We have a few questions regarding the pm_static.yml file that's used for defining flash partitions in zephyr.
Our main questions are regarding alignment; we've created a partition "device_details_partition" where we plan on writing configuration values at manufacturing using nrfjprog via an external nRF53DK.
These values should be permanent for the lifecycle of the device and will only ever be read in the application firmware, never overwritten. "device_details_partition" needs to have static memory locations so we know where to write/read.
The "device_details_partition" is only 16 bytes long so we're unable to align it to 4kb, we've defined it as follows;
device_details_partition: address: 0xf3FF0 # New address, originally where user_partition started end_address: 0xf4000 # Size is 0x10 region: flash_primary size: 0x10
Some questions we had about this implementation:
- Could having the size and end address of mcuboot_primary and mcuboot_primary_app not 4kb aligned cause any issues?
- Is there a better way we can create "device_details_partition"? A section of flash which can be flashed externally.
Below is our full pm_static.yml
user_partition: # NVS Storage
address: 0xf6000
end_address: 0xf8000
placement:
after:
- settings_storage
app:
address: 0x4c200
end_address: 0xf3FF0 # Decreased by 0x10
external_flash:
address: 0x128000
end_address: 0x200000
region: external_flash
mcuboot:
address: 0x0
end_address: 0xc000
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0xc000
end_address: 0xc200
placement:
align:
start: 0x4000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0xc000
orig_span: &id001
- mcuboot_pad
- app
- tfm
span: *id001
mcuboot_primary_1:
address: 0x0
device: nordic_ram_flash_controller
end_address: 0x40000
region: ram_flash
mcuboot_primary_app:
address: 0xc200
orig_span: &id002
- app
- tfm
span: *id002
mcuboot_secondary:
address: 0x0
device: DT_CHOSEN(nordic_pm_ext_flash)
end_address: 0xe8000
placement:
align:
start: 0x4
share_size:
- mcuboot_primary
mcuboot_secondary_1:
address: 0xe8000
end_address: 0x128000
nonsecure_storage:
address: 0xf4000
end_address: 0xf6000
orig_span: &id003
- settings_storage
span: *id003
otp:
address: 0xff8100
end_address: 0xff83fc
region: otp
pcd_sram:
address: 0x20000000
end_address: 0x20002000
placement:
before:
- tfm_sram
region: sram_primary
ram_flash:
address: 0x40000
region: ram_flash
rpmsg_nrf53_sram:
address: 0x20070000
end_address: 0x20080000
placement:
before:
- end
settings_storage:
address: 0xf4000
inside:
- nonsecure_storage
placement:
align:
start: 0x4000
before:
- tfm_storage
- end
sram_nonsecure:
address: 0x2000fd70
orig_span: &id004
- sram_primary
- rpmsg_nrf53_sram
span: *id004
sram_primary:
address: 0x2000fd70
end_address: 0x20070000
sram_secure:
address: 0x20000000
end_address: 0x2000fd70
orig_span: &id005
- pcd_sram
- tfm_sram
span: *id005
tfm:
address: 0xc200
end_address: 0x4c200
inside:
placement:
before:
- app
tfm_its:
address: 0xf8000
end_address: 0xfa000
inside:
- tfm_storage
placement:
before:
- tfm_otp_nv_counters
tfm_nonsecure:
address: 0x4c200
orig_span: &id006
- app
span: *id006
tfm_otp_nv_counters:
address: 0xfa000
end_address: 0xfc000
inside:
- tfm_storage
placement:
before:
- tfm_ps
tfm_ps:
address: 0xfc000
end_address: 0x100000
inside:
- tfm_storage
placement:
align:
start: 0x4000
before:
- end
tfm_secure:
address: 0xc000
orig_span: &id007
- mcuboot_pad
- tfm
span: *id007
tfm_sram:
address: 0x20002000
inside:
- sram_secure
placement:
after:
- start
tfm_storage:
address: 0xf8000
orig_span: &id008
- tfm_ps
- tfm_its
span: *id008
