So to quickly summarize my issue, I am trying to implement the LIS3DH accelerometer. Even though it builds and flashes I am not able to send data like I can with the simulated sensor. I'm hoping someone can tell me if I am setting up the configuration wrong or if the method I use to implement it can be improved.
This is the documentation I have been reading and trying to follow so far. I have modified the 3 things. The Kconfig file named "prj.conf", the device tree overall named "app.overlay", and a sensor config file named "sensor_manager_def.h". Here are pictures of the changes I made:
Kconfig:
Device Tree
Sensor Config:
After I build and flash this code I see that the LED 1(application state) blinks showing it's not sending data. For the code with the simulated sensor, I would press and hold button 1 to switch modes, but I find that the inputs are not received. This causes the device to eventually go into sleep mode like it is designed. The rest of the code I don't have screenshots for should be the same as the base example code built for the "nrf5340dk_nrf5340_cpuapp", but please let me know if you'd like screenshots of anything to help me better.
