Hi.
There is MainThread and MeasureThread.
There are also two events that MainThread sends - BIT(0), BIT(1). These are Start and Stop.
In MeasureThread, we first wait for the Start event K_FOREVER, after which we get into another loop where we wait for Stop K_NO_WAIT.
The idea is to send a Start event when a Client connects via BE, which will wake up the thread.
This Thread will start sending notify via BE until it receives a Stop event when the client disconnects.
My problem is that when I sent the Stop event, it does not arrive, although Start did. What could this be related to?
I do not see the line "WT> Receive WT_STOP_EVENT"
#include <zephyr/types.h> #include <zephyr/kernel.h> #include <zephyr/bluetooth/bluetooth.h> #include <zephyr/bluetooth/hci.h> #include <zephyr/bluetooth/uuid.h> #include <zephyr/bluetooth/gatt.h> #include <zephyr/sys/printk.h> static uint8_t weight_value = 0; static struct bt_conn *connection_; #define WT_EXEC_EVENT BIT(0) #define WT_STOP_EVENT BIT(1) K_EVENT_DEFINE(measure_thread_event_); #define WT_STACK_SIZE 4096 K_THREAD_STACK_DEFINE(wt_stack, WT_STACK_SIZE); extern void wt_thread(void *, void *, void *); struct k_thread wt_data; static struct bt_uuid_128 service_uuid = BT_UUID_INIT_128( BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef0)); static struct bt_uuid_128 weight_char_uuid = BT_UUID_INIT_128( BT_UUID_128_ENCODE(0x87654321, 0x4321, 0x8765, 0x4321, 0xfedcba987654)); static ssize_t read_weight(struct bt_conn *conn, const struct bt_gatt_attr *attr, void *buf, uint16_t len, uint16_t offset) { const uint8_t *value = attr->user_data; return bt_gatt_attr_read(conn, attr, buf, len, offset, value, sizeof(weight_value)); } static void bt_read_weight_cfg_changed(const struct bt_gatt_attr *attr, uint16_t value) { bool notif_enabled = (value == BT_GATT_CCC_NOTIFY); printk("BT> Notifications %s\n", notif_enabled ? "enabled" : "disabled"); } BT_GATT_SERVICE_DEFINE(service, BT_GATT_PRIMARY_SERVICE(&service_uuid), BT_GATT_CHARACTERISTIC(&weight_char_uuid.uuid, BT_GATT_CHRC_NOTIFY | BT_GATT_CHRC_READ, BT_GATT_PERM_READ, read_weight, NULL, &weight_value), BT_GATT_CCC(bt_read_weight_cfg_changed, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE), ); static void connected(struct bt_conn *conn, uint8_t err) { if (err) { printk("BT> Connection failed (err %u)\n", err); return; } if (connection_) { printk("BT> Only one connection is allowed at a time.\n"); return; } printk("BT> Connected\n"); connection_ = bt_conn_ref(conn); printk("BT> Send WT_EXEC_EVENT\n"); k_event_set(&measure_thread_event_, WT_EXEC_EVENT); } static void disconnected(struct bt_conn *conn, uint8_t reason) { printk("BT> Disconnected (reason %u)\n", reason); if (!connection_) { printk("BT> No active connection\n"); } else { printk("BT> Send WT_STOP_EVENT\n"); k_event_set(&measure_thread_event_, WT_STOP_EVENT); } } BT_CONN_CB_DEFINE(conn_callbacks) = { .connected = connected, .disconnected = disconnected, }; int main(void) { printk("BT> Starting Bluetooth Peripheral\n"); int error; error = bt_enable(NULL); if (error) { printk("BT> Bluetooth init failed (err %d)\n", error); return -1; } printk("BT> Bluetooth initialized\n"); k_tid_t my_tid = k_thread_create(&wt_data, wt_stack, K_THREAD_STACK_SIZEOF(wt_stack), wt_thread, NULL, NULL, NULL, /*lowPrio=*/7, /*options=*/0, K_NO_WAIT); error = bt_le_adv_start(BT_LE_ADV_CONN, NULL, 0, NULL, 0); if (error) { printk("BT> Advertising failed to start (err %d)\n", error); return -1; } printk("BT> Advertising successfully started\n"); k_thread_suspend(k_current_get()); return 0; } void wt_thread(void *, void *, void *) { while (1) { uint32_t events = k_event_wait(&measure_thread_event_, WT_EXEC_EVENT, true, K_FOREVER); if (events & WT_EXEC_EVENT) { printk("WT> Received WT_EXEC_EVENT\n"); if (!connection_) { printk("WT> No active connection\n"); return; } exec(); printk("WT> Completed\n"); bt_conn_unref(connection_); connection_ = NULL; } } } void exec() { while (1) { uint32_t events = k_event_wait(&measure_thread_event_, WT_STOP_EVENT, false, K_NO_WAIT); if (events & WT_STOP_EVENT) { printk("WT> Receive WT_STOP_EVENT\n"); return; } weight_value++; printk("WT> Notify %d\n", weight_value); //bt_gatt_notify(NULL, &service.attrs[1], &weight_value, sizeof(weight_value)); k_sleep(K_MSEC(500)); } }
