Is there examples of paring,bonding and whitelisting?
The pairing and bonding mode is static password.
It is best to have examples of the central and the peripheral.
Thank you.
Thank you.
There are many examples in the SDK shat support pairing and bonding. You can refer to the Central UART and Peripheral UART samples.
Whitelisting is called filter accept list in Zephyr, and you can see an example of that in the Peripheral Accept List sample. It is also covered in exersise 2 in lesson 5 in the Bluetooth Low Energy Fundamentals course.
Regarding static passkey I want to stress that it can be very easily brute forced, so it does not provide any security compared to just works. But it can sometimes be convenient none the less. If you still want to use it, you can refer to this post.
Can you help me see why other devices can still be connected after setting the whitelist?
I whitelisted on the central side because I entered the password on the peripheral side.
Here is the central code. Please ignore the comments.
* Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
// shy - btn
#include "ble_btn_c.h"
// shy - btn
///////////Added for bonding//////////
#include "peer_manager.h"
#include "peer_manager_handler.h"
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Enable MITM protection */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display Only. */ // -Shy
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
//////////////Added for bonding///////
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
// shy - btn
BLE_BTN_C_DEF(m_ble_btn_c);
// shy - btn
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
///**@brief NUS UUID. */
//static ble_uuid_t const m_nus_uuid =
// .uuid = BLE_UUID_NUS_SERVICE,
// .type = NUS_SERVICE_UUID_TYPE
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY "123456"
// static ble_opt_t m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
// shy - scan
static char const m_target_periph_name[] = "Nordic_UART";
// ?¨ò?é¨?è2?êy
static ble_gap_scan_params_t m_scan_params =
.active = 1, // 1?a?÷?ˉé¨?è£??é??μ?1?2¥êy?Y?°é¨?è??μ÷êy?Y
.interval_us = 10000, // é¨?è????£o160*0.625 = 100ms
.window_us = 5000, // é¨?è′°?ú£o80*0.625 = 50ms
.timeout = NRF_BLE_SCAN_SCAN_DURATION, // é¨?è3?D?μ?ê±??£oéè???a0£?ò??±é¨?è£??±μ??÷è·μ?í£?1é¨?è
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL, // é¨?è?ùóDBLEéè±?£?2?×??T??
.scan_phys = BLE_GAP_PHY_1MBPS, // é¨?è1MBPSμ?PHY
static ble_gap_conn_params_t m_conn_params =
.min_conn_interval = MSEC_TO_UNITS(NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL, UNIT_1_25_MS), // ×?D?á??ó????7.5ms
.max_conn_interval = MSEC_TO_UNITS(NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL, UNIT_1_25_MS), // ×?′óá??ó????30ms
.slave_latency = NRF_BLE_SCAN_SLAVE_LATENCY, // òt2??ü?ú0
.conn_sup_timeout = MSEC_TO_UNITS(NRF_BLE_SCAN_SUPERVISION_TIMEOUT, UNIT_10_MS), // 3?ê±ê±??4000ms
// shy - scan
// shy - btn
// shy - btn
////////////Added for bonding//////////////
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void) // -Shy
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds");
err_code = pm_peers_delete();
/**@brief Function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is only an example and is not meant for the final product. You need to analyze
* how your product is supposed to react in case of assert.
* @param[in] line_num Line number of the failing assert call.
* @param[in] p_file_name File name of the failing assert call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void nus_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
//从本机Flash中存储的对端设备数据中检索peer id的过滤列表,之后将得到的peer id加到白名单
static void whitelist_set(pm_peer_id_list_skip_t skip)
//定义一个ID句柄数组,该ID句柄用于唯一标识在本机Flash中存储了绑定数据的对端设备
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
//白名单中最大地址数量
uint32_t peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
//检索peer id的过滤列表,检索后得到的是ID句柄
ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
//设置白名单
err_code = pm_whitelist_set(peer_ids, peer_id_count);
void scan_start(bool erase_bonds) // -Shy
ret_code_t ret;
if (erase_bonds == true)
//删除Flash中存储的配对信息,执行完删除操作后,会产生PM_EVT_PEERS_DELETE_SUCCEEDED事件,在该事件下会启动广播
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
//设置白名单(仅添加具有公共地址或随机静态地址的对端设备)
whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
//设置过滤设备的设备身份列表
static void identities_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
//设置设备身份列表
err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start(false);
} break;
//白名单请求:广播程序模块向主应用程序请求白名单,主应用程序应在接收到该事件后设置白名单
case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST: //BLE_ADV_EVT_WHITELIST_REQUEST
//定义地址结构体数组变量
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
//定义IRK结构体数组变量
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
//白名单和IRK存储的最大数量
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
//获取之前设置的白名单,用于ble_advertising_whitelist_reply函数检查白名单和IRK数量
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
whitelist_irks, &irk_cnt);
NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
addr_cnt, irk_cnt);
//设置设备身份列表
identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// //检查白名单和IRK数量是否正确
// err_code = ble_advertising_whitelist_reply(&m_advertising,
// whitelist_addrs,
// addr_cnt,
// whitelist_irks,
// irk_cnt);
// APP_ERROR_CHECK(err_code);
} break;
/**@brief Function for initializing the scanning and setting the filters.
void scan_init(void) // shy
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
init_scan.p_scan_param = &m_scan_params;
init_scan.p_conn_param = &m_conn_params;
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, NULL, 4);
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, &m_target_periph_name);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
ble_btn_c_on_db_disc_evt(&m_ble_btn_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to the peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
/**@brief Function for handling app_uart events.
* @details This function receives a single character from the app_uart module and appends it to
* a string. The string is sent over BLE when the last character received is a
* 'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
} while (ret_val == NRF_ERROR_RESOURCES);
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS client handle. This identifies the NUS client.
* @param[in] p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start(false);
* @brief Function for handling shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
void pair_start()
// if(pair_start_flag == 1)
err_code = pm_conn_secure(0x00, false);
if (err_code != NRF_ERROR_BUSY)
// pair_start_flag = 2;
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("BLE_GAP_EVT_CONNECTED.");
pair_start();
NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
p_gap_evt->conn_handle,
p_gap_evt->params.disconnected.reason);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
/////////Remove for bonding///////////
/* case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
// Pairing not supported.
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
break;*/
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// case BLE_GAP_EVT_SEC_REQUEST: /** ·μ?????????ó*/
// ble_gap_sec_params_t sec_params;
// memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
// err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
// break;
// case BLE_GAP_EVT_AUTH_STATUS:
// if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS) {
// NRF_LOG_INFO("Pair success!");
// } else {
// NRF_LOG_INFO("Pair failed!");
// sd_ble_gap_disconnect(p_ble_evt->evt.gap_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
// break;
NRF_LOG_INFO("Pair success.");
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
printf("a1PAIR_OKs");
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, 0x00, NULL);
//printf("Connection handle1: %u\n", p_ble_evt->evt.gap_evt.conn_handle);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, 0x00);
//printf("Connection handle2: %u\n", p_ble_evt->evt.gap_evt.conn_handle);
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void) // shy
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
// .rts_pin_no = RTS_PIN_NUMBER,
// .cts_pin_no = CTS_PIN_NUMBER,
.use_parity = true,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
init.error_handler = nus_error_handler;
init.p_gatt_queue = &m_ble_gatt_queue;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
// pm_handler_disconnect_on_sec_failure(p_evt);
pm_handler_flash_clean(p_evt);
// switch (p_evt->evt_id)
// case PM_EVT_PEERS_DELETE_SUCCEEDED:
// scan_start(false);
// break;
// default:
// break;
//存储的绑定信息已成功删除
//若程序启动时执行了删除绑定信息操作,在该事件下启动广播
scan_start(false);
//对端设备数据更新事件
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
/////////////Added for bonding/////////////
//////////////Added for bonding//////////////
/**@brief Function for initializing the Peer Manager.
* @param[in] erase_bonds Indicates whether the bonding information must be cleared from
* persistent storage during the initialization of the Peer Manager.
static void peer_manager_init()
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
//éè???2ì??ü??
static void set_static_passkey()
//?¨ò?ò???BLE?????á11ì?±?á?
//?¨ò?ò???±£′??2ì??ü??μ?êy×é
//m_static_pin_option?Dμ??ü?????????ò′?·??2ì??ü??μ?êy×é
m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
//éè??GAP?????Dμ??ü??????μ??μ
uint32_t err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
//?ì2éoˉêy·μ???μ
//uint8_t usart_send_packet(uint16_t Key_Value, uint8_t DMG_status)
uint8_t usart_send_packet(uint8_t *key_value)
for (uint32_t i = 0; i < 10; i++)
NRF_LOG_INFO("%d:%x",i,key_value[i]);
if(key_value[4] == 1)
NRF_LOG_INFO("nrf_gpio_pin_set(6);");
NRF_LOG_INFO("nrf_gpio_pin_clear(6);");
// /*send key value*/
app_uart_put(key_value[0]);
app_uart_put(key_value[1]);
app_uart_put(key_value[2]);
app_uart_put(key_value[3]);
app_uart_put(key_value[4]);
app_uart_put(key_value[5]);
app_uart_put(key_value[6]);
app_uart_put(key_value[7]);
app_uart_put(key_value[8]);
app_uart_put(key_value[9]);
return 0;
// fn : ble_btn_c_evt_handler
// brief : BTN·t??ê??t
// param : none
// return : none
static void ble_btn_c_evt_handler(ble_btn_c_t * p_ble_btn_c, ble_btn_c_evt_t * p_evt)
static uint8_t data_array[244];
static uint16_t uc_idx;
static uint32_t current_index = 0;
switch (p_evt->evt_type)
case BLE_BTN_C_EVT_DISCOVERY_COMPLETE:
err_code = ble_btn_c_handles_assign(&m_ble_btn_c, p_evt->conn_handle, &p_evt->params.peer_db);
NRF_LOG_INFO("Connected to device with Ghostyu BTN Service.");
err_code = ble_btn_c_tx_notif_enable(&m_ble_btn_c);
NRF_LOG_INFO("Enable notification.");
case BLE_BTN_C_EVT_BTN_NOTIFY:
NRF_LOG_INFO("Receiving data.");
for (uint32_t i = 0; i < p_evt->data_len; i++)
if (current_index < 10)
data_array[current_index] = p_evt->p_data[i];
current_index++;
if(current_index==10)
current_index = 0;
NRF_LOG_INFO("Buffer overflow, data cannot be stored.\n");
index++;
uc_idx = index-1;
switch(uc_idx)
case 0x00:
if(p_evt->p_data[0] == 'a')
// NRF_LOG_INFO("p_evt->p_data[0]==FRAME_HEAD");
index = 0;
case 0x01:
if((p_evt->p_data[0]=='1')||(p_evt->p_data[0]=='2')||(p_evt->p_data[0]=='3')||(p_evt->p_data[0]=='4')||(p_evt->p_data[0]=='5'))
// NRF_LOG_INFO("p_evt->p_data[1]=='2'");
index = 0;
case 0x02:
case 0x03:
case 0x04:
case 0x05:
case 0x06:
case 0x07:
case 0x08:
case 0x09:
if(p_evt->p_data[0]=='d')
usart_send_packet(data_array);
index = 0;
index = 0;
// fn : btn_c_init
// brief : 3?ê??ˉBTN·t???í?§??£¨Ghostyu BTN Service client£?
// param : none
// return : none
static void btn_c_init(void)
ble_btn_c_init_t init;
init.evt_handler = ble_btn_c_evt_handler;
err_code = ble_btn_c_init(&m_ble_btn_c, &init);
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
set_static_passkey();
gatt_init();
// shy - btn
btn_c_init();
// shy - btn
nus_c_init();
scan_init();
peer_manager_init();
// Start execution.
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
scan_start(false);
// Enter main loop.
for (;;)
idle_state_handle();
Here is the peripheral code.
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_ble_qwr.h"
#include "ble_nus.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "ble_btn.h"
#include "btd_serial_btn.h"
#include "fdc2114.h"
#include "btd_serial_led.h"
//#include "algorithm.h"
//#include "flash.h"
//#include "selftest.h"
#include "nrf_delay.h"
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection is enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_KEYBOARD_ONLY /**< Keyboard Only. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(10, UNIT_1_25_MS) //20 /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) //75 /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(200, UNIT_10_MS) //4000 /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define FDC_ARRAY_NUM 10
//#define USART_RX_BUF_SIZE 512 //64
//#define USART_RX_DATA_LENGTH 10
#define SYNC 1
#define LED 0
#define DATA 'd'
#define DATA_SEC_BYTE '2' //0x32
#define STATUS 's' //0x73
#define TOUCHUAN 't'
#define IDENTIFY 'i'
#define STATUS_SEC_BYTE '1' //0x31
#define FIRST_BYTE 'a' //0xF0//
/*************Transmit Channel*********************/
#define TX1 1
#define TX2 2
#define TX3 3
#define TX4 4
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_BTN_DEF(m_btn);
APP_TIMER_DEF(fdc_timer_flag);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
// Static passkey
// shy - pair
// 定义状态
typedef enum {
STATE_IDLE, // 空闲状态
STATE_WAIT_FOR_KEY_FLAG, // 等待 key_flag
STATE_AUTH_KEY_REPLY, // 处理认证密钥回复
// 其他状态
} state_t;
state_t current_state = STATE_IDLE;
bool key_flag = false;
// shy - pair
// shy - led
uint8_t command = 0x00;
// shy - led
//u8 Digital_counter=0;
//u8 TX_PDO3 = 0; //sent cyclic synchronous every 100ms (every 2th sync) if a button is pressed.
//u8 TX_PDO1 = 0; //sent on every change in the button status (key pressed or released)
//u8 fdc_read_start = 0;
//u8 Three_seconds_flag=0;
//u16 Three_seconds_counter=0;
//u16 fdc_read_val = 0;
uint16_t fdc_offset = 0;
uint8_t fdc_calibrate_flag = 0;
//u8 fdc_error_flag = FALSE; //wangwei add 180912
//u8 fdc_timer_flag = FALSE;
uint8_t fdc_array_idx = 0;
uint8_t fdc2114_trigger_flag = 0;
//volatile u8 MCU_start_flag = 0;
uint32_t led_on_value = 0; //led on total value
//u8 huart1_rx_flag = FALSE; //huart1 receive flag
//u8 hlpuart1_rx_flag = FALSE;
uint8_t ble_connect_flag = 0; //BLE connect 1, disconnect 0
uint8_t data_array[10];
//u8 hlpuart1_rx_buffer[10];
//u8 huart1_rx_count = 0;
//u8 hlpuart1_rx_count = 0;
//u8 huart_RxBuffer[1], hlpuart1_RxBuffer[1];
//u8 second_data_flag = 0;
//u8 second_data_flag2 = 0;
uint8_t BLE_B_MAC[7];
uint8_t led_rx_buffer[6];
uint8_t hi2c2_device_ready_flag = 0;
uint8_t hi2c1_device_ready_flag = 0;
volatile uint16_t four_key_val = 0;
uint8_t four_key_detect_flag = 0;
//selfTest_t self_test_info = {0};
uint8_t power_trans_flag = 0;
uint8_t mac_identify_flag = 0;
uint8_t DMG_status_flag = 0;
uint8_t fdc_falling_edge = 0;
uint8_t fdc_rising_edge = 0;
uint8_t DMG_old_status = 0;
uint8_t DMG_falling_edge = 0;
uint8_t DMG_rising_edge = 0;
////add wangwei 180911
uint8_t key_rising_edge = 0;
uint8_t key_falling_edge = 0;
uint32_t key_all_value = 0;
////end add
uint8_t fdc_counter = 0;
uint8_t fdc_anti_shake_flag = 0;
//u8 ble_wait_flag = FALSE; //wangwei 180920
//u16 ble_wait_counter = FALSE; //wangwei 180920
//u8 ble_wait_flag2 = FALSE; //wangwei 180920
//u16 ble_wait_counter2 = FALSE; //wangwei 180920
////add wangwei 190124
//u8 ble_A_connect_error_counter = 0;
//u16 ble_A_connect_error_timer_counter = 1000;
//u8 ble_A_connect_error_over_time_flag = FALSE;
//u16 ble_A_connect_error_over_time_counter = 0;
//u8 ble_B_connect_error_counter = 0;
//u16 ble_B_connect_error_timer_counter = 1000;
//u8 ble_B_connect_error_over_time_flag = FALSE;
//u16 ble_B_connect_error_over_time_counter = 0;
////end add
////u8 dmg_old_status = FALSE;
uint8_t stick_key[2] = {0, 0}; //add wangwei 180824
//extern USART_RxQueue_t huart1_rx_queue_t;
//extern USART_RxQueue_t hlpuart1_rx_queue_t;
//extern I2C_HandleTypeDef hi2c1;
//extern I2C_HandleTypeDef hi2c2;
extern uint32_t key_past_value;
extern uint32_t led_blink_value;
extern uint8_t led_blink_flag;
extern uint16_t led_blink_freq;
extern uint8_t key_press_flag;
extern uint8_t channel_ref;
extern uint8_t channel_sample;
extern uint16_t fdc_threshold_val;
extern uint32_t key_current_value;
extern uint32_t anti_shake_key_value;
extern uint8_t anti_shake_timer_counter;
extern uint8_t anti_shake_timer_flag;
extern uint8_t key_enable_status;
extern uint8_t pressed_first_key_flag;
//u8 BLE_REICEIVE_STATUS[8][11] =
// "a1CPCONOKs",
// "a1DISCON_s",
// "a1SCANKEYs",
// "a1CP_NOR_s",
// "a1CP_FAR_s",
// "a1PAIR_OKs",
// "a1DMG_ON_s",
// "a1DMG_OFFs"
uint8_t BLE_REICEIVE_TRANSPARENT[12][11] =
"a1WSNxxxxt",
"a1WRNxxxxt",
"a1WPCxxxxt",
"a1READ_SNt",
"a1READ_RNt",
"a1READ_PCt",
"a1GET_VERt", //上电已发 还发了a1GETCVERs?a1GETPVERs?
"a1GETCAPxt", //上电已发
"a1CALIByxt", //pcan发送ID=1542,Type=D,DLC=8,Data=43 1 33 0 50 0 0 0,Comment="cap_calibrate"
"a1SLFTESTt",
"a1GETCVERs", //新加 上电已发
"a1GETPVERs" //新加 上电已发
uint8_t BLE_TRANSFER[5][11] =
"a1four_oks",
"a1R_CAPyxt",
"a1RSNxxxxt",
"a1RRNxxxxt",
"a1RPCxxxxt"
const uint8_t SOFTWARE_VERSON[7] = "VA20_A1"; //wangwei 180911
uint8_t self_test_finish_flag = 0;
//shy
uint8_t reset_flag = 0;
void usart_send_status(uint8_t *Status_Value, uint8_t T_S);
//shy
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
data_array[i] = p_evt->params.rx_data.p_data[i];
// data_list[i] = data_array[i];
// NRF_LOG_INFO("%x",data_array[i]);
uint32_t err_code;
ble_nus_init_t nus_init;
/*------------------以下代码初始化NUS服务-------------*/
//清零NUS服务初始化结构体
//设置NUS事件回调函数
//初始化NUS服务
/*------------------初始化NUS服务-END-----------------*/
/*------------------以下代码初始化BTN服务-------------*/
//初始化BTN服务
err_code = ble_btn_init(&m_btn);
/*------------------初始化BTN服务-END-----------------*/
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
* @param[in] ble_adv_evt Advertising event.
// uint32_t err_code;
NRF_LOG_INFO("on_adv_evt");
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
// err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
case BLE_ADV_EVT_IDLE:
nrf_gpio_cfg_default(BUTTON_1);
nrf_gpio_cfg_default(BUTTON_2);
nrf_gpio_cfg_default(BUTTON_3);
nrf_gpio_cfg_default(BUTTON_4);
nrf_gpio_cfg_default(BUTTON_5);
nrf_gpio_cfg_default(BUTTON_6);
nrf_gpio_cfg_default(BUTTON_7);
nrf_gpio_cfg_default(BUTTON_8);
nrf_gpio_cfg_default(BUTTON_9);
nrf_gpio_cfg_default(BUTTON_10);
sleep_mode_enter();
uint32_t err_code;
NRF_LOG_INFO("Connected");
// case BLE_GAP_EVT_DISCONNECTED:
// NRF_LOG_INFO("Disconnected");
// // LED1 ON
// err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
// // LED indication will be changed when advertising starts.
// m_conn_handle = BLE_CONN_HANDLE_INVALID;
// break;
stick_key[0] = 0;
stick_key[1] = 0;
// self_test_info.key_val = 0;
four_key_val = 0;
key_press_flag = 0;
key_past_value = 0;
led_off_all_except_power();
led_on(BlueTooth_Light);
key_current_value = 0;
anti_shake_key_value = 0;
anti_shake_timer_counter = 0;
anti_shake_timer_flag = ANTI_SHAKE_TIMER_CLOSE;
pressed_first_key_flag = 0;
NRF_LOG_INFO("Disconnected, reason: 0x%X", p_ble_evt->evt.gap_evt.params.disconnected.reason);
// // LED1 ON
// err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
// 根据断开连接的原因执行不同的操作
switch (p_ble_evt->evt.gap_evt.params.disconnected.reason)
case BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION:
NRF_LOG_INFO("Disconnected by remote user.");
// 执行相关操作
case BLE_HCI_LOCAL_HOST_TERMINATED_CONNECTION:
NRF_LOG_INFO("Disconnected by local host.");
// 执行相关操作
case BLE_HCI_CONNECTION_TIMEOUT:
NRF_LOG_INFO("Connection timeout.");
// 执行相关操作
// 可以添加其他断开连接原因的处理
NRF_LOG_INFO("Disconnected with unknown reason.");
// 执行相关操作
} break;
case BLE_GAP_EVT_AUTH_KEY_REQUEST:
four_key_val = 0;
four_key_detect_flag = 1;
led_on(Tracking_Light);
current_state = STATE_WAIT_FOR_KEY_FLAG;
NRF_LOG_INFO("Received BLE_GAP_EVT_AUTH_KEY_REQUEST, waiting for key_flag");
/////////Removed for ebonding process//////////
/*case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
break;*/
/* case BLE_GATTS_EVT_SYS_ATTR_MISSING:
break;*/
/////////Removed for bonding process//////////
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
// ret_code_t err_code;
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
ble_connect_flag = 1;
led_off(BlueTooth_Light);
if(mac_identify_flag == 1)
usart_send_status(BLE_B_MAC, IDENTIFY);
// // LED1 OFF
// //add wangwei 190124
// ble_A_connect_error_timer_counter = 1000;
// ble_A_connect_error_counter = 0;
// ble_A_connect_error_over_time_counter = 0;
// ble_A_connect_error_over_time_flag = FALSE;
// //end add
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
uint32_t err_code;
switch (event)
sleep_mode_enter();
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t data_arr[BLE_NUS_MAX_DATA_LEN];
static uint8_t index = 0;
uint32_t err_code;
UNUSED_VARIABLE(app_uart_get(&data_arr[index]));
index++;
if ((data_arr[index - 1] == '\n') ||
(data_arr[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
NRF_LOG_HEXDUMP_DEBUG(data_arr, index);
do
err_code = ble_nus_data_send(&m_nus, data_arr, &length, m_conn_handle);
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
uint32_t err_code;
.use_parity = true,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
int8_t tx_power_level = 8;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, tx_power_level);
if (err_code == NRF_SUCCESS)
// 发射功率设置成功
NRF_LOG_INFO("Transmit power set successfully.");
// 发射功率设置失败
NRF_LOG_INFO("Failed to set transmit power. Error code: %d\n", err_code);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
// bsp_event_t startup_event;
// uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
uint32_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
nrf_gpio_pin_clear(LED_2);
// err_code = bsp_btn_ble_init(NULL, &startup_event);
// *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);
advertising_start();
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
nrf_pwr_mgmt_run();
uint8_t usart_send_packet(uint8_t second_byte, uint16_t Key_Value, uint8_t DMG_status, uint8_t Led_Value, uint8_t Tx_counter, uint8_t Tx_num, uint8_t d_s)
uint8_t key_value[10]={0};
uint8_t i=0;
uint8_t len=5,j=4;
uint16_t crc=0;
uint16_t c=0x0107; //1 0000 0111 //x^8+x^2+x+1
c=c<<7; //1000 0011 1000 0000
key_value[0]=FIRST_BYTE;
key_value[1]=second_byte;
key_value[2] = (uint8_t)((Key_Value >> 8) & 0xFF);
key_value[3] = (uint8_t)(Key_Value & 0xFF);
key_value[4] = DMG_status;
key_value[5]=Led_Value;
key_value[6]=Tx_counter;
crc=(uint16_t)((key_value[2]<<8)&0xFF00) | key_value[3];
while(len--)
for(i=0;i<8;i++)
if((crc&0x8000)!=0)
crc=crc^c;
if(i<7)
crc=(crc<<1)&0xFFFE;
if(j<7)
crc=((crc<<1)&0xFFFE) | key_value[j++];
crc=((crc<<1)&0xFFFE) | 0x00;
// key_value[7]=~((uint8_t)(crc>>8));‘
key_value[7]=0;
key_value[8]=Tx_num;
key_value[9]=d_s;
ble_btn_data_send(&m_btn, key_value, 10, m_conn_handle);
// NRF_LOG_INFO("ble_btn_data_send(&m_btn, key_value, 10, m_conn_handle);=%x", ble_btn_data_send(&m_btn, key_value, 10, m_conn_handle));
return 0;
key_value[1]=STATUS_SEC_BYTE;
key_value[2]=*Status_Value;
Status_Value++;
key_value[3]=*Status_Value;
Status_Value++;
key_value[4]=*Status_Value;
Status_Value++;
key_value[5]=*Status_Value;
Status_Value++;
key_value[6]=*Status_Value;
Status_Value++;
key_value[7]=*Status_Value;
Status_Value++;
key_value[8]=*Status_Value;
key_value[9]=T_S;
/*send key value*/
void process_state() {
switch (current_state) {
case STATE_WAIT_FOR_KEY_FLAG:
if (key_flag) {
current_state = STATE_AUTH_KEY_REPLY;
case STATE_AUTH_KEY_REPLY:
sd_ble_gap_auth_key_reply(0x00, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, passkey);
NRF_LOG_INFO("sd_ble_gap_auth_key_reply");
// 执行完后回到空闲状态或其他状态
case STATE_IDLE:
// 空闲状态处理其他任务
// 其他状态处理
void GPIO_Init()
// nrf_gpio_cfg_input(POWER_PIN, NRF_GPIO_PIN_PULLUP);
// nrf_gpio_cfg_input(DMG, NRF_GPIO_PIN_PULLUP);
/**@brief Application main function.
bool erase_bonds;
uint8_t four_key_read_value;
// Initialize.
uart_init();
log_init();
timers_init();
// 初始化外设
GPIOTE_Init();
GPIO_Init();
// 初始化按键
BTN_Init();
LED_Init();
nrf_gpio_cfg_output(11);
nrf_delay_ms(10);
twi_init();
fdc2114_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// flash_init();
// Start execution.
// Enter main loop.
for (;;)
process_state();
if(four_key_detect_flag == 1)
four_key_read_value = read_four_key();
NRF_LOG_INFO("four_key_read_value = %d",four_key_read_value);
if(four_key_read_value != 0)
led_blink(Tracking_Light, 300);
led_blink(0, 0);
four_key_val = four_key_val | four_key_read_value;
if(four_key_val == 0x0F)
NRF_LOG_INFO("four_key_val == 0x0F");
key_flag=1;
// memcpy(Data_buffer, BLE_TRANSFER[0]+2, 7);
// usart_send_status(Data_buffer, STATUS);
led_off(Tracking_Light);
led_blink_flag = 0;
led_blink_value = 0;
led_blink_freq = 50;
mac_identify_flag = 1;
Whitelisting on the central is used to filter on peripherals, so that the central only attempts to connect to specifc peripherals.
Whitelisting on the peripheral is used to prevent other centrals than those whitelisted from connecting. If the problem is that other centrals connect to the peripheral, you need to implement whitelisting on the peripheral. Whitelisting on the central plays no part in this.
Note that whitelisting is not related to the pairing procedure (other than that you use information obtained in the pariging procedure: adress and potentially IRK), so which side that enters the passkey is not relevant for how you handle whitelisting.
PS: I see you are using the old nRF5 SDK, so you can ignore the links in my previous post, which are only relevant for the newer nRF Connect SDK.
Sorry. Now I change my minds. I want to start scanning and then connect and pair when I recieve the
specific commands. And I also want to realize the function that when I recieve the specific commands
again I can delete the information of bonding and restart scanning.
Here is the important part of my code.
Here is the whole code if you need.
#include <stdio.h>
#include <stdint.h>
#include "ble.h"
// shy - btn
// shy - btn
#include "flash.h"
uint8_t data_list[10];
uint32_t has_received_stadis = 0;
uint8_t is_paired = 0; // 表示是否已经配对
// shy - btn
// shy - btn
// Static passkey
// shy - scan
// 定义扫描参数
.active = 1, // 1为主动扫描,可获得广播数据及扫描回调数据
.interval_us = 10000, // 扫描间隔:160*0.625 = 100ms
.window_us = 5000, // 扫描窗口:80*0.625 = 50ms
.timeout = NRF_BLE_SCAN_SCAN_DURATION, // 扫描持续的时间:设置为0,一直扫描,直到明确的停止扫描
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL, // 扫描所有BLE设备,不做限制
.scan_phys = BLE_GAP_PHY_1MBPS, // 扫描1MBPS的PHY
.min_conn_interval = MSEC_TO_UNITS(NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL, UNIT_1_25_MS), // 最小连接间隔7.5ms
.max_conn_interval = MSEC_TO_UNITS(NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL, UNIT_1_25_MS), // 最大连接间隔30ms
.slave_latency = NRF_BLE_SCAN_SLAVE_LATENCY, // 隐藏周期0
.conn_sup_timeout = MSEC_TO_UNITS(NRF_BLE_SCAN_SUPERVISION_TIMEOUT, UNIT_10_MS), // 超时时间4000ms
// shy - scan
// shy - btn
// shy - btn
//白名单中最大地址数量
//设置白名单
ret_code_t ret;
delete_bonds();
//设置过滤设备的设备身份列表
//设置设备身份列表
static uint8_t retry_count = 0;
const uint8_t max_retries = 5;
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
if(has_received_stadis == 1)
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_FILTER_MATCH");
ble_gap_addr_t m_addr;
m_addr.addr_id_peer = 1;
m_addr.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
memcpy(m_addr.addr, p_scan_evt->params.p_not_found->peer_addr.addr, BLE_GAP_ADDR_LEN);
nrf_ble_scan_stop();
NRF_LOG_INFO("has_received_stadis == 1");
err_code = sd_ble_gap_connect(&m_addr, &m_scan_params, &m_conn_params, APP_BLE_CONN_CFG_TAG);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Connection attempt failed, error code: 0x%x", err_code);
if (retry_count < max_retries)
NRF_LOG_INFO("Retrying connection attempt %d of %d", retry_count + 1, max_retries);
retry_count++;
scan_start(false);
NRF_LOG_ERROR("Max connection attempts reached");
retry_count = 0;
retry_count = 0;
NRF_LOG_INFO("handle_stadis_received");
} break;
init_scan.connect_if_match = false;
ret_code_t ret_val;
do
do
//void uart_event_handle(app_uart_evt_t * p_event)
// static uint8_t data_array[BLE_NUS_MAX_DATA_LEN];
// static uint16_t index = 0;
// uint32_t ret_val;
// switch (p_event->evt_type)
// /**@snippet [Handling data from UART] */
// case APP_UART_DATA_READY:
// UNUSED_VARIABLE(app_uart_get(&data_array[index]));
// index++;
// if ((data_array[index - 1] == '\n') ||
// (data_array[index - 1] == '\r') ||
// (index >= (m_ble_nus_max_data_len)))
// NRF_LOG_DEBUG("Ready to send data over BLE NUS");
// NRF_LOG_HEXDUMP_DEBUG(data_array, index);
// do
// ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
// if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
// APP_ERROR_CHECK(ret_val);
// } while (ret_val == NRF_ERROR_RESOURCES);
// index = 0;
// break;
// case APP_UART_COMMUNICATION_ERROR:
// NRF_LOG_ERROR("Communication error occurred while handling UART.");
// APP_ERROR_HANDLER(p_event->data.error_communication);
// break;
// case APP_UART_FIFO_ERROR:
// NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
// APP_ERROR_HANDLER(p_event->data.error_code);
// break;
// default:
// break;
uint32_t ret_val;
NRF_LOG_HEXDUMP_DEBUG(&data_array[index], 1);
index++;
uc_idx = index-1;
switch(uc_idx)
case 0x00:
if(data_array[0] == 'a')
index = 0;
case 0x01:
if((data_array[1]=='1')||(data_array[1]=='2')||(data_array[1]=='3')||(data_array[1]=='4')||(data_array[1]=='5'))
index = 0;
case 0x02:
case 0x03:
case 0x04:
case 0x05:
case 0x06:
case 0x07:
case 0x08:
case 0x09:
if((data_array[9]=='m')||(data_array[9]=='i'))
for(int i=2;i<10;i++)
data_list[i-2]=data_array[i];
index = 0;
else if((data_array[9]=='d')||(data_array[9]=='t')||(data_array[9]=='s'))
NRF_LOG_INFO("ble_nus_c_string_send success");
for(int i = 0; i < 10; i++)
data_list[i]=data_array[i];
// ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_list, sizeof(data_list));
// if(ret_val != NRF_SUCCESS)
index = 0;
index = 0;
scan_start(false);
switch (event)
return true;
void pair_start()
break;*/
} break;
// break;
// } else {
// break;
is_paired = 1;
write_flash(0x7e200,is_paired);
switch (event)
.use_parity = true,
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
err_code);
// break;
// default:
// break;
//存储的绑定信息已成功删除
scan_start(false);
//对端设备数据更新事件
nrf_pwr_mgmt_run();
//éè???2ì??ü??
//?ì2éoˉêy·μ???μ
return 0;
// param : none
// return : none
current_index++;
current_index = 0;
index++;
uc_idx = index-1;
switch(uc_idx)
case 0x00:
index = 0;
case 0x01:
index = 0;
case 0x02:
case 0x03:
case 0x04:
case 0x05:
case 0x06:
case 0x07:
case 0x08:
case 0x09:
index = 0;
index = 0;
// fn : btn_c_init
// param : none
// return : none
// Initialize.
log_init();
timer_init();
uart_init();
flash_init();
has_received_stadis = read_flash(0x7e100);
is_paired = read_flash(0x7e200);
ble_stack_init();
gatt_init();
btn_c_init();
nus_c_init();
scan_init();
// Start execution.
scan_start(false);
// Enter main loop.
for (;;)
if((data_list[0] == 'a') && (data_list[1] == '1') && (data_list[2] == 'S') && (data_list[3] == 'T') && (data_list[4] == 'A') && (data_list[5] == 'D') && (data_list[6] = 'I') && (data_list[7] == 'S') && (data_list[8] == 'C') && (data_list[9] == 's'))
NRF_LOG_INFO("has_received_stadis=1.");
has_received_stadis = 1;
write_flash(0x7e100,has_received_stadis);
data_list[0] = 'b';
if (is_paired == 1) {
NRF_LOG_INFO("is_paired");
delete_bonds();
is_paired = 0;
Thank you.
I am not entierly sure what you want to do, or what is not working and wha tyou need asssitance with, but I see a an imporant things that must be addressed:
You write some internal status (is_paired and has_received_stadis) to flash (at leat I assume that is what the write_flash() function does, though I do not see the implementation of that). But please note that writing to flash an only flip bits from 0 to 1, not the other way (that happens with a page erase). So I do not expect this will work. If you really want to write data to flash you should consider something like Flash Data Storage. I do not understand why you write this to flash, though? If this is just a variable you need to set in an interrupt and read outside in the same file, a static volatile variable should do the job.
Other than that, I need to understand more about what you want to do in order to provide advice. Also, I would recommend not "reinventig the wheel". If what you want to do is something commonly done (like whitelisting a peer), then there are standard ways to do it, and you will likely gain from just following the normal approach.
