Bluetooth: Mesh Light example connection problem
Dear support team:
Problem description:
Use \v2.7.0\nrf\samples\bluetooth\mesh\light routines to download to nRF52840-DK board, after adding it with nRF Mesh app (Android), Models is displayed as 0, and app cannot obtain Elements; try to set app keys to empty, after adding the device, Elements can be displayed, but Generic On Off cannot be controlled by app. Preliminary judgment is that app keys cannot be added normally
Hardware information: nRF52840-DK development board
Software information: nRF connect SDK version: v2.7.0, nRF Mesh app version: 3.3.0, IDE: VS Code
Reproduction steps:
1, Firmware generation command: west build -b nrf52840dk_nrf52840 -p -- -DSB_CONF_FILE="sysbuild-dfu.conf" -DEXTRA_CONF_FILE="overlay-dfu.conf"
2. Use west flash to download to nRF52840-DK board
3. Use nRF Mesh app to add
Best regards
  • Hi joe_su,
    You can just create an App Key from in the last tab and assign it to the node.
    Hieu
  • Hi Hieu,
    That's great. After creating the app key and adding it, I can control the device normally.
    So is the cause of this problem due to the nRF Mesh app version?
    joe_su
  • Hi joe_su,
    If that is the only thing that has been changed compared to when you last had the issue, then yes, I think so.
    It could be the issue fixed here: https://github.com/NordicSemiconductor/Android-nRF-Mesh-Library/commit/c9376ff59631d5e1e70319abab81721f37332b03.
    Hieu
  • Hi Heiu,
    OK, thank you very much for your support, I solved this problem.
    joe_su
  • Hi joe_su,
    Great, please feel free to close this case at your convenience then.
    Hieu
