Maximum RSSI value of -42 dBm
FormerMember
FormerMember
Greetings,
During a connection between two nrf51422s running on S120 (2.1.0) and S110 (8.0.0) with a connection interval of 7.5 ms I get only a maximum RSSI of -42 dBm, even when the two antennas as almost touching. When taken further apart the RSSI decreases to a minimum of about -100 dBm.
The RSSI measurement is started by
sd_ble_gap_rssi_start(m_conn_handle, BLE_GAP_RSSI_THRESHOLD_INVALID, 0);
And in a routine in between the two connection events I get the RSSI by the call
sd_ble_gap_rssi_get(m_conn_handle, &rssi_val);
What could be the reason for this behavior of RSSI not increasing beyond -42 dBm? With bare metal coding for advertisements and scanners I've noticed RSSI greater than -30 dBm too.
Thanks and cheers!
    Is this on the development kit or using a custom board?
    The performance in what is almost guaranteed to be near field will give odd results. If it is a custom board it can be because the matching is poor. Also when you are holding metal object like the development kit close to the antenna you will affect the RF performance.
    A minimum of around -100 to -80 dBm is sensible, as the nRF51 has a maximum sensitivity of -90dBm in 1mbps mode. The swing of +/- 10dBm is due to RSSI measuring inaccuracies.
    Øyvind
  • FormerMember
    0 FormerMember in reply to Øyvind Karlsen
    Not from my side. With the few devices that we've played around with, some of them DK, this behaviour is prevalent. The max RSSI is around -45 to -40 dBm. I also feel that they are saturating somehow.
