I edded the multi cloud serves to fit my needes. When the divice sends GNSS data after fix it looks like this:
"Received":{4 items
"messageType":"DATA"
"appId":"GNSS"
"data":{3 items
"lat":51.832831879576325
"lng":4.849055562212727
"acc":9.889153480529785
"ts":1723624845580
When a massage is sent from temperature if I remember it correctly (now it is V for voltage) it looks like this:
"Received":{4 items
"appId":"V"
"data":38.413185119628906
"ts":1723624845562
I removed the queueing application and have another way to handle the not send messages.
static int send_sensor_sample(const char *const sensor, double value){
int ret;
MSG_OBJ_DEFINE(msg_obj);
ret = create_timestamped_device_message(&msg_obj, sensor, NRF_CLOUD_JSON_MSG_TYPE_VAL_DATA);
if (ret) {
return -EINVAL;
/* Populate the container object with the sensor value. */
ret = nrf_cloud_obj_num_add(&msg_obj, NRF_CLOUD_JSON_DATA_KEY, value, false);
if (ret) {
LOG_ERR("Failed to append value to %s sample container object ",
sensor);
nrf_cloud_obj_free(&msg_obj);
return -ENOMEM;
int err = nrf_cloud_coap_obj_send(&msg_obj, IS_ENABLED(CONFIG_COAP_SEND_CONFIRMABLE));
if (err < 0) {
LOG_ERR("Failed to send %s sample, error: %d", sensor, err);
return err;
I call this function a few times and every time the data is put in its own massage. Now I want to add all data in one massage somewhat like the GNSS data. I tried calling nrf_cloud_obj_num_add() multiple times and using nrf_cloud_obj_str_array_add() with a return err that it can't encode unknown type.
