NCS v2.6.0, NRF5340dk
I'm trying to configure a project that uses mcuboot with direct XIP with the external QSPI flash. I've been looking at examples in
ncs/v2.6.0/nrf/tests/modules/mcuboot/external_flash
ncs/v2.6.0/nrf/tests/modules/mcuboot/direct_xip
ncs/v2.6.0/nrf/samples/nrf5340/extxip_smp_svr
The partition manager is having time creating partitions and throwing errors that memory regions are not aligned, so I've been using this as a guideline Partition Manager Error w/ Direct XIP and MCUboot enabled
This is the process I've been using to build
Starting with the "external_flash" example:
1. copy the linker script from ncs/v2.6.0/nrf/samples/nrf5340/extxip_smp_svr/linker_arm_extxip.ld
2. create a VERSION file for cmake builds
VERSION_MAJOR = 0 VERSION_MINOR = 1 PATCHLEVEL = 11 VERSION_TWEAK = 0 EXTRAVERSION =
3. modify prj.conf
CONFIG_ZTEST=y CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP=y CONFIG_FLASH=y CONFIG_HAVE_CUSTOM_LINKER_SCRIPT=y CONFIG_CUSTOM_LINKER_SCRIPT="linker_arm_extxip.ld" CONFIG_XIP=y CONFIG_NORDIC_QSPI_NOR_XIP=y
# MCUboot requires a large stack size, otherwise an MPU fault will occur CONFIG_MAIN_STACK_SIZE=10240 # Enable flash operations CONFIG_FLASH=y # This must be increased to accommodate the bigger images. CONFIG_BOOT_MAX_IMG_SECTORS=256 # Use minimal C library instead of the Picolib CONFIG_MINIMAL_LIBC=y CONFIG_BOOT_DIRECT_XIP=y CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
nvs_storage: address: 0xfa000 end_address: 0xfc000 region: flash_primary size: 0x2000 settings_storage: address: 0xfc000 end_address: 0xff000 region: flash_primary size: 0x3000 id_storage: address: 0xff000 end_address: 0x100000 region: flash_primary size: 0x1000
5. generate a new pm_static.yml
west build -b nrf5340dk_nrf5340_cpuapp -t partition_manager_report --pristine cp pm_static.yml pm_static.yml.bak cp build/partitions.yml pm_static.yml
6. Modify the pm_static.yml to include mcuboot_secodary_app and mcuboot_secondary_pad
app:
address: 0x10200
end_address: 0xfa000
external_flash:
address: 0xea000
end_address: 0x800000
region: external_flash
id_storage:
address: 0xff000
mcuboot:
address: 0x0
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0x10000
end_address: 0x10200
placement:
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0x10000
orig_span: &id001
- app
- mcuboot_pad
span: *id001
mcuboot_primary_app:
address: 0x10200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x0
device: DT_CHOSEN(nordic_pm_ext_flash)
end_address: 0xea000
orig_span: &id003
- mcuboot_secondary_pad
- mcuboot_secondary_app
placement:
align:
start: 0x4
share_size:
- mcuboot_primary
span: *id003
mcuboot_secondary_pad:
address: 0x0
end_address: 0x200
align:
start: 0x4000
share_size:
- mcuboot_pad
mcuboot_secondary_app:
address: 0x200
placement:
after:
share_size:
nvs_storage:
address: 0xfa000
otp:
address: 0xff8100
end_address: 0xff83fc
region: otp
pcd_sram:
address: 0x20000000
end_address: 0x20002000
placement:
after:
- start
region: sram_primary
rpmsg_nrf53_sram:
address: 0x20070000
end_address: 0x20080000
placement:
before:
- end
settings_storage:
address: 0xfc000
sram_primary:
address: 0x20002000
end_address: 0x20070000
7. Modify linker script with new external flash memory address
MEMORY
EXTFLASH (wx) : ORIGIN = 0x10ea000, LENGTH = 0x716000
#include <zephyr/arch/arm/cortex_m/scripts/linker.ld>
8. Build/flash using vscode
Results:
The application builds and programs, however there is no output on my terminal for either the app core or the net core
Memory report looks like what I'd expect. I'm surprised the mcuboot_secondary_pad isn't in the correct span, but the address is correct
Any assistance debugging this would be appreciated
