I encountered a very strange issue. I need to control a device using GPIO. What I use is p0.22/p0.02/p0.03/p1.11/p0.31/p0.30. I modify the app.overlay file and check the final zephyr.dts which is correct. But when I use the gpio_pin_set_dt to control those GPIO, the results are not as I expected.
p0.22 , can't control, always 1
p0.02 ,can't control, always 0
p0.03 ,can't control, always 0
p1.11 , OK
p0.31 , OK
p0.30 ,can't control, always 0
In my project, I also control the other GPIO p0.5/p1.15/p1.14/p1.1/p1.0 using the same method and those GPIO work well. I check the issue again and again and I can't find anything wrong.
My questions are
1. Is it possible the pins are overlapping assignments? ( I checked zephyr.dts already, another way to check it? )
2. Is it possible those pins can't be used as GPIO? p0.22/p0.02/p0.03/p0.30
Thanks
