Device id 99 00 83 does not match config 9d 60 18
I try to implement little fs to my external flash memory. I am using nrf52832 board and my memory is IS25LP128.
Without the connection of the memory the nrf board sends proper signal, that I found by logic analyzer. However after connecting the memory I found that
E: Device id 99 00 83 does not match config 9d 60 18
I: littlefs partition at /lfs1
I: LittleFS version 2.8, disk version 2.1
E: can't open flash area 0
E: fs mount error (-19)
E: Automount /lfs1 failed: -19
Please help me with that. Thank you.
Regards
Farhan
 * Copyright (c) 2022 Lukasz Majewski, DENX Software Engineering GmbH
 * Copyright (c) 2019 Peter Bigot Consulting, LLC
/* Sample which uses the filesystem API with littlefs */
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/fs/fs.h>
#include <zephyr/fs/littlefs.h>
#include <zephyr/storage/flash_map.h>
#include <zephyr/settings/settings.h>
 * Copyright (c) 2020 Circuit Dojo, LLC
/* Matches LFS_NAME_MAX */
#define MAX_PATH_LEN 255
/* Config */
struct system_config
	int32_t update_interval;
	int32_t status;
static struct system_config cfg = {
	.update_interval = 0,
	.status = 0,
FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
static struct fs_mount_t lfs_storage_mnt = {
	.type = FS_LITTLEFS,
	.fs_data = &storage,
	.storage_dev = (void *)FLASH_AREA_ID(littlefs_storage),
	.mnt_point = "/lfs",
static int test_settings_set(const char *name, size_t len,
							 settings_read_cb read_cb, void *cb_arg)
	const char *next;
	int rc;
	if (settings_name_steq(name, "entry", &next) && !next)
		if (len != sizeof(cfg))
			return -EINVAL;
		rc = read_cb(cb_arg, &cfg, sizeof(cfg));
		if (rc >= 0)
			/* key-value pair was properly read.
			 * rc contains value length.
			return 0;
		/* read-out error */
		return rc;
	return -ENOENT;
struct settings_handler my_config = {
	.name = "config",
	.h_set = test_settings_set,
int main()
	struct fs_mount_t *mp = &lfs_storage_mnt;
	unsigned int id = (uintptr_t)mp->storage_dev;
	char fname[MAX_PATH_LEN];
	struct fs_statvfs sbuf;
	const struct flash_area *pfa;
	int rc;
	snprintf(fname, sizeof(fname), "%s/boot_count", mp->mnt_point);
	rc = flash_area_open(id, &pfa);
	if (rc < 0)
		printk("FAIL: unable to find flash area %u: %d\n",
			   id, rc);
		return -1;
	printk("Area %u at 0x%x for %u bytes\n",
		   id, (unsigned int)pfa->fa_off, (unsigned int)pfa->fa_size);
	/* Optional wipe flash contents */
	if (IS_ENABLED(CONFIG_APP_WIPE_STORAGE))
		printk("Erasing flash area ... ");
		rc = flash_area_erase(pfa, 0, pfa->fa_size);
		printk("%d\n", rc);
	flash_area_close(pfa);
	rc = fs_mount(mp);
	if (rc < 0)
		printk("FAIL: mount id %u at %s: %d\n",
			   (unsigned int)mp->storage_dev, mp->mnt_point,
			   rc);
		return -1;
	printk("%s mount: %d\n", mp->mnt_point, rc);
	rc = fs_statvfs(mp->mnt_point, &sbuf);
	if (rc < 0)
		printk("FAIL: statvfs: %d\n", rc);
		goto out;
	printk("%s: bsize = %lu ; frsize = %lu ;"
		   " blocks = %lu ; bfree = %lu\n",
		   mp->mnt_point,
		   sbuf.f_bsize, sbuf.f_frsize,
		   sbuf.f_blocks, sbuf.f_bfree);
	/*struct fs_dirent dirent;
	rc = fs_stat(fname, &dirent);
	printk("%s stat: %d\n", fname, rc);
	if (rc >= 0)
		printk("\tfn '%s' siz %u\n", dirent.name, dirent.size);
	struct fs_file_t file;
	rc = fs_open(&file, fname, FS_O_CREATE | FS_O_RDWR);
	if (rc < 0)
		printk("FAIL: open %s: %d\n", fname, rc);
		goto out;
	uint32_t boot_count = 0;
	if (rc >= 0)
		rc = fs_read(&file, &boot_count, sizeof(boot_count));
		printk("%s read count %u: %d\n", fname, boot_count, rc);
		rc = fs_seek(&file, 0, FS_SEEK_SET);
		printk("%s seek start: %d\n", fname, rc);
	boot_count += 1;
	rc = fs_write(&file, &boot_count, sizeof(boot_count));
	printk("%s write new boot count %u: %d\n", fname,
		   boot_count, rc);
	rc = fs_close(&file);
	printk("%s close: %d\n", fname, rc);
	/* Using settings subsystem */
	/*settings_subsys_init();
	settings_register(&my_config);
	settings_load();
	printk("Settings: before: status %i, interval: %i\n", cfg.status, cfg.update_interval);
	cfg.status += 1;
	cfg.update_interval = 20;
	printk("Settings: after: status %i, interval: %i\n", cfg.status, cfg.update_interval);
	settings_save_one("config/entry", &cfg, sizeof(cfg));
	/* End of setting related items */
out:
	rc = fs_unmount(mp);
	printk("%s unmount: %d\n", mp->mnt_point, rc);
	return 0;
      chosen {
          nordic,pm-ext-flash = &IS25LP128;
    &spi1 {
            compatible = "nordic,nrf-spi";
            status = "okay";
            cs-gpios = <&gpio0 28 GPIO_ACTIVE_LOW>;
            pinctrl-0 = <&spi1_default>;
            pinctrl-1 = <&spi1_sleep>;
            IS25LP128: IS25LP128@0 {
                       compatible = "jedec,spi-nor";
                       //status = "okay";
                       //label = "25LP128";
                       reg = <0>;
                       spi-max-frequency = <8000000>; /* Adjust based on your flash specifications */
                       jedec-id = [9D 60 18]; /* Adjust based on your flash JEDEC ID */
                       size = <134217728>; /* Adjust based on your flash size */
                       has-dpd;
                       t-enter-dpd = <3000>;
                       t-exit-dpd = <3000>;
    &pinctrl {
        spi1_default: spi1_default {
            group1 {
                psels = <NRF_PSEL(SPIM_SCK, 0, 31)>,
                        <NRF_PSEL(SPIM_MISO, 0, 29)>,
                        <NRF_PSEL(SPIM_MOSI, 0, 30)>;
        spi1_sleep: spi1_sleep {
            group1 {
    &IS25LP128 {
          partitions {
    		     #address-cells = <1>;
    		     #size-cells = <1>;
                lfs1_partition: partition@0 {
    			label = "lfs1_partition";
    			reg = <0x00000000 0x01000000>;
    	fstab {
    		compatible = "zephyr,fstab";
    		lfs1: lfs1 {
    			compatible = "zephyr,fstab,littlefs";
    			mount-point = "/lfs1";
    			partition = <&lfs1_partition>;
    			automount;
    			read-size = <16>;
    			prog-size = <16>;
    			cache-size = <64>;
    			lookahead-size = <32>;
    			block-cycles = <512>;
  • CONFIG_MAIN_STACK_SIZE=4096
    # SPI Flash
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_SPI_ASYNC=y
    CONFIG_SPI_SLAVE=y
    # Enable flash operations.
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    # Enable the LittleFS file system.
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # Enable Zephyr application to be booted by MCUboot
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Erase
    CONFIG_APP_WIPE_STORAGE=y
    # Log immediate
    CONFIG_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    # Settings
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FS=y
    CONFIG_SETTINGS_FS_DIR="/lfs/settings"
    CONFIG_SETTINGS_FS_FILE="/lfs/settings/run"
    # Partition manager settings
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
    # Let __ASSERT do its job
    CONFIG_DEBUG=y
    CONFIG_LOG_MODE_MINIMAL=y
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_PM_PARTITION_REGION_LITTLEFS_EXTERNAL=y
    #CONFIG_PM_PARTITION_REGION_SETTINGS_STORAGE_EXTERNAL=y
    #CONFIG_PM_PARTITION_REGION_NVS_STORAGE_EXTERNAL=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    # CONFIG_BOOTLOADER_MCUBOOT=y
    # Optionally force the file system to be recreated
    #CONFIG_APP_WIPE_STORAGE=y
    # fs_dirent structures are big.
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_SHELL=y
    CONFIG_SHELL_LOG_LEVEL_INF=y
    CONFIG_FILE_SYSTEM_SHELL=y
    Difficult to say what the problem can be based on the error code, but I could find two cases with similar symptoms, I suggest to check them out if they can help:
    External flash not working with simple example on nrf9160dk 1.0.0
    Zephyr flash_erase(w25q32jv@0, 524288, 4096) faild -19
    Kenneth
