SPI Communication SDK 2.4.0 nRF5340 DK
I want to operate a rather complex spi sensor with the nrf5340. To do that, I wanted to first establish spi communication. I started by creating a hello world example and then implementing the steps explained in the spi API tutorial. This is my current main.c:
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr/kernel.h>
#include <zephyr/drivers/spi.h>
#define SPIOP	SPI_WORD_SET(8) | SPI_TRANSFER_MSB
// const struct device *const spi_dev = DEVICE_DT_GET(DT_NODELABEL(spi1));
const struct spi_dt_spec *const spispec = DEVICE_DT_GET(DT_NODELABEL(spi4));
// struct spi_dt_spec spispec = SPI_DT_SPEC_GET(DT_NODELABEL(spi1), SPIOP, 0);
	uint32_t err;
	err = spi_is_ready_dt(&spispec);
	if (!err) {
		// LOG_ERR("Error: SPI device is not ready, err: %d", err);
		return 0;
	uint8_t data[8], size, data2[8];
	data2[0] = 3;
	// while (true)
	// 	err = spi_write_dt(spispec, data);
	uint8_t tx_buffer = 0x88;
	struct spi_buf tx_spi_buf		= {.buf = (void *)&tx_buffer, .len = 1};
	struct spi_buf_set tx_spi_buf_set 	= {.buffers = &tx_spi_buf, .count = 1};
	struct spi_buf rx_spi_bufs 		= {.buf = data, .len = size};
	struct spi_buf_set rx_spi_buf_set	= {.buffers = &rx_spi_bufs, .count = 1};
	while (true)
		/* code */
	err = spi_write_dt(&spispec, &data2);
	err = spi_transceive_dt(&spispec, &tx_spi_buf_set, &rx_spi_buf_set);
	if (err < 0) {
		LOG_ERR("spi_transceive_dt() failed, err: %d", err);
		return err;
		k_msleep(10);
	printk("Hello World! %s\n", CONFIG_BOARD);
	return 0;
I did set the SPI config in my proj.conf.
I wanted to check with a logic analyzer if anything is happening on my mosi and miso lines, so I connected it to the default spi4 pins: P1.13 for MOSI, P1.14 for MISO and P1.15 for SCK. I checked in the devie tree and the pins are correct. However, nothing is happening on the MISO, MOSI, or SCK lines.
I do not have a Sensor attached, i just want to check if anything is happening at all.
Can someone help me out here?
Paul
