matter lock sample failed to boot (E: GetEnableKey() failed [Error: 160])
Hi Nordic Team,
I am using SDK 2.7.0 & board: nrf52840-dk for matter lock application and facing below issue when boot device.
I want to create factory data manually using guide: Configuring factory data for the nRF Connect examples (nordicsemi.com)
Changes made in SDK V2.7.0 Matter lock sample:
in sysbuild.conf => Added New => SB_CONFIG_MATTER_FACTORY_DATA_GENERATE=n
In prj.conf => CONFIG_CHIP_FACTORY_DATA_BUILD=y =>  # CONFIG_CHIP_FACTORY_DATA_BUILD=y
Generate Factory data using the below script:
generate_nrfconnect_chip_factory_data.py --sn 1234567890ABCDEF --date 2024-08-01 --vendor_id 65521 --product_id 32774 --vendor_name "Nordic Semiconductor ASA" --product_name not-specified --hw_ver 0 --hw_ver_str prerelease --dac_cert D:/nRF_SDK/v2.7.0/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8006-Cert.der --dac_key D:/nRF_SDK/v2.7.0/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8006-Key.der --pai_cert D:/nRF_SDK/v2.7.0/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.der --spake2_it 1000 --spake2_salt U1BBS0UyUCBLZXkgU2FsdA== --discriminator 0xF00 --passcode 20202021 --include_passcode --overwrite --product_finish other --generate_onboarding -o D:/nRF_SDK/v2.7.0/nrf/samples/matter/lock/build/lock/zephyr/factory_data -s D:/nRF_SDK/v2.7.0/modules/lib/matter/scripts/tools/nrfconnect/nrfconnect_factory_data.schema --offset 0xf7000 --size 0x1000
After uploading merged.hex and factory_data.hex, got below out on uart terminal.
UART Log:
21:22:51.591> uart:~$ *** Booting My Application v2.7.0-5cb85570ca43 ***
21:22:51.591> *** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
21:22:51.591> *** Using Zephyr OS v3.6.99-100befc70c74 ***
21:22:51.591> I: 31 [DL]BLE address: D4:0B:37:B0:27:5B
21:22:51.591> I: No users indexes stored
21:22:51.591> I: No stored indexes for credential of type: 1
21:22:51.591> I: 47 [DL]CHIP task running
21:22:51.591> I: Init CHIP stack
21:22:51.591> I: 52 [DL]OpenThread started: OK
21:22:51.673> I: 55 [DL]Setting OpenThread device type to SLEEPY END DEVICE
21:22:51.673> I: 62 [DL]Found DAC Private Key in factory data set. Copying to secure storage...
21:22:51.673> E: GetEnableKey() failed [Error: 160]
21:22:51.673> E: Exited with code a0
Himansu Donga
