Connection parameter optimize: nRF52840(central) multilink with 8x52832 peripherals
Hi all,
I'm developing a multilink system with 52840 dongle as central and 8 52832 devices as peripherals, which is similar to previous project in thread part I & Part II.
8 peripherals are exactly the same and generates 172Bytes/each device every 100ms, so total data rate would be 13.76kB/s.
↑According to power profiler, I foud that data packets generated every 100ms, which is 8(peripheral devices) * 251(PDU size) * 1(packet per device) could be transmited within 25ms.  So I set central connection parameters as follows:
But here is my problem: the throughput could reach the requirement, but the connection stability seems very sensitive to distance. When peripheral devices are placed closely to central, the connection is very stable. Then I move peripherals 1 meter away from the central, the devices start to disconnect & reconnect frequently which cause severe packet loss.
I've tried different parameters in previous thread, for instance, 100ms connection interval or 80ms interval. I also tried 52840 module with PA/LNA to raise TX/RX sensitivity. Seems no help. So I think there might be some faults in parameter setting?
Thnaks.
Ava
