing SDK 2.7 I am unable to get nRF Connect SDK to function in VS Code.
After I installed nRF Connect SDK 2.7 and tried to run the pre-release version of VS Code extension, I am now compleatly unable to make nRF Connect for VS Code function.
When using the menu to select toolchains, I get nothing to select installed SDK or toolchain. I see an error dispolayed by VS Code "command 'nrf-connect.mangeWestWorkspace' not found" or "command 'nrf-connect.mangeToolchains' not found".
I have uninstalled everything two times (both VS Code extensions (all) and the SDK and reinstalled again. One time from within VS Code extension and one time through the nRF Connect for Desktop Toolchain Manager.
None of the reinstallation have brought my installation back to a functional state.
I am sure it is a simple thing, but I do not know where to look....
  • Well I killed it again. From within VS Code I selected to install toolchain and SDK version v2.7.0.
    I created a new application from a sample, was able to build a prestine build. But then trying to flash to my DK board, I get an error. I think my problems started the same way earlier. When trying to flash the newly successfully build application i get:
    west flash: using runner nrfjprog
    runners.nrfjprog: reset after flashing requested
    runners.nrfjprog: Flashing file: d:\Workspaces\pmi8004i\build_1\zephyr\merged.hex
    [error] [ Client] - Encountered error -102: Command read_device_info executed for 142 milliseconds with result -102
    [error] [ Worker] - An unknown error.
    [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 31 milliseconds with result -102
    Failed to read device memories.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'd:\Workspaces\pmi8004i\build_1\zephyr\merged.hex' --sectorerase --verify -f NRF91 --snr 960090542
    The terminal process terminated with exit code: 33.
    Terminal will be reused by tasks, press any key to close it.
    And unfortunately after goiing back to 2.6.1 the problem persists.
  • hello,
    Have you checked whether you are able to generate the support information now? Please attach if you are able to. Otherwise, follow the step I mentioned in this response and attach it here. We need these details to investigate the issue.
    Kind Regards,
    Abhijith
  • [15:09:47] nRF Command Line Tools 10.24.2 are up to date
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 11 Pro",
        "osKernel": "10.0.26257",
        "vscode": "1.92.0",
        "electron": "30.1.2",
        "node": "v20.14.0"
      "system": {
        "date": "2024-08-06T13:10:01.889Z",
        "vscodeRoot": "c:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:00:20",
        "osUptime": "116:24:12",
        "cpu": "Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz"
      "workspace": {
        "name": "pmi8004i",
        "workspaceFile": null,
        "folders": [
          "d:\\Workspaces\\pmi8004i"
      "sdks": [
          "version": "v2.7.0",
          "path": "d:\\ncs\\v2.7.0"
          "version": "v2.6.1",
          "path": "d:\\ncs\\v2.6.1"
      "activeBuild": "d:\\Workspaces\\pmi8004i\\build_1",
      "apps": [
          "workspace": "d:\\Workspaces\\pmi8004i",
          "uri": "d:\\Workspaces\\pmi8004i",
          "buildConfigurations": [
              "id": "d:\\Workspaces\\pmi8004i\\build_1",
              "name": "build_1",
              "boardId": "nrf9160dk_nrf9160_ns",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
      "topdir": "d:\\ncs\\v2.6.1",
      "workspaceState": "freestanding-ready",
      "toolchains": [
          "version": "2.7.0",
          "path": "d:\\ncs\\toolchains\\ce3b5ff664"
          "version": "2.6.1",
          "path": "d:\\ncs\\toolchains\\cf2149caf2"
      "connectedDevices": [
          "serialNumber": "000960090542"
      "deviceProvider": "nrfutil",
      "tools": {
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.5",
        "C:\\Program Files\\SEGGER\\JLink_V794e\\JLink.exe": "7.94e",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.2",
        "C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37\\Scripts\\nrfutil.exe": null,
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\cmake.exe": "3.21.0",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Scripts\\west.exe": "1.2.0",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\python.exe": "3.9.13",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\ninja.exe": "1.10.2",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\gperf.exe": "3.1",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\dtc.exe": "1.4.7",
        "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\gn.exe": "2154",
        "D:\\ncs\\toolchains\\cf2149caf2\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
        "gdbPath": "d:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.0.0",
          "binPath": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.7.13-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
        "nrfutil-toolchain-manager": {
          "version": "0.14.4",
          "binPath": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.7.13-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\ThomasMaltesen",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\ThomasMaltesen",
          "PATH": "D:\\ncs\\toolchains\\cf2149caf2;D:\\ncs\\toolchains\\cf2149caf2\\mingw64\\bin;D:\\ncs\\toolchains\\cf2149caf2\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Scripts;D:\\ncs\\toolchains\\cf2149caf2\\opt\\nanopb\\generator-bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.7.13-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Program Files\\Microsoft SDKs\\Azure\\CLI2\\wbin;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37\\Scripts;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\msb-4.6.7;C:\\Program Files (x86)\\PuTTY\\;C:\\Program Files (x86)\\msb-4.6.8;C:\\SysGCC\\arm-eabi\\bin;C:\\Program Files\\Microsoft Network Monitor 3\\;C:\\Program Files (x86)\\msb-5.0.2;C:\\Program Files (x86)\\msb-5.0.5;C:\\Program Files (x86)\\LonWorks\\Drivers\\FTDI\\amd64;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\Microsoft SQL Server\\140\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Echelon\\License Tools\\;C:\\Program Files (x86)\\LonWorks\\bin;C:\\Program Files (x86)\\msb-5.0.11;C:\\Program Files\\usbipd-win\\;C:\\Program Files\\Intel\\Intel(R) Memory and Storage Tool\\;C:\\Program Files (x86)\\msb-6.0.1;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files (x86)\\nodejs\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\msb-7.0.2;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\PowerShell\\7\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Azure Data Studio\\bin;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Program Files\\Digi\\AnywhereUSBManager\\;C:\\Users\\ThomasMaltesen\\AppData\\Roaming\\npm;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "ZEPHYR_BASE": "d:\\ncs\\v2.6.1\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "D:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk",
          "PYTHONPATH": "D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin;D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Lib;D:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Program Files\\Microsoft SDKs\\Azure\\CLI2\\wbin;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37\\Scripts;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\msb-4.6.7;C:\\Program Files (x86)\\PuTTY\\;C:\\Program Files (x86)\\msb-4.6.8;C:\\SysGCC\\arm-eabi\\bin;C:\\Program Files\\Microsoft Network Monitor 3\\;C:\\Program Files (x86)\\msb-5.0.2;C:\\Program Files (x86)\\msb-5.0.5;C:\\Program Files (x86)\\LonWorks\\Drivers\\FTDI\\amd64;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\Microsoft SQL Server\\140\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Echelon\\License Tools\\;C:\\Program Files (x86)\\LonWorks\\bin;C:\\Program Files (x86)\\msb-5.0.11;C:\\Program Files\\usbipd-win\\;C:\\Program Files\\Intel\\Intel(R) Memory and Storage Tool\\;C:\\Program Files (x86)\\msb-6.0.1;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files (x86)\\nodejs\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\msb-7.0.2;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\PowerShell\\7\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Azure Data Studio\\bin;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Program Files\\Digi\\AnywhereUSBManager\\;C:\\Users\\ThomasMaltesen\\AppData\\Roaming\\npm;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
          "PATH": "C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Program Files\\Microsoft SDKs\\Azure\\CLI2\\wbin;C:\\Program Files\\Microsoft\\jdk-11.0.16.101-hotspot\\bin;C:\\Program Files\\Eclipse Foundation\\jdk-8.0.302.8-hotspot\\bin;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37\\Scripts;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.7_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python37;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Microsoft SQL Server\\130\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\Client SDK\\ODBC\\170\\Tools\\Binn\\;C:\\Program Files (x86)\\msb-4.6.7;C:\\Program Files (x86)\\PuTTY\\;C:\\Program Files (x86)\\msb-4.6.8;C:\\SysGCC\\arm-eabi\\bin;C:\\Program Files\\Microsoft Network Monitor 3\\;C:\\Program Files (x86)\\msb-5.0.2;C:\\Program Files (x86)\\msb-5.0.5;C:\\Program Files (x86)\\LonWorks\\Drivers\\FTDI\\amd64;C:\\Program Files (x86)\\IVI Foundation\\IVI\\bin;C:\\Program Files\\IVI Foundation\\IVI\\bin;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Azure Data Studio\\bin;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files\\Microsoft SQL Server\\140\\Tools\\Binn\\;C:\\Program Files\\Microsoft SQL Server\\150\\Tools\\Binn\\;C:\\Program Files (x86)\\Echelon\\License Tools\\;C:\\Program Files (x86)\\LonWorks\\bin;C:\\Program Files (x86)\\msb-5.0.11;C:\\Program Files\\usbipd-win\\;C:\\Program Files\\Intel\\Intel(R) Memory and Storage Tool\\;C:\\Program Files (x86)\\msb-6.0.1;C:\\Program Files\\Microsoft SQL Server\\120\\Tools\\Binn\\;C:\\Program Files (x86)\\nodejs\\;C:\\Program Files (x86)\\Microsoft SQL Server\\150\\DTS\\Binn\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files (x86)\\msb-7.0.2;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\Windows Kits\\10\\Windows Performance Toolkit\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\PowerShell\\7\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\Scripts\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Python\\Python38-32\\;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Azure Data Studio\\bin;C:\\Program Files\\Azure Data Studio\\bin;C:\\Users\\ThomasMaltesen\\.dotnet\\tools;C:\\Program Files\\Digi\\AnywhereUSBManager\\;C:\\Users\\ThomasMaltesen\\AppData\\Roaming\\npm;C:\\Users\\ThomasMaltesen\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
        "toolchainPath": "d:\\ncs\\toolchains\\cf2149caf2",
        "toolchainBinPath": "d:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.6.1"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "${nrf-connect.sdk:2.6.1}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.6.1}"
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [
            "d:\\nrfboards"
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": true
          "deviceProvider": "",
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": "d:\\ncs"
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask",
          "welcome": {
            "showOnStartup": false
          "terminalMode": "character"
        "marus25.cortex-debug": {
          "variableUseNaturalFormat": true,
          "liveWatchRefreshRate": "300",
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "dbgServerLogfile": null
      "extensions": {
        "internal": {
            "version": "2024.7.13",
            "path": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.7.13-win32-x64",
            "isActive": true
            "version": "2024.3.15",
            "path": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.3.15",
            "isActive": true
            "version": "2024.6.20",
            "path": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.6.20",
            "isActive": true
            "path": "c:\\Users\\ThomasMaltesen\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.6.20",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.12.1",
          "ms-vscode.cpptools": "1.21.6",
          "ms-vscode.js-debug": "1.92.0",
          "ms-vscode.vscode-js-profile-table": "1.0.9",
          "coolbear.systemd-unit-file": "1.0.6",
          "cschlosser.doxdocgen": "1.4.0",
          "eamodio.gitlens": "15.2.3",
          "george-alisson.html-preview-vscode": "0.2.5",
          "GitHub.copilot": "1.220.0",
          "GitHub.copilot-chat": "0.18.1",
          "jeff-hykin.better-cpp-syntax": "1.27.1",
          "jock.svg": "1.5.4",
          "mads-hartmann.bash-ide-vscode": "1.42.0",
          "mcu-debug.debug-tracker-vscode": "0.0.15",
          "mcu-debug.memory-view": "0.0.25",
          "mcu-debug.peripheral-viewer": "1.4.6",
          "mcu-debug.rtos-views": "0.0.7",
          "microhobby.linuxkerneldev": "0.6.1",
          "ms-azuretools.vscode-azurefunctions": "1.15.1",
          "ms-azuretools.vscode-azureresourcegroups": "0.9.1",
          "ms-azuretools.vscode-docker": "1.29.1",
          "ms-dotnettools.csdevkit": "1.8.14",
          "ms-dotnettools.csharp": "2.39.29",
          "ms-dotnettools.vscode-dotnet-runtime": "2.1.1",
          "ms-dotnettools.vscodeintellicode-csharp": "2.1.11",
          "ms-python.debugpy": "2024.10.0",
          "ms-python.isort": "2023.10.1",
          "ms-python.python": "2024.12.2",
          "ms-python.vscode-pylance": "2024.8.1",
          "ms-toolsai.jupyter": "2024.7.0",
          "ms-toolsai.jupyter-keymap": "1.1.2",
          "ms-toolsai.jupyter-renderers": "1.0.19",
          "ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
          "ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
          "ms-vscode-remote.remote-containers": "0.380.0",
          "ms-vscode-remote.remote-ssh": "0.112.0",
          "ms-vscode-remote.remote-ssh-edit": "0.86.0",
          "ms-vscode-remote.remote-wsl": "0.88.2",
          "ms-vscode-remote.vscode-remote-extensionpack": "0.25.0",
          "ms-vscode.azure-account": "0.12.0",
          "ms-vscode.cmake-tools": "1.18.44",
          "ms-vscode.powershell": "2024.2.2",
          "ms-vscode.remote-explorer": "0.4.3",
          "ms-vscode.remote-server": "1.5.2",
          "ms-vscode.vscode-serial-monitor": "0.12.0",
          "ms-vsts.team": "1.161.1",
          "msazurermtools.azurerm-vscode-tools": "0.15.12",
          "msjsdiag.debugger-for-edge": "1.0.15",
          "plorefice.devicetree": "0.1.1",
          "RandomFractalsInc.vscode-data-preview": "2.3.0",
          "redhat.vscode-yaml": "1.15.0",
          "TeamsDevApp.ms-teams-vscode-extension": "5.8.1",
          "twxs.cmake": "0.0.17",
          "vsciot-vscode.azure-iot-toolkit": "2.17.1",
          "vsciot-vscode.vscode-dtdl": "1.4.1",
          "yocto-project.yocto-bitbake": "2.6.0",
          "ZainChen.json": "2.0.2"
    To confirm the issue, could you please try building and flashing via West? Additionally, try installing the SDK and Toolchain via nRF Connect for Desktop. Follow the steps mentioned here. Let me know the results, and I will report this issue internally.
    Kind Regards,
    Abhijith
