NCS project occured error when running
After I flash my code,I get imformations as follow:
*** Booting nRF Connect SDK v3.5.99-ncs1 *** ***引导nRF Connect SDK v3.5.99-ncs1 ******引导nRF Connect SDK v3.5.99-ncs1 ******引导nRF Connect SDK v3.5.99-ncs1 ******引导nRF Connect SDK v3.5.99-ncs1 ***
1202 Start 1202年开始 1202年开始 1202年开始 1202年开始
I: 6 Sectors of 4096 bytes I: 6个扇区,4096字节I: 6个扇区,4096字节I: 6个扇区,4096字节I: 6个扇区,4096字节
I: alloc wra: 0, fb8 I:分配 wra:0,fb8 I:分配 wra:0,fb8 I:分配 wra:0,fb8 I:分配 wra:0,fb8
I: data wra: 0, 30
I: SoftDevice Controller build revision:  I: SoftDevice Controller build版本:I: SoftDevice Controller build版本:I: SoftDevice Controller build版本:I: SoftDevice Controller build版本:
I: 36 f0 e5 0e 87 68 48 fb |6....hH. I: 36 f0 e5 0e 87 68 48 fb |6....hH。I: 36 f0 e5 0e 87 68 48 fb |6....hH。I: 36 f0 e5 0e 87 68 48 fb |6....hH。I: 36 f0 e5 0e 87 68 48 fb |6....hH。
I: 02 fd 9f 82 cc 32 e5 7b |.....2.{
1202 Start
I: data wra: 0, 30
I: 91 b1 5c ed             |..\.
I: HW Platform: Nordic Semiconductor (0x0002)
I: HW Variant: nRF52x (0x0002)
I: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
I: No ID address. App must call settings_load()
I: Identity: EC:41:5C:CB:1E:AD (random)
I: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
I: LMP: version 5.4 (0x0d) subver 0x118f
* buffer overflow detected *
E: r0/a1:  0x00000002  r1/a2:  0x2000d200  r2/a3:  0x00000001
E: r3/a4:  0x0004ab91 r12/ip:  0x00000000 r14/lr:  0x000297b9
E:  xpsr:  0x61000000
E: s[ 0]:  0x00000008  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00025a87
E: s[ 4]:  0x00020000  s[ 5]:  0x00025a49  s[ 6]:  0x00000000  s[ 7]:  0x00000000
E: s[ 8]:  0x00000041  s[ 9]:  0x0003ff59  s[10]:  0x000000cb  s[11]:  0x2000d2b4
E: s[12]:  0x000000ad  s[13]:  0x000297b9  s[14]:  0x0004ab74  s[15]:  0x2000d2dc
E: fpscr:  0x00000000
E: Faulting instruction address (r15/pc): 0x000297c4
E: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0
E: Current thread: 0x20007d38 (main)
E: Resetting system
I can not understand it.Maybe about settings_load()?
The main function in my code as follow:
int main(void) int主要(空白)
  int err; int犯错;
  uint32_t blink_status = 0;
  struct dm_init_param init_param; struct dm_init_param;struct dm_init_param;
  printk("1202 Start\n"); printk(“1202年开始\ n”); printk(“1202年开始\ n”);
  err = dk_leds_init(); 错误 = dk_leds_init(); 错误 = dk_leds_init();
  if (err) {
 printk("LEDs init failed (err %d)\n", err); printk(" led init failed (err %d)\n", err);printk(" led init failed (err %d)\n", err);
 return 0; 返回0; 返回0;
  err = peer_init();
	int err;
	if (err) {
		return 0;
	err = peer_init();
	if (err) {
		printk("Peer init failed (err %d)\n", err);
		return 0;
	init_param.cb = &dm_cb;
	err = dm_init(&init_param);
	if (err) {
		printk("Distance measurement init failed (err %d)\n", err);
		return 0;
	err = service_ddfs_init();
	if (err) {
		printk("DDF Service init failed (err %d)\n", err);
		return 0;
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return 0;
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	char *name = namecat();
	err = bt_set_name(name);
	if (err)
		printk("Name set failed (err %d)\n",err);
		return 0;
	err = bt_sync_init();
	if (err) {
		printk("Synchronisation init failed (err %d)\n", err);
		return 0;
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
		service_azimuth_elevation_simulation();
