Matter Template sample in SDK v2.7.0 using nrf52840dk board will not fit in the mcuboot partition
I downloaded the nRF Connect SDK v2.7.0 and read the Release Notes.  I installed the v2024.7.18 (pre-release) version of the nRF Connect for VS Code.  As a first step, I created an application by copying the Matter Template sample to my local work directory, using the command:
NRF CONNECT -> WELCOME -> Create a new application -> Copy a sample -> Matter Template
I opened an nRF Connect terminal and ran this command:
west build -b nrf52840dk/nrf52840
I got this error:
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/puzl/nrf/template_v2.7.0/build/mcuboot/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/puzl/nrf/template_v2.7.0/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/nrf52840/libsoc__nordic.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard"  -L/Users/puzl/nrf/template_v2.7.0/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /opt/nordic/ncs/v2.7.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  /opt/nordic/ncs/v2.7.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /Users/puzl/nrf/template_v2.7.0/build/mcuboot/zephyr && /opt/nordic/ncs/toolchains/f8037e9b83/Cellar/cmake/3.21.0/bin/cmake -E true
/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `text' will not fit in region `FLASH'
/opt/nordic/ncs/toolchains/f8037e9b83/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 4042 bytes
collect2: error: ld returned 1 exit status
Recognizing that the MCUBOOT was larger than the mcuboot partition that is defined in the pm_static_nrf52840dk_nrf52840.yml file (included in the sample code), I looked at other pm_static.yml files in the sample code main directory and saw that the pm_static_nrf5340dk_nrf5340_cpuapp.yml file had a larger partition for mcuboot.  So, I tried this experiment.  I did the following:
1.   cp pm_static_nrf5340dk_nrf5340_cpuapp.yml pm_static_nrf52840dk_nrf52840.yml
2.  west build -b nrf52840dk/nrf52840
3.  west flash
After flashing this code to my nrf52840 DK board, I get this error when the board boots:
*** Booting MCUboot v2.1.0-dev-daf2946a0f07 ***
*** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
I: Starting bootloader
E: Failed to open flash area ID 1 (image 0 slot 1): -2, cannot continue
What can I do to get this sample to build and run on my DK board?
Gene Roylance
PuzL Labs
