direction_finding_connectionless_tx - MPU problem/stack
I get error about MPU error stack size while trying to run the example from ncs v2.7.0 on nrf52833dk
I was able to build correctly and I see in the log file that it gets error on MPU for some problems with the cache
I have not made any changes to the code
I am trying to transmit AOA and receive it on my UBLOX AOA antenna B10.
I was able to run UBLOX code example on nrf52833dk and it works
Thanks
Avi
  • Hi
    Please provide some details on the error you're seeing. Can you upload the logging file so we can take a look at exactly what this MPU error says and what the stack size error says.
    Most likely what is wrong is that you need to increase the CONFIG_MAIN_STACK_SIZE or CONFIG_BT_RX_STACK_SIZE in your prj.conf file.
    Simon
  • 00> [00:00:00.249,267] <dbg> mpu: region_init: [2] 0x20003740 0x150b000a
    00> [00:00:00.249,298] <dbg> bt_hci_core: hci_tx_thread: Started
    00> [00:00:00.249,298] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 1 events
    00> [00:00:00.249,328] <dbg> mpu: mpu_configure_region: Configure MPU region at index 0x2
    00> [00:00:00.249,328] <dbg> mpu: region_allocate_and_init: Program MPU region at index 0x2
    00> [00:00:00.249,359] <dbg> mpu: region_init: [2] 0x20004e80 0x150b000a
    00> [00:00:00.249,420] <dbg> os: setup_thread_stack: stack 0x20003a80 for thread 0x20000988: obj_size=1280 buf_start=0x20003ac0 buf_size 1216 stack_ptr=0x20003f80
    00> [00:00:00.249,450] <dbg> mpu: mpu_configure_region: Configure MPU region at index 0x2
    00> [00:00:00.249,450] <dbg> mpu: region_allocate_and_init: Program MPU region at index 0x2
    00> [00:00:00.249,481] <dbg> mpu: region_init: [2] 0x20003a80 0x150b000a
    00> [00:00:00.249,511] <dbg> mpu: mpu_configure_region: Configure MPU region at index 0x2
    00> [00:00:00.249,542] <dbg> mpu: region_allocate_and_init: Program MPU region at index 0x2
    00> [00:00:00.249,542] <dbg> mpu: region_init: [2] 0x20004e80 0x150b000a
    00> [00:00:00.249,633] <dbg> mpu: mpu_configure_region: Configure MPU region at index 0x2
    00> [00:00:00.249,664] <dbg> mpu: region_allocate_and_init: Program MPU region at index 0x2
    00> [00:00:00.249,664] <dbg> mpu: region_init: [2] 0x20003400 0x150b000a
    00> [00:00:00.248,962] <dbg> mpu: region_init: [2] 0x20006ec0 0x150b000a
    00> [00:00:00.249,786] <err> os: ***** MPU FAULT *****
    00> [00:00:00.249,816] <err> os: Stacking error (context area might be not valid)
    00> [00:00:00.249,816] <err> os: Data Access Violation
    00>
    00> [00:00:00.249,816] <err> os: MMFAR Address: 0x20003438
    00> [00:00:00.249,847] <err> os: r0/a1: 0x95de2e74 r1/a2: 0x9ede1e6b r2/a3: 0xc21aabe9
    00> [00:00:00.249,877] <err> os: r3/a4: 0x0902ecd0 r12/ip: 0xff37f464 r14/lr: 0x2953c887
    00> [00:00:00.249,877] <err> os: xpsr: 0x21000000
    00> [00:00:00.249,908] <err> os: Faulting instruction address (r15/pc): 0x00014c98
    00> [00:00:00.249,938] <err> os: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
    00> [00:00:00.249,969] <err> os: Current thread: 0x20000448 (unknown)
    00> [00:00:01.373,321] <err> os: Halting system
  • After increasing the stack size, it started to run:
    Update CTE params...success
    Periodic advertising params set...success
    Enable CTE...success
    Periodic advertising enable...success
    Extended advertising enable...success
    Get extended advertising address...success
    Started extended*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    Starting Direction Finding periodic advertising Beacon Demo
    Bluetooth initialization...[00:00:00.257,324] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:00.257,354] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:00.257,385] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 3.6 Build 99
    [00:00:00.257,995] <inf> bt_hci_core: Identity: C0:12:9B:D4:B8:63 (random)
    [00:00:00.258,026] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x0000, manufacturer 0x0059
    [00:00:00.258,056] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0xffff
    success
    Advertising set create...success
    Started extended advertising as C0:12:9B:D4:B8:63 (random)
    Here is my prj.conf:
    CONFIG_BT=y
    CONFIG_BT_DEVICE_NAME="DF Connectionless Beacon App"
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_PER_ADV=y
    CONFIG_BT_BROADCASTER=y
    # Enable Direction Finding Feature including AoA and AoD
    CONFIG_BT_DF=y
    CONFIG_BT_DF_CONNECTIONLESS_CTE_TX=y
    CONFIG_LOG=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_MAIN_STACK_SIZE=8192
    But I dont see any reception by the AOA antenna made by UBLOX (B10). I can receive tags with UBLOX code which are programmed into the same nrf52833dk
    UBLOX told me that I can use Nordic tx tag with the code from the ncs - as I am doing now. But there is no recpetion
    What can be the reason?
  • Hi
    My guess for why you don't see it on the UBlox antenna is that there is some filter on the receiver side set to only pick up and accept transmissions from UBlox devices, so you need to find out what filters it is using. UBlox should probably know what these are. Also, do the UBlox code also work in a connectionless setup and don't connect to the device?
    Simon
  • Hi
    I am using the same nrf52833 device for both the UBLOX code and the code from Nordic. So it is not a "UBLOX device".
    As for the UBLOX code, I am not aware of any filter.
    The UBLOX code is provided at: https://github.com/u-blox/c209-aoa-tag
    It is a connectionless transmission
    In UBLOX code, I get also a eddystone transmission. Is it also part of the Nordic code?
    Thanks
    Avi
