LIS2DH Accelerometer not initializing with nRF5340 DK
Hi, I'm trying to read data from an LIS2DH accelerometer using the nRF5340 DK board. I have been able to build and flash my code to the board, but the terminal outputs, "Device not ready", indicating that the sensor was not initialized properly. The code I am using (shown below) should work as it is based off the sample LIS2DH application. I was wondering if someone could help explain why the sensor is not initializing properly. Thank you!
main:
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
static void fetch_and_display(const struct device *sensor)
	static unsigned int count;
	struct sensor_value accel[3];
	const char *overrun = "";
	int rc = sensor_sample_fetch(sensor);
	++count;
	if (rc == -EBADMSG) {
		/* Sample overrun.  Ignore in polled mode. */
		if (IS_ENABLED(CONFIG_LIS2DH_TRIGGER)) {
			overrun = "[OVERRUN] ";
		rc = 0;
	if (rc == 0) {
		rc = sensor_channel_get(sensor,
					SENSOR_CHAN_ACCEL_XYZ,
					accel);
	if (rc < 0) {
		printf("ERROR: Update failed: %d\n", rc);
	} else {
		printf("#%u @ %u ms: %sx %f , y %f , z %f",
		       count, k_uptime_get_32(), overrun,
		       sensor_value_to_double(&accel[0]),
		       sensor_value_to_double(&accel[1]),
		       sensor_value_to_double(&accel[2]));
	const struct device *const sensor = DEVICE_DT_GET_ANY(st_lis2dh);
	if (sensor == NULL) {
		printf("No device found\n");
		return 0;
	if (!device_is_ready(sensor)) {
		printf("Device %s is not ready\n", sensor->name);
		return 0;
	printf("Polling at 0.5 Hz\n");
	while (true) {
		fetch_and_display(sensor);
		k_sleep(K_MSEC(2000));
Overlay file:
prj.conf:
    I wanted to let you know that I have been assigned to this case. I have reviewed the inputs provided by the community, and they appear to be good and relevant. If you are still encountering issues, please let me know, and I will be happy to look into it further.
    Abhijith
    roddyb said:
    I was able to run a basic SDK sample without any issues. However, I am still having some trouble reading data from the sensor. Do you know what the issue could be?
    Sorry, I accidentally deleted one of your replies. Could you explain the issue a little more or provide the current status of your development? If there are any error logs or error messages, please share them as they will help in diagnosing the issue.
    Abhijith
  • No worries! I am trying to read data from an LIS2DH accelerometer using the nRF5340 DK board. I was using to given LIS2DH application as a starting point. However, when I try to run the application the code outputs the message "Device not ready" indicating the sensor was not initialized properly in the code. Here is my code including the changes I made thanks to the previous replies by the community:
    main:
    #include <stdio.h>
    	struct sensor_value temperature;
    	++count;
    		rc = 0;
    	if (rc == 0) {
    					accel);
    	if (rc < 0) {
    	} else {
    	if (IS_ENABLED(CONFIG_LIS2DH_MEASURE_TEMPERATURE)) {
    		if (rc == 0) {
    			rc = sensor_channel_get(sensor, SENSOR_CHAN_DIE_TEMP, &temperature);
    			if (rc < 0) {
    				printf("\nERROR: Unable to read temperature:%d\n", rc);
    			} else {
    				printf(", t %f\n", sensor_value_to_double(&temperature));
    	} else {
    		printf("\n");
    #ifdef CONFIG_LIS2DH_TRIGGER
    static void trigger_handler(const struct device *dev,
    			    const struct sensor_trigger *trig)
    	fetch_and_display(dev);
    	printf("Hello world!\n");
    	const struct device *sensor = DEVICE_DT_GET_ANY(st_lis2dh);
    		return 0;
    		return 0;
    #if CONFIG_LIS2DH_TRIGGER
    		struct sensor_trigger trig;
    		int rc;
    		trig.type = SENSOR_TRIG_DATA_READY;
    		trig.chan = SENSOR_CHAN_ACCEL_XYZ;
    		if (IS_ENABLED(CONFIG_LIS2DH_ODR_RUNTIME)) {
    			struct sensor_value odr = {
    				.val1 = 1,
    			rc = sensor_attr_set(sensor, trig.chan,
    					     SENSOR_ATTR_SAMPLING_FREQUENCY,
    					     &odr);
    			if (rc != 0) {
    				printf("Failed to set odr: %d\n", rc);
    				return 0;
    			printf("Sampling at %u Hz\n", odr.val1);
    		rc = sensor_trigger_set(sensor, &trig, trigger_handler);
    		if (rc != 0) {
    			printf("Failed to set trigger: %d\n", rc);
    			return 0;
    		printf("Waiting for triggers\n");
    		while (true) {
    #else /* CONFIG_LIS2DH_TRIGGER */
    	while (true) {
    #endif /* CONFIG_LIS2DH_TRIGGER */
    nrf5340dk_nrf5340_cpuapp.overlay:
    &pinctrl {
    	uart0_default: uart0_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 0, 20)>,
    				<NRF_PSEL(UART_RX, 0, 22)>;
    	uart0_sleep: uart0_sleep {
    		group1 {
    			low-power-enable;
    	i2c2_default: i2c2_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 0, 8)>,
    				<NRF_PSEL(TWIM_SCL, 0, 7)>;
    	i2c2_sleep: i2c2_sleep {
    		group1 {
    			low-power-enable;
    	pwm0_default: pwm0_default {
    		group1 {
    			psels = <NRF_PSEL(PWM_OUT0, 0, 25)>;
    	pwm0_sleep: pwm0_sleep {
    		group1 {
    			low-power-enable;
    	spi3_default: spi3_default {
    		group1 {
    			psels = <NRF_PSEL(SPIM_SCK, 0, 19)>,
    				<NRF_PSEL(SPIM_MISO, 0, 20)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 21)>;
    	spi3_sleep: spi3_sleep {
    		group1 {
    			low-power-enable;
    nrf5340dk_nrf5340_cpuapp.dts:
     * Copyright (c) 2020 Nordic Semiconductor ASA
    /dts-v1/;
    #include <nordic/nrf5340_cpuapp_qkaa.dtsi>
    #include "nrf5340_cpuapp_common.dtsi"
    	model = "Nordic NRF5340 DK NRF5340 Application";
    	compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
    	chosen {
    		zephyr,sram = &sram0_image;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,sram-secure-partition = &sram0_s;
    		zephyr,sram-non-secure-partition = &sram0_ns;
    &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    	pinctrl-0 = <&uart0_default>;
    	pinctrl-1 = <&uart0_sleep>;
    &i2c2 {
    	status = "okay";
    	pinctrl-0 = <&i2c2_default>;
    	pinctrl-1 = <&i2c2_sleep>;
    	clock-frequency = <I2C_BITRATE_FAST>;
    	pmic_main: npm1300@6b {
    		compatible = "nordic,npm1300";
    		reg = <0x6b>;
    		pmic_charger: charger {
    			compatible = "nordic,npm1300-charger";
    			term-microvolt = <4150000>;
    			term-warm-microvolt = <4000000>;
    			current-microamp = <150000>;
    			dischg-limit-microamp = <1000000>;
    			vbus-limit-microamp = <500000>;
    			thermistor-ohms = <10000>;
    			thermistor-beta = <3380>;
    			charging-enable;
    		regulators {
    			compatible = "nordic,npm1300-regulator";
    			BUCK1 {
    				regulator-min-microvolt = <1800000>;
    				regulator-max-microvolt = <1800000>;
    				regulator-boot-on;
    			BUCK2 {
    				regulator-min-microvolt = <3300000>;
    				regulator-max-microvolt = <3300000>;
    				regulator-boot-on;
    	lis2dh: lis2dh@18 {
    		compatible = "st,lis2dh";
    		reg = <0x18>;
    		irq-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
    		disconnect-sdo-sa0-pull-up;
    	eeprom0: eeprom@50 {
    		/* 24CW160 (16 kbit eeprom) */
    		/* 0x8000 config register not accessible! If required, set size to 64K */
    		compatible = "atmel,at24";
    		reg = <0x50>;
    		size = <DT_SIZE_K(2)>;
    		pagesize = <32>;
    		address-width = <16>;
    		timeout = <5>;
    &pwm0 {
    	status = "okay";
    	pinctrl-0 = <&pwm0_default>;
    	pinctrl-1 = <&pwm0_sleep>;
    prj.conf:
    CONFIG_STDOUT_CONSOLE=y
    # Adding I2C
    CONFIG_I2C=y
    # Add the accelerometer
    CONFIG_SENSOR=y
    CONFIG_LIS2DH=y
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # newlibc for printing floats
    CONFIG_NEWLIB_LIBC=y
    CONFIG_SERIAL=y
    The error message suggests that the sensor device specified in your code isn’t properly initialized or detected. Please ensure that the I2C bus (i2c2) is enabled and configured correctly. Verify that the pinctrl settings are appropriate for your hardware setup. Confirm that your sensor is connected to the I2C2 bus with the address 0x18, and double-check the wiring and connections.
    Please review this guide and ensure that you have followed all the steps mentioned.
    Abhijith
  • Thank you for the reply! I have double checked that the I2C bus is enabled and configured. As far as I am aware the pinctrl settings are appropriate for my board. I can also confirm that the sensor connected to the I2C bus with the address 0x18, and the wiring is correct: VCC ->, GND -> GND, SDA -> P0.08, SCL -> 0.07. I spent some time working through the guide you sent, but I found that I already had most of the information they asked to include. Do  you think I could be missing something in the overlay file or in the devicetree that would stop the sensor from initializing?
    Roddy
