Undefined reference to `__device_dts_ord_18' for adxl362
I am currently working on a custom project that requires the integration of the ADXL-362 accelerometer. The project involves a system with a radar sensor connected to custom pins configured for SPI2 communication.
Initially, I attempted to connect the ADXL-362 directly to SPI2, but this caused conflicts with the radar sensor, resulting in errors. Subsequently, I assigned the ADXL-362 to custom pins. This adjustment allowed the system to build and flash successfully. However, during integrated system testing, i encountered an issue: the system fails to read data from the ADXL-362 sensor.
The sensor has been defined in the code as follows:
#define ACCELEROMETER_SPI_NODE             DT_ALIAS(adxl362) /**< SPI sensor node */
Calling it like this:
static const struct device *accelerometer_spi_device = DEVICE_DT_GET(ACCELEROMETER_SPI_NODE); /**< SPI device for communication */
And this gives me the undefined Reference.
When i use:
static const struct device *accelerometer_spi_device = DEVICE_DT_GET_ANY(ACCELEROMETER_SPI_NODE); /**< SPI device for communication */
The system cant find the sensor and gives me a NULL pointer back.
Here is my prj.conf:
CONFIG_MAIN_STACK_SIZE=6144
CONFIG_HEAP_MEM_POOL_SIZE=8192
# General config
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_REBOOT=y
# NEWLIB C
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_LTE_NETWORK_USE_FALLBACK=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_NETWORK_TIMEOUT=20
CONFIG_LTE_PSM_REQ_RAT="00000010"
CONFIG_LTE_PSM_REQ_RPTAU="00110000"
# Modem library
CONFIG_NRF_MODEM_LIB=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# AWS IoT library
CONFIG_AWS_IOT=y
#IMPORTANT: If building for firmware update, this must be set to y
CONFIG_AWS_IOT_CLIENT_ID_APP=y
CONFIG_AWS_IOT_CLIENT_ID_MAX_LEN=15
#If building for firmware update, this is ignored
CONFIG_AWS_IOT_CLIENT_ID_STATIC=""
CONFIG_AWS_IOT_BROKER_HOST_NAME="HOSTNAME"
CONFIG_AWS_IOT_SEC_TAG=1
CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=1
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=n
CONFIG_AWS_IOT_LAST_WILL=n
CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
CONFIG_AWS_FOTA_PAYLOAD_SIZE=1350
CONFIG_AWS_FOTA_HOSTNAME_MAX_LEN=255
CONFIG_AWS_FOTA_FILE_PATH_MAX_LEN=255
CONFIG_AWS_IOT_LOG_LEVEL_DBG=n
CONFIG_MQTT_CLEAN_SESSION=y
# NRF Cloud
CONFIG_NRF_CLOUD_AGPS=y
CONFIG_NRF_CLOUD_LOG_LEVEL_DBG=n
#AWS shadow
CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=n
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMG_MANAGER=y
# Image manager
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# AWS FOTA
CONFIG_FOTA_DOWNLOAD=y
CONFIG_AWS_FOTA=y
CONFIG_DFU_TARGET=y
# Download client (needed by AWS FOTA)
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core = 1200
CONFIG_MQTT_KEEPALIVE=1200
# Date Time library
CONFIG_DATE_TIME=y
# Modem information
CONFIG_MODEM_INFO=y
# CJSON
CONFIG_CJSON_LIB=y
# Peripherals
CONFIG_I2C=y
CONFIG_SPI=y
CONFIG_FPU=n
CONFIG_NRFX_SPIM2=y
CONFIG_NRFX_TWIM3=y
# Power management
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
# Logging
CONFIG_LOG=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=n
# Fault handling
CONFIG_RESET_ON_FATAL_ERROR=y
# Heap
CONFIG_SYS_HEAP_RUNTIME_STATS=n
# ADC
CONFIG_ADC=y
# Watchdog
CONFIG_WATCHDOG=y
# Enable Sensor
CONFIG_SENSOR=y
# Enable ADXL362 Accelerometer Sensor
CONFIG_ADXL362=y
Vs-Code tells me the following:
CONFIG_ADXL362 was assigned the value y, but got the value n. Missing dependencies:
DT_HAS_ADI_ADXL362_ENABLED
How to add the missing dependencies?
Here is my sensor_ovelay for reference:
#include "sensor1_ns.dtsi"
    zephyr,user {
        io-channels = <&adc 0>;
    vbatt {
        io-channels = <&adc 1>;
    custom_pins {
        adxl362: adxl362 {
            gpios = <&gpio0 15 0>;
            label = "ADXL362_spi_ss";
    aliases {
        eeprom-i2c = &i2c3;
        temperature-i2c = &i2c3;
        rtc-i2c = &i2c3;
        adxl362 = &adxl362;
&spi2 {
    status = "okay";
    pinctrl-0 = <&spi2_default>;
    pinctrl-1 = <&spi2_sleep>;
    clock-frequency = <1000000>;
    label = "SPI_2_1";
&spi2_default {
    group1 {
        psels = <NRF_PSEL(SPIM_SCK, 0, 23)>,
                <NRF_PSEL(SPIM_MOSI, 0, 20)>,
                <NRF_PSEL(SPIM_MISO, 0, 22)>;
&spi2_sleep {
    group1 {
&i2c3 {
    status = "okay";
    pinctrl-0 = <&i2c3_default>;
    pinctrl-1 = <&i2c3_sleep>;
    clock-frequency = <I2C_BITRATE_FAST>;
    label = "I2C_3_1";
&gpio0 {
    status = "okay";
    label = "GPIO_0";
&adc {
    #address-cells = <1>;
    #size-cells = <0>;
    channel@0 {
        reg = <0>;
        zephyr,gain = "ADC_GAIN_1_6";
        zephyr,reference = "ADC_REF_INTERNAL";
        zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 40)>;
        zephyr,input-positive = <NRF_SAADC_AIN1>;
        zephyr,resolution = <10>;
        zephyr,oversampling = <16>;
  • Thanks for your Reply.
    Yes you where right i did not include the node on the spi bus. But when i do that the radar stops working.
  • It is a Acconeer A121 Radar Sensor.
    https://www.acconeer.com/products/
    This sensor is not standart on the Nrf9160 board
  • Ah, so it's on the same SPI2-bus, and you're not using a Zephyr driver (something you'd need to code yourself), rather the SPI directly.
    I don't have any experience in using a mix of Zephyr drivers and direct SPI implementation, but I'd go with using the ADXL-362 drivers and fix the A121 implementation, either by converting it into a Zephyr driver, or by using debugging tools to find out more about why it fails when the ADXL driver is enabled.
  • Yes they run booth on the same SPI-bus. No the radar driver is entilery self coded. BUt i dont think there is something wrong with it. Because the system is already in production. I just need to add the ADXL Sensor. But ill look into your suggestion.
  • There might be nothing wrong with your implementation on its own, but clearly something isn't compatible with the Zephyr drivers. For example, mutexes, enabling/disabling the bus, CPOL & CPHA settings etc.
    Try enabling SPI debug log for starters and see if any errors emerge:
    CONFIG_SPI_LOG_LEVEL_DBG=y
  • This is the output i get with SPI log when the adxl sensor in added to SPI-bus:
    �mۿm�+_�{�}��__�_?}YD: tx_bufs 0x2002cac8 - rx_bufs (nil) - 1
    D: current_tx 0x2002cad8 (2), current_rx (nil) (0), tx buf/len 0x2002cac4/2, rx buf/len (nil)/0
    E: Timeout waiting for transfer complete
    E: adxl362_software_reset failed, error -116
    *** Booting Zephyr OS build v3.1.99-ncs1  ***
    (706)[INFO] Starting sensor1
    D: tx buf/len (nil)/140148
    D: tx buf/len (nil)/131957
    D: tx buf/len (nil)/123766
    D: tx buf/len (nil)/115575
    D: tx buf/len (nil)/107384
    D: tx buf/len (nil)/99193
    D: tx buf/len (nil)/91002
    D: tx buf/len (nil)/82811
    D: tx buf/len (nil)/74620
    D: tx buf/len (nil)/66429
    D: tx buf/len (nil)/58238
    D: tx buf/len (nil)/50047
    D: tx buf/len (nil)/41856
    D: tx buf/len (nil)/33665
    D: tx buf/len (nil)/25474
    D: tx buf/len (nil)/17283
    D: tx buf/len (nil)/9092
    D: tx buf/len (nil)/901
    D: tx buf/len (nil)/0
    D: Transaction finished with status 0
    Initializing system check
    SYSTEM FIRMWARE VERSION: 1.1.43
    SYSTEM HARDWARE VERSION: 2
    EEPROM status: OK
    D: tx_bufs 0x2002c9f8 - rx_bufs 0x2002c9f8 - 1
    D: current_tx 0x2002c9f0 (1), current_rx 0x2002c9f0 (1), tx buf/len 0x2002ca30/6, rx buf/len 0x2002ca30/6
    D: rx buf/len (nil)/0
    D: tx_bufs 0x2002ca08 - rx_bufs 0x2002ca08 - 1
    D: current_tx 0x2002ca00 (1), current_rx 0x2002ca00 (1), tx buf/len 0x2002ca40/6, rx buf/len 0x2002ca40/6
    Radar status: failed, 13
    System check: failed
    (1894)[DEBUG] Current time: 0
    (1897)[INFO] Powering down system
    (2701)[ERROR] Error in main loop
    Radar status failed 13 means Error creating Sensor.
    An
    -ߍmۿm]/�{���]_�}_�}Yw�O_*** Booting Zephyr OS build v3.1.99-ncs1  ***
    (486)[INFO] Starting sensor1
    EEPROM status: OK
    D: tx_bufs 0x2002c9e8 - rx_bufs 0x2002c9e8 - 1
    D: current_tx 0x2002c9e0 (1), current_rx 0x2002c9e0 (1), tx buf/len 0x2002ca20/6, rx buf/len 0x2002ca20/6
    D: tx_bufs 0x2002c950 - rx_bufs 0x2002c950 - 1
    D: current_tx 0x2002c948 (1), current_rx 0x2002c948 (1), tx buf/len 0x2002c988/6, rx buf/len 0x2002c988/6
    D: tx_bufs 0x2002c928 - rx_bufs 0x2002c928 - 1
    D: current_tx 0x2002c920 (1), current_rx 0x2002c920 (1), tx buf/len 0x2002c960/6, rx buf/len 0x2002c960/6
    D: tx_bufs 0x2002c938 - rx_bufs 0x2002c938 - 1
    D: current_tx 0x2002c930 (1), current_rx 0x2002c930 (1), tx buf/len 0x2002c97c/4, rx buf/len 0x2002c97c/4
    D: tx_bufs 0x2002c960 - rx_bufs 0x2002c960 - 1
    D: current_tx 0x2002c958 (1), current_rx 0x2002c958 (1), tx buf/len 0x20025c6f/4096, rx buf/len 0x20025c6f/4096
    D: current_tx 0x2002c958 (1), current_rx 0x2002c958 (1), tx buf/len 0x20025c6f/1744, rx buf/len 0x20025c6f/1744
    D: tx_bufs 0x2002c948 - rx_bufs 0x2002c948 - 1
    D: current_tx 0x2002c940 (1), current_rx 0x2002c940 (1), tx buf/len 0x2002c980/6, rx buf/len 0x2002c980/6
    D: current_tx 0x2002c958 (1), current_rx 0x2002c958 (1), tx buf/len 0x2002c99c/4, rx buf/len 0x2002c99c/4
    D: tx_bufs 0x2002c968 - rx_bufs 0x2002c968 - 1
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x2002c9a0/6, rx buf/len 0x2002c9a0/6
    D: tx_bufs 0x2002c970 - rx_bufs 0x2002c970 - 1
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x2002c9a8/6, rx buf/len 0x2002c9a8/6
    D: tx_bufs 0x2002c978 - rx_bufs 0x2002c978 - 1
    D: current_tx 0x2002c970 (1), current_rx 0x2002c970 (1), tx buf/len 0x2002c9b0/6, rx buf/len 0x2002c9b0/6
    D: tx_bufs 0x2002c990 - rx_bufs 0x2002c990 - 1
    D: current_tx 0x2002c988 (1), current_rx 0x2002c988 (1), tx buf/len 0x2002c9cc/4, rx buf/len 0x2002c9cc/4
    D: tx_bufs 0x2002c998 - rx_bufs 0x2002c998 - 1
    D: current_tx 0x2002c990 (1), current_rx 0x2002c990 (1), tx buf/len 0x2002c9d0/6, rx buf/len 0x2002c9d0/6
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x20025c6f/44, rx buf/len 0x20025c6f/44
    D: tx_bufs 0x2002c940 - rx_bufs 0x2002c940 - 1
    D: current_tx 0x2002c938 (1), current_rx 0x2002c938 (1), tx buf/len 0x2002c97c/10, rx buf/len 0x2002c97c/10
    D: current_tx 0x2002c940 (1), current_rx 0x2002c940 (1), tx buf/len 0x2002c988/8, rx buf/len 0x2002c988/8
    D: tx_bufs 0x2002c980 - rx_bufs 0x2002c980 - 1
    D: current_tx 0x2002c978 (1), current_rx 0x2002c978 (1), tx buf/len 0x2002c9bc/4, rx buf/len 0x2002c9bc/4
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/40, rx buf/len 0x20025c6f/40
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x20025c6f/138, rx buf/len 0x20025c6f/138
    D: tx_bufs 0x2002c988 - rx_bufs 0x2002c988 - 1
    D: current_tx 0x2002c980 (1), current_rx 0x2002c980 (1), tx buf/len 0x20025c6f/6, rx buf/len 0x20025c6f/6
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/72, rx buf/len 0x20025c6f/72
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/136, rx buf/len 0x20025c6f/136
    D: current_tx 0x2002c980 (1), current_rx 0x2002c980 (1), tx buf/len 0x20025c6f/196, rx buf/len 0x20025c6f/196
    D: current_tx 0x2002c920 (1), current_rx 0x2002c920 (1), tx buf/len 0x2002c964/10, rx buf/len 0x2002c964/10
    D: tx_bufs 0x2002c930 - rx_bufs 0x2002c930 - 1
    D: current_tx 0x2002c928 (1), current_rx 0x2002c928 (1), tx buf/len 0x2002c970/8, rx buf/len 0x2002c970/8
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x2002c9a4/4, rx buf/len 0x2002c9a4/4
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/1544, rx buf/len 0x20025c6f/1544
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x20025c6f/40, rx buf/len 0x20025c6f/40
    D: current_tx 0x2002c928 (1), current_rx 0x2002c928 (1), tx buf/len 0x2002c96c/10, rx buf/len 0x2002c96c/10
    D: current_tx 0x2002c930 (1), current_rx 0x2002c930 (1), tx buf/len 0x2002c978/8, rx buf/len 0x2002c978/8
    D: tx_bufs 0x2002c958 - rx_bufs 0x2002c958 - 1
    D: current_tx 0x2002c950 (1), current_rx 0x2002c950 (1), tx buf/len 0x2002c990/6, rx buf/len 0x2002c990/6
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x2002c9ac/4, rx buf/len 0x2002c9ac/4
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/200, rx buf/len 0x20025c6f/200
    D: current_tx 0x2002c960 (1), current_rx 0x2002c960 (1), tx buf/len 0x20025c6f/1544, rx buf/len 0x20025c6f/1544
    D: current_tx 0x2002c968 (1), current_rx 0x2002c968 (1), tx buf/len 0x20025c6f/3464, rx buf/len 0x20025c6f/3464
    Radar status: OK
    Temperature status: OK
    SIM status: OK
    Battery voltage: 3594
    (6784)[ERROR] Could not find a DT node for the accelerometer
    (6790)[ERROR] Accelerometer device not ready
    (6794)[ERROR] ADXL362 set filter control failed
    (6798)[ERROR] ADXL362 set activity threshold failed
    (6803)[ERROR] Accelerometer configuration failed
    Accelerometer status: failed, 2
    (6817)[DEBUG] Current time: 0
    (6820)[INFO] Powering down system
    (7624)[ERROR] Error in main loop
    d this is the log when the ADXL Sensor is not in the SPI-bus:
    EEPROM status: OK
    An
    EEPROM status: OK
    Radar status: OK
    SIM status: OK
