Unable to connect with JTag
Hi, I'm working on custom PCB and I have small issue. After making PCB I was trying to connect, but no luck - "(unable to connect to the target)"
Maybe there is something wrong with my schema: image description
or maybe with PCB: image description
I have tested with different NRF chip, and also with different crystal.
What should I test ? How to verify that chip is working ?
  • Hei Øyvind, Thank you for your answer. I'm newbe in this subject so I will redesign PCB based on your comment and also on guidelines. I'm going to Oslo later today so I will have time there to teach myself more in this subject :)
    Unfortunately is does not answer to my problem which was about connection through SWD - and this part does not work at all. I ttried to replace NRF51 chip on working module with the one (or three) that I have but non of them seems to work so I have to order different version.
    Does this design looks more proper ? image description
    Thank you, Robert
  • Hi Oyvind, I think I made small mistake - crystal is not connected to ground. Not sure if this is the problem, I have to verify this.
    I ordered 10 NF51822 QFAC R7 on Mouser and waiting for delivery so I will move forward soon.
