nRF9160 firmware upgrade process no longer works
I implemented firmware update over LTE Cat-M and Ethernet last year by modifying the `fota_download` and the `download_client` examples into my own slightly modified version, which has functions that choose ethernet or LTE depending on what's available for the download.
While preparing the firmware release for the production units I decided to test the firmware update and found it no longer works.
I've implemented the code using the nRF Connect SDK v2.2.2, which initially worked last year when tested.
So far, from my testing, I can tell it is correctly downloading the firmware image from the client's server. However, it doesn't seem to apply the firmware update after downloading it, even when using `dfu_target_schedule_update(0)` or `boot_request_upgrade(BOOT_UPGRADE_PERMANENT)`. From additional debug information, I can tell that it is writing the MCU image type as 0x03, which should be permanent.
Development software: JLinkRTT Viewer, nRF Connect SDK v2.2.2
Computer platform: Ubuntu 24.04
Note that I am using the MCU boot key, which is publically known at the moment, not a custom key for signing.
Attached is a version of the firmware with most things removed except for the modem and firmware update code.
0564.controller-ng.tgz
  • Which board do you use?
    Thingy:91 (thingy91_nrf9160_ns) comes with a "static partition management/pm_static.yml", while the nRF9160-DK (nrf9160dk_nrf9160_ns) uses a dynamic per default. If your build is based on the dynamic partition management, did you check, if the partitions has changed (e.g. using -t partition_manager_report )? Did you enable "CONFIG_SETTINGS=y" recently or was it always enabled?
    (I had a similar experience , in my case it was caused by enabling the CONFIG_SETTINGS=y.)
  • The board is the nRF9160-DK, we are running on a custom board that uses the same config as the DK board.
    Looking back at the commits I had `CONFIG_SETTINGS=y` enabled when it was working. I'll look into the partition report and see if it gives me anything useful.
    The size and location of the bootloader slots must remain consistent across versions for DFU to function properly. With a dynamic partition layout, the layout may change when enabling partitions, such as settings storage.
    You can make the memory layout static by creating a static partition file as described here: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/scripts/partition_manager/partition_manager.html#static_and_dynamic_configuration
    Vidar
  • After doing a lot of debugging I found the issue is due to my overlay file not being picked up by the build system
    I have the overlay located in `child_image/mcuboot/boards/nrf9160dk_nrf9160_ns.overlay` and `child_image/mcuboot/boards/nrf9160dk_nrf9160.overlay`. The file contains the following.
    &uart1 {
    	status = "disabled";
    &i2c2 {
    &uart0 {
    &pwm_led0 {
    &led0 {
    &led1 {
    &led2 {
    &led3 {
    &button0 {
    &button1 {
    &button2 {
    &button3 {
    &spi3 {
    	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>, /* D10 */
    		   <&gpio0 25 GPIO_ACTIVE_LOW>;
    	mx25r64: mx25r6435f@1 {
    		compatible = "jedec,spi-nor";
    		reg = <1>;
    		spi-max-frequency = <8000000>;
    		jedec-id = [c2 28 17];
    		sfdp-bfp = [
    			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
    			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
    			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
    			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
    		size = <67108864>;
    		mxicy,mx25r-power-mode = "high-performance";
    /* Enable high drive mode for the SPI3 pins to get a square signal at 8 MHz */
    &spi3_default {
    	group1 {
    		nordic,drive-mode = <NRF_DRIVE_H0H1>;
    	aliases {
    		ext-flash = &mx25r64;
    	/* Configure partition manager to use mx25r64 as the external flash */
    	chosen {
    		nordic,pm-ext-flash = &mx25r64;
    On the initial build the overlay file is picked up, however, if I build it again then the file is excluded and it results in the firmware update not working due to the external flash not being part of the device tree.
    Any solution to get this to always be included for the mcuboot image?
