Having trouble Flashing from VSCode
I"m using VScode and nrf5340.  I often get an error like this:
[ ##########           ]   0.000s | Erasing non-volatile memory - block 1 of 1                                      Timed out waiting for progress updates.
Did worker process die?
[ #################### ]   0.000s | Erasing non-volatile memory - Erase successful                                  [ #################### ]  23.593s | Erase file - Done erasing
ERROR: An internal error has occurred, please try again.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 63: nrfjprog --program GENERATED_CP_APPLICATION_merged_domains.hex --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 852003463
If I use Ozone and the Segger tools, flash erase and download seems to always succeed. The above seems to timeout on the erase. On the segger toolchain, erase is very fast (~0.0 seconds according to the segger tools). I am using an Apple silicon Mac and wondering if the nrf tools is missing that the erase was quite fast. This pretty much stops my ability to develop using vscode and the nrf tools
support info.rtf
  • Hi
    This sounds a lot like what multiple users has seen in this ticket:  VS-CODE: build hangs: "Found GnuLd: ld.bfd..."
    Unfortunately we haven't been able to reproduce this on our end, but one temporary solution has been to downgrade to VS code v1.87.2. Since you're using Apple Silicon, please explain how you downloaded the extensions and SDK, as there might be an issue with the toolchain being incorrect. If you have any Intel based toolchains, uninstall them, and then install the Apple silicon versions that are needed directly from VS Code.
    Simon
  • For clarity, this isn't a problem building the code -- it is a problem downloading and programing the flash on the nrf
    I installed the VSCode extensions from within VSCode.
    for the nordic SDK , we have cmd line tools with our project, yaml files, etc that set up the build.
    I downgraded to 1.87.2 uninstalled all of my extensions and then installed the nrf connect (v2024.7.13) from within VSCode
    No intel based toolchains as far as I can tell -- is there a specific one that I should look for and uninstall?
    And this did not fix the problem.
  • Okay, then it doesn't seem like this is the same issue.
    Are you attempting to flash the onboard SoC on anRF5340 DK or a custom board with the nRF5340 DK as the debugger? If you're working on the latter, what voltage is the custom board running at, as the nRF5340 DK only supports flashing targets at 3V by default. Some more information it would be nice to have.
    • What sample application are you trying to flash?
    • What version of J-Link do you have installed on your computer?
    • Have you tried multiple USB cables and USB ports on your computer?
    Simon
