Hi, I am using light lightness server example for the testing of DFU OTA over mesh. I have successfully transferred the DFU archive over serial with nRF Util tool and follow the steps as described in the nrf5 SDK for mesh. After DFU update device restart and return "app_error_weak.c, 105, Mesh assert at 0x0002AC42 (:0)" when initializating mesh stack.
This is light lightness example with DFU functionality:
#include <stdint.h>
/* HAL */
//#include "boards.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh_events.h"
#include "nrf_mesh_config_examples.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "mesh_config.h"
#include "device_state_manager.h"
#include "access_config.h"
#include "proxy.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_light_lightness.h"
#include "app_config.h"
#include "example_common.h"
#include "pwm_utils.h"
#include "light_lightness_utils.h"
#include "ble_softdevice_support.h"
#include "model_config_file.h"
#include "app_timer.h"
#include "app_scene.h"
#include "nrf_mesh_dfu.h"
#include "app_util.h"
#include "nrf_mesh_serial.h"
* Definitions
/* Client lightness parameter step size */
#define APP_LIGHTNESS_STEP_SIZE (16384L)
/* Controls if the model instance should force all mesh messages to be segmented messages. */
#define APP_FORCE_SEGMENTATION (false)
/* Controls the MIC size used by the model instance for sending the mesh messages. */
#define APP_MIC_SIZE (NRF_MESH_TRANSMIC_SIZE_SMALL)
/* Gives the light lightness element index. */
#define APP_LL_ELEMENT_INDEX (0)
* Forward declaration of static functions
static void mesh_events_handle(const nrf_mesh_evt_t * p_evt);
static void set_lightness_cb(const app_light_lightness_setup_server_t * p_app, uint16_t lightness);
static void get_lightness_cb(const app_light_lightness_setup_server_t * p_app, uint16_t * p_lightness);
static void transition_time_lightness_cb(const app_light_lightness_setup_server_t * p_server,
uint32_t transition_time_ms, uint16_t target_lightness);
#if SCENE_SETUP_SERVER_INSTANCES_MAX > 0
static void scene_transition_lightness_cb(const app_scene_setup_server_t * p_app,
uint16_t target_scene);
* Static variables
static bool m_device_provisioned;
static nrf_mesh_evt_handler_t m_evt_handler;
static const uint8_t led = 4;
static nrf_mesh_evt_handler_t m_event_handler =
.evt_cb = mesh_events_handle,
/* Light Lightness Setup Server related variables */
/* Light Lightness Setup Server structure definition and initialization */
APP_LIGHT_LIGHTNESS_SETUP_SERVER_DEF(m_light_lightness_server_0,
APP_FORCE_SEGMENTATION,
APP_MIC_SIZE,
set_lightness_cb,
get_lightness_cb,
transition_time_lightness_cb)
/* Scene Setup server structure definition and initialization */
APP_SCENE_SETUP_SERVER_DEF(m_scene_server_0,
APP_MIC_SIZE,
scene_transition_lightness_cb,
&m_light_lightness_server_0.light_lightness_setup_server.generic_ponoff_setup_srv.generic_dtt_srv)
/* Application variable for holding instantaneous lightness value */
static uint16_t m_pwm0_present_actual_lightness;
/* PWM hardware instance and associated variables */
/* Note: PWM cycle period determines the the max value that can be used to represent 100%
* duty cycles, therefore value scaling is required to get pwm tick value
* between 0 and max.
static APP_PWM_INSTANCE(PWM0, 1);
static app_pwm_config_t m_pwm0_config = APP_PWM_DEFAULT_CONFIG_1CH(200, led);
static pwm_utils_contex_t m_pwm = {
.p_pwm = &PWM0,
.p_pwm_config = &m_pwm0_config,
.channel = 0
/* Private function definitions. */
/* Callback for updating the hardware state */
m_pwm0_present_actual_lightness = lightness;
(void)pwm_utils_level_set_unsigned(&m_pwm, m_pwm0_present_actual_lightness);
/* Callback for reading the hardware state */
*p_lightness = (m_pwm0_present_actual_lightness);
/* Callback for receiveing transition time. */
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target lightness: %d\n",
transition_time_ms, target_lightness);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Transition time: %d, Target Scene: %d\n",
transition_time_ms, target_scene);
static void models_init_cb(void)
/* Initialize the Light Lightness Setup Server */
APP_ERROR_CHECK(app_light_lightness_model_init(&m_light_lightness_server_0, APP_LL_ELEMENT_INDEX));
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App Light Lightness Model handle: %d, Element index: %d\n",
m_light_lightness_server_0.light_lightness_setup_server.model_handle,
m_light_lightness_server_0.light_lightness_setup_server.settings.element_index);
/* Instantiate scene server and register light lightness server to have scene support */
ERROR_CHECK(app_scene_model_init(&m_scene_server_0, APP_LL_ELEMENT_INDEX));
ERROR_CHECK(app_scene_model_add(&m_scene_server_0, &m_light_lightness_server_0.scene_if));
ERROR_CHECK(app_light_lightness_scene_context_set(&m_light_lightness_server_0,
&m_scene_server_0));
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App Scene Model handle: %d, Element index: %d\n",
m_scene_server_0.scene_setup_server.model_handle,
m_scene_server_0.scene_setup_server.settings.element_index);
if (p_evt->type == NRF_MESH_EVT_ENABLED)
/* The onpowerup/last/actual binding is required at boot time to restore the correct state
* of the lightness model. */
APP_ERROR_CHECK(app_light_lightness_binding_setup(&m_light_lightness_server_0));
#if NRF_MESH_LOG_ENABLE
else if (p_evt->type == NRF_MESH_EVT_CONFIG_LOAD_FAILURE)
const nrf_mesh_evt_config_load_failure_t * p_details = &p_evt->params.config_load_failure;
__LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Corrupted entry: file:%d record:%d reason:%d\n",
p_details->id.file, p_details->id.record, p_details->reason);
__LOG_XB(LOG_SRC_APP, LOG_LEVEL_DBG1, "Raw data:", (const uint8_t *)p_details->p_data, p_details->data_len);
static bool fw_updated_event_is_for_me(const nrf_mesh_evt_dfu_t * p_evt)
switch (p_evt->fw_outdated.transfer.dfu_type)
case NRF_MESH_DFU_TYPE_APPLICATION:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "DFU type Application\n");
return (p_evt->fw_outdated.current.application.app_id == p_evt->fw_outdated.transfer.id.application.app_id &&
p_evt->fw_outdated.current.application.company_id == p_evt->fw_outdated.transfer.id.application.company_id &&
p_evt->fw_outdated.current.application.app_version < p_evt->fw_outdated.transfer.id.application.app_version);
case NRF_MESH_DFU_TYPE_BOOTLOADER:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "DFU type Bootloader\n");
return (p_evt->fw_outdated.current.bootloader.bl_id == p_evt->fw_outdated.transfer.id.bootloader.bl_id &&
p_evt->fw_outdated.current.bootloader.bl_version < p_evt->fw_outdated.transfer.id.bootloader.bl_version);
case NRF_MESH_DFU_TYPE_SOFTDEVICE:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "DFU type Softdevice\n");
return false;
return false;
static const uint32_t * optimal_bank_address(void)
/* The incoming transfer has to fit on both sides of the bank address: First it needs to fit
* above the bank address when we receive it, then it needs to fit below the bank address when
* we install it. We want to put the bank address in the middle of the available application
* code area, to maximize the potential transfer size we can accept. */
const uint32_t * p_start;
uint32_t dummy;
ERROR_CHECK(mesh_stack_persistence_flash_usage(&p_start, &dummy));
uint32_t middle_of_app_area = (CODE_START + (intptr_t) p_start) / 2;
/* The bank can't start in the middle of the application code, and should be page aligned: */
return (const uint32_t *) ALIGN_VAL(MAX(middle_of_app_area, CODE_END), PAGE_SIZE);
static void mesh_evt_handler(const nrf_mesh_evt_t* p_evt)
switch (p_evt->type)
case NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED:
case NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH:
if (fw_updated_event_is_for_me(&p_evt->params.dfu))
const uint32_t * p_bank = optimal_bank_address();
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Requesting DFU transfer with bank at 0x%p\n", p_bank);
ERROR_CHECK(nrf_mesh_dfu_request(p_evt->params.dfu.fw_outdated.transfer.dfu_type,
&p_evt->params.dfu.fw_outdated.transfer.id,
p_bank));
* While preparing for the start of the DFU process, the DFU module
* will notify about any other ongoing DFU transfers by sending
* @ref NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH or
* @ref NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED.
* Check the current DFU state to avoid reverting the target state
* to the relay state.
nrf_mesh_dfu_transfer_state_t state;
uint32_t error_code = nrf_mesh_dfu_state_get(&state);
if (error_code == NRF_SUCCESS && (state.state == NRF_MESH_DFU_STATE_INITIALIZED ||
state.state == NRF_MESH_DFU_STATE_FIND_FWID ||
state.state == NRF_MESH_DFU_STATE_RELAY_CANDIDATE ||
state.state == NRF_MESH_DFU_STATE_RELAY))
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Starting relay\n");
ERROR_CHECK(nrf_mesh_dfu_relay(p_evt->params.dfu.fw_outdated.transfer.dfu_type,
&p_evt->params.dfu.fw_outdated.transfer.id));
case NRF_MESH_EVT_DFU_START:
case NRF_MESH_EVT_DFU_END:
case NRF_MESH_EVT_DFU_BANK_AVAILABLE:
ERROR_CHECK(nrf_mesh_dfu_bank_flash(p_evt->params.dfu.bank.transfer.dfu_type));
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
model_config_file_clear();
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
static const char m_usage_string[] =
"\n"
"\t\t--------------------------------------------------------------\n"
"\t\t RTT 1) Decrease LED state, until min value is reached.\n"
"\t\t RTT 2) Increase LED state, until max value is reached.\n"
"\t\t RTT 4) Clear all the states to reset the node.\n"
"\t\t--------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
/* Increase button number because the buttons on the board is marked with 1 to 4 */
button_number++;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
switch (button_number)
/* Sending value `1` or `2` via RTT will result in LED state to change and trigger
the STATUS message to inform client about the state change. This is a demonstration of
state change publication due to local event. */
case 1:
m_pwm0_present_actual_lightness = MAX(0, (int32_t)m_pwm0_present_actual_lightness - APP_LIGHTNESS_STEP_SIZE);
case 2:
m_pwm0_present_actual_lightness = MIN(UINT16_MAX,
(int32_t)m_pwm0_present_actual_lightness + APP_LIGHTNESS_STEP_SIZE);
/* Initiate node reset */
case 4:
/* Clear all the states to reset the node. */
if (mesh_stack_is_device_provisioned())
#if MESH_FEATURE_GATT_PROXY_ENABLED
(void) proxy_stop();
mesh_stack_config_clear();
node_reset();
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "The device is unprovisioned. Resetting has no effect.\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
if (button_number == 1 || button_number == 2)
uint32_t status = app_light_lightness_current_value_publish(&m_light_lightness_server_0);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "lightness: %d\n", m_pwm0_present_actual_lightness);
if ( status != NRF_SUCCESS)
__LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Unable to publish status message, status: %d\n", status);
static void app_rtt_input_handler(int key)
if (key >= '1' && key <= '4')
uint32_t button_number = key - '1';
button_event_handler(button_number);
static void unicast_address_print(void)
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
/* Restores the application parameters after switching from the Provisioning service to the
* Proxy */
gap_params_init();
conn_params_init();
unicast_address_print();
static void mesh_init(void)
/* Initialize the application storage for models */
model_config_file_init();
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = NULL,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
if (status == NRF_SUCCESS)
/* Check if application stored data is valid, if not clear all data and use default values. */
status = model_config_file_config_apply();
switch (status)
case NRF_ERROR_INVALID_DATA:
/* Clear model config file as loading failed */
"Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
case NRF_SUCCESS:
APP_ERROR_CHECK(status);
#if NRF_MESH_SERIAL_ENABLE
ERROR_CHECK(nrf_mesh_serial_init(NULL));
m_evt_handler.evt_cb = mesh_evt_handler;
nrf_mesh_evt_handler_add(&m_evt_handler);
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Lightness Setup Server Demo -----\n");
pwm_utils_enable(&m_pwm);
APP_ERROR_CHECK(app_timer_init());
ble_stack_init();
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_complete_cb = provisioning_complete_cb,
.prov_device_identification_start_cb = NULL,
.prov_device_identification_stop_cb = NULL,
.prov_abort_cb = NULL,
.p_device_uri = EX_URI_LL_SERVER
APP_ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Enabling serial interface...\n");
ERROR_CHECK(nrf_mesh_serial_enable());
mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
/* NRF_MESH_EVT_ENABLED is triggered in the mesh IRQ context after the stack is fully enabled.
* This event is used to call Model APIs for establishing bindings and publish a model state information. */
nrf_mesh_evt_handler_add(&m_event_handler);
APP_ERROR_CHECK(mesh_stack_start());
/* Entry-point */
initialize();
start();
for (;;)
(void)sd_app_evt_wait();
DFU update using nrf Util tool:
Device output logs:
Device is provisioned using static provisioner.
Thanks
