undefined reference to device dts ord
I'm learning how to write a new device driver for Zephyr 3 using NCS version 2.6.0.
I have watched the ZDS summit video and looked through the shared git repo.
I have created an overlay, CMakeLists.txt files, Kconfig chain, bindings and adjusted prj.conf and main.c
I started with the simple hello world sample.
I have this source code now:
#define MYSENSOR_DEVICE_NODE          DT_NODELABEL(mysensor)
#if DT_NODE_EXISTS(MYSENSOR_DEVICE_NODE)
  #if DT_NODE_HAS_STATUS(MYSENSOR_DEVICE_NODE, okay)
    static const struct device *fpsensor = DEVICE_DT_GET(MYSENSOR_DEVICE_NODE);
  #else
    #error "mysensor status is not okay, thus disabled in devicetree"
#else
  #error "mysensor node could not be found in devicetree"
    if (!device_is_ready(fpsensor)) {
        LOG_ERR("unable to get the device ready");
        return -ENODEV;
    } else {
        LOG_INF("initialized successfully");
    LOG_INF("starting while loop");
    while(true) {
        LOG_INF("Hello World from RTT! %s", CONFIG_BOARD);
        k_msleep(1000);
    return 0;
I have used the macros to confirm my sensor can be found and has status okay. Otherwise it will print the error.
I also checked the generated ./build/zephyr/zephyr.dts to check if my sensor is present and has status okay.
I also checked the generated ./build/zephyr/.config to check if my sensor is enabled (with y).
I always do pristine build, but still the compiler complains with:
src/main.c:40: undefined reference to `__device_dts_ord_125'
What could be wrong?
