Is there examples of paring,bonding and whitelisting?
The pairing and bonding mode is static password.
It is best to have examples of the central and the peripheral.
Thank you.
Thank you.
I want to know why I finish executing this command in the central, the peripheral didn't call the command " case PM_EVT_PEERS_DELETE_SUCCEEDED:".
////////////Added for bonding//////////////
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void) // -Shy
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds");
err_code = sd_ble_gap_disconnect(0x0000,BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
err_code = pm_peers_delete();
Or in what state can I call the delete_bonds()?
Thank you.
Did pm_peers_delete return NRF_SUCCESS? If so, you should subsequently get either a PM_EVT_PEERS_DELETE_SUCCEEDED or a PM_EVT_PEERS_DELETE_FAILED even tin your peer manager event handler. I see you currently do not check for PM_EVT_PEERS_DELETE_FAILED, so I suggest startign with checking if you get that event.
I have used the pm_evt_handler. When I finish executing the delete_bonds(), I get the PM_EVT_PEERS_DELETE_SUCCEEDED in the central. But the peripheral not. I guess the central
and the peripheral connect after executing the delete_bonds().
This is the debugging information of the peripheral.
It consists of two processes. One is to connect, pair and bond.
The Other is to delete the bonds.
00> <info> app_timer: RTC: initialized.
00>
00> <info> app: Transmit power set successfully.
00>
00> <info> app: Debug logging for UART over RTT started.
00>
00> <info> app: on_adv_evt
00>
00> <debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
00>
00> <debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
00>
00> <info> app: Connected
00>
00> <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 247 bytes.
00>
00> <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 247) on connection 0x0.
00>
00> <info> app: Received BLE_GAP_EVT_AUTH_KEY_REQUEST, waiting for key_flag
00>
00> <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
00>
00> <debug> nrf_ble_gatt: max_rx_octets: 27
00>
00> <debug> nrf_ble_gatt: max_tx_octets: 27
00>
00> <debug> nrf_ble_gatt: max_rx_time: 328
00>
00> <debug> nrf_ble_gatt: max_tx_time: 328
00>
00> <debug> app: ATT MTU exchange completed. central 0xF7 peripheral 0xF7
00>
00> <debug> nrf_ble_gatt: ATT MTU updated to 247 bytes on connection 0x0 (response).
00>
00> <info> app: Data len is set to 0xF4(244)
00>
00>
00> <info> app: notification enabled, val=0x0001
00>
00> <info> app: four_key_val == 0x0F
00>
00> <info> app: sd_ble_gap_auth_key_reply
00>
00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
00>
00>
00> <info> app: Disconnected, reason: 0x13
00>
00> <info> app: Disconnected by remote user.
00>
00>
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
00> <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 133
00>
00>
pm_evt_handler() is a local operation. To delete the bond on the peripheral side you need to call it there as well.
I call pm_evt_handler() on the peripheral side.
But it doesn't respond.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
NRF_LOG_INFO("PM_EVT_PEERS_DELETE_SUCCEEDED");
// ret_code_t err_code = sd_ble_gap_disconnect(0x0000, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
advertising_start();
case PM_EVT_PEERS_DELETE_FAILED:
NRF_LOG_INFO("PM_EVT_PEERS_DELETE_FAILED");
Or do you mean i need to call the delete_bonds() on the peripheral side?
I find before deleting the bonds, I should disable scanning and advertising.
How can I implement this function?
