nRF52832 connection parameters for multilink
Dear all,
I'm trying to build a system with 1 central to 9 peripherals. All devices are based on nRF52832, SDK16, s132 7.0.1.
I've checked this post to get some clues but still quite confusing while scheduling.
Here are some questions I have for scheduling and connection parameters:
  1. Can peripherals using GAP_EVENT_LENGTH different with each other?
  2. CONNECTION_INTERVAL should be unified for all the peripherals and central device? Which eaquals to ∑tevent-Cx + scanWindow + tScanReserved ?
  3. How to determine central GAP_EVENT_LENGTH? ∑tevent-Cx ?
  4. Should I set MIN_CONNECTION_INTERVAL and MAX_CONNECTION to the same value get better performance?
For example, I have Peripheral one with GAP_EVENT LENGTH set to 5 (which is 6.25ms) and other eight peripherals with GAP_EVENT LENGTH set to 2 (which is 2.5ms). Total gap_event length needed is 6.25 + 2.5 * 8 = 26.25ms, thus the central GAP_EVENT_LENGTH should be 22(27.5ms). Considering 10ms scan window and some scan reserved time. I set both CONNECTION_INTERVAL to 40ms for all devices, SCAN_INTERVAL is set to 40ms for central. Is it the correct thinking?
But the peripherals disconnect periodically.
*Besides, I can't set MTU_SIZE to maximum value if I set CENTRAL_LINK_COUNT to 9. It shows  .
Following is snippet of compiler message of my cenrtral device code, I've set the RAM exactally the size compiler told me so I guess I've spared as much RAM as possible to softdevice?
Any help is appreciated,
Thanks!
    Yes, you can add different configurations with different GAP event length. Add configurations using the sd_ble_cfg_set() function.
    Yes, it's recommend that this is a common factor. It's covered in this chapter here: https://infocenter.nordicsemi.com/topic/sds_s132/SDS/s1xx/multilink_scheduling/suggested_intervals_windows_s132.html
    It depends on the connetion interval, and number of links:
    It's the central that decides the connection interval. The slave can request a different a connection interval, but if you as the central want's to accurately control the connection interval, then set max=min.
    No. 22(27.5)ms is the sum yes, but GAP_EVENT_LENGTH is the time set aside for each connection.
    Are you sure? If you set DEBUG as a preprocessor symbol define, what does the log shows?
  • Can peripherals using GAP_EVENT_LENGTH different with each other?
    I actually want to set fixed GAP_EVENT_LENGTH for a single peripheral device, but the value is different between peripherals. So if I set the value in sdk_config.h, should it work?
    So if I have 9 connections with different GAP_EVENT_LENGTH, how do I supposed to choose central GAP_EVENT_LENGTH. Fot instance, one 6.25ms peripheral and eight 2.5ms peripherals.
    Actually I'm not quite sure about this, I just compile the code on KEIL. Adding RX-data to ZI-data size to calculate minimum RAM size. I'll see what's going on with DEBUG macro.
    Thanks.
    When you initializes the SoftDevice, you typically have this function.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    Where nrf_sdh_ble_default_cfg_set is used to set the configuration. Values from sdk_config.h is used, and the tag APP_BLE_CONN_CFG_TAG is used.
    You need to add a new configuration / new tag. And when you call sd_ble_gap_connect(), you select what configuration you want to use.
    See this Message Sequence Chart: https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s132.api.v7.3.0/group___b_l_e___c_o_n_n___c_f_g.html
    I've checked ble_app_multilink_central demo, the default parameter is shown as follow snippet.
    I wonder how could it work since 8 * 6ms = 48ms yet the conntion interval is set in range 7~30ms. Also, scanning interval is 160 * 0.625 = 100ms with 50ms window. Total GAP_EVENT_LENGTH is way larger than connect interval. How does this central distribute its connection and avoid overlapping?
    Thanks
    The configuration for the ble_app_multilink_central example does not look optimal. With 8(NRF_SDH_BLE_CENTRAL_LINK_COUNT)*NRF_SDH_BLE_GAP_EVENT_LENGTH > the connection interval, and with scanning as well, you will get scheduling conflicts here. i.e. scanning events and/or some expected connection events will be dropped if this central connects to 8 devices with this configuration.
