Hello, I am trying to upload my custom firmware to the MetaWear RG (nrf51822) platform but currently without luck. Steps that I have performed:
- Connected to the device using the debug out of the nRF51DK as described here
- Uploaded Softdevice S130
- Uploaded custom application
Now, uploading seems to be working fine, but the application/mcu doesn't seem to start/work. I believe the problem lies in not correctly configuring the application to use the 32MHz external crystal, which the MetaWear uses.
To try to achieve that:
Step 1
it is being suggested to write the value 0xFFFFFF00 to the UICR (User Information Configuration Register) at address 0x10001008 (XTALFREQ).
# After softdevice upload and when the UICR can be written to
# Using nrfprog.exe (not tested, but should work)
nrfjprog.exe --snr <your_jlink_debugger_serial_number> --memwr 0x10001008 --val 0xFFFFFF00
# Using jlink (my method)
w4 0x10001008 0xFFFFFF00
I can verify that address 0x10001008 has been written to correctly.
Step 2
I edited the nrf_drv_config.h to use NRF_CLOCK_XTALFREQ_32MHz.
Step 3 (Edit 1)
based on this I changed the definition at the top of the system.nrf51.c file to
#define __SYSTEM_CLOCK (32000000UL)
and I also explicitly enabled the use of the external 32MHz crystal in the application code like:
// Set the external high frequency clock source to 32 MHz
NRF_CLOCK->XTALFREQ = 0xFFFFFF00;
// Start the external high frequency crystal
// Wait for the external oscillator to start up
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0) {}
while (true) {
// run application
Using nRF51_SDK_9.0.0_2e23562
Any clues? Has anyone successfully managed to run custom code in the metawear?
Any help appreciated! Thanks!
