Time out! failed to receive status response from Exchange
Board: nrf7002
Project: matter_light_blub
OS: Kubuntu 22
Toolchains: v2.6.1
SDK: v2.6.1
I am developing with the nrf7002, and my current setup involves using a Samsung A54 as the network gateway. I connect to Google Nest Mini via Google Home, and use a second phone as a controller to connect the device.
Initially, the device connects successfully, and the light bulb icon appears on Google Home. However, I cannot control the Matter device through my phone. It seems like a connection timeout, but I'm not sure which part is failing. I have verified that my phone’s network supports IPv6 through this URL: https://test-ipv6.com/index.html.en_US.
Here is the error message:
I: 152 [DL]BLE address: DB:36:89:99:96:07
D: 183 [DL]WiFiManager has been initialized
I: 188 [DL]CHIP task running
I: Init CHIP stack
D: 192 [DL]Connecting to WiFi network: Galaxy A54 5G E59B
D: 201 [DL]WiFi scanning started...
I: 204 [SVR]Subscription persistence not supported
I: 209 [SVR]Server initializing...
I: 214 [TS]Last Known Good Time: 2024-08-14T15:00:54
I: 222 [FP]Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x7BABAAB43C4053C0, FabricId 0x410B7D3944284516, NodeId 0x0000000019E9F7B2, VendorId 0x6006
I: 238 [DMG]AccessControl: initializing
I: 241 [DMG]Examples::AccessControlDelegate::Init
I: 246 [DMG]AccessControl: setting
I: 249 [DMG]DefaultAclStorage: initializing
I: 254 [DMG]DefaultAclStorage: 1 entries loaded
D: 258 [IN]UDP::Init bind&listen port=5540
D: 262 [IN]UDP::Init bound to port=5540
D: 265 [IN]BLEBase::Init - setting/overriding transport
D: 270 [IN]TransportMgr initialized
I: 278 [ZCL]Using ZAP configuration...
I: 285 [DMG]AccessControlCluster: initializing
D: 289 [DL]Boot reason: 1
I: 292 [ZCL]Initiating Admin Commissioning cluster.
I: Turn On Action has been initiated
I: Turn On Action has been completed
I: 303 [ZCL]Endpoint 1 On/off already set to new value
I: 308 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 314 [SVR]Fabric already commissioned. Disabling BLE advertisement
D: 320 [DL]CHIPoBLE advertising set to off
I: 324 [DIS]Updating services using commissioning mode 0
I: 331 [DIS]CHIP minimal mDNS started advertising.
D: 335 [DL]Using wifi MAC for hostname
I: 339 [DIS]Advertise operational node 7BABAAB43C4053C0-0000000019E9F7B2
D: 345 [DIS]Responding with _matter._tcp.local
D: 350 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 357 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 364 [DIS]Responding with F4CE360024AE.local
D: 368 [DIS]Responding with F4CE360024AE.local
D: 372 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
I: 378 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-0000000019E9F7B2.
I: 389 [DIS]mDNS service published: _matter._tcp
I: 393 [IN]CASE Server enabling CASE session setups
D: 398 [IN]SecureSession[0x20004530]: Allocated Type:2 LSID:32755
I: 404 [SVR]Joining Multicast groups
I: 408 [SVR]Server Listening...
I: 411 [DL]Device Configuration:
I: 414 [DL]  Serial Number: 11223344556677889900
I: 419 [DL]  Vendor Id: 65521 (0xFFF1)
I: 422 [DL]  Product Id: 32773 (0x8005)
I: 426 [DL]  Product Name: not-specified
I: 429 [DL]  Hardware Version: 0
I: 432 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 438 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 444 [DL]  Manufacturing Date: 2022-01-01
I: 448 [DL]  Device Type: 65535 (0xFFFF)
I: 452 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 457 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 464 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 475 [SVR]Manual pairing code: [34970112332]
E: 481 [DL]Long dispatch time: 291 ms, for event type 2
I: 487 [ZCL]Cluster OnOff: attribute OnOff set to 1
I: 492 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 4819 [DL]Wi-Fi scan done (0)
I: 6362 [DL]Connection to Galaxy A54 5G E59B requested [RSSI=-81]
E: 6367 [DL]Long dispatch time: 1548 ms, for event type 3
I: 11122 [DL]Connected to WiFi network
I: 11133 [SWU]Stopping the watchdog timer
I: 11137 [SWU]Starting the periodic query timer, timeout: 86400 seconds
I: 11143 [SVR]Server initialization complete
I: 11147 [DIS]Updating services using commissioning mode 0
I: 11154 [DIS]CHIP minimal mDNS started advertising.
D: 11165 [DL]Using wifi MAC for hostname
I: 11169 [DIS]Advertise operational node 7BABAAB43C4053C0-0000000019E9F7B2
D: 11176 [DIS]Responding with _matter._tcp.local
D: 11180 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 11191 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 11198 [DIS]Responding with F4CE360024AE.local
D: 11202 [DIS]Responding with F4CE360024AE.local
D: 11207 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
I: 11213 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-0000000019E9F7B2.
I: 11227 [DIS]mDNS service published: _matter._tcp
I: 11232 [DIS]Updating services using commissioning mode 0
I: 11238 [DIS]CHIP minimal mDNS started advertising.
D: 11249 [DL]Using wifi MAC for hostname
I: 11254 [DIS]Advertise operational node 7BABAAB43C4053C0-0000000019E9F7B2
D: 11261 [DIS]Responding with _matter._tcp.local
D: 11265 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 11272 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 11279 [DIS]Responding with F4CE360024AE.local
D: 11284 [DIS]Responding with F4CE360024AE.local
D: 11289 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
I: 11296 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-0000000019E9F7B2.
I: 11309 [DIS]mDNS service published: _matter._tcp
I: 11960 [DIS]Updating services using commissioning mode 0
I: 11966 [DIS]CHIP minimal mDNS started advertising.
D: 11978 [DL]Using wifi MAC for hostname
I: 11983 [DIS]Advertise operational node 7BABAAB43C4053C0-0000000019E9F7B2
D: 11989 [DIS]Responding with _matter._tcp.local
D: 11994 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 12001 [DIS]Responding with 7BABAAB43C4053C0-0000000019E9F7B2._matter._tcp.local
D: 12009 [DIS]Responding with F4CE360024AE.local
D: 12014 [DIS]Responding with F4CE360024AE.local
D: 12018 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
I: 12025 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-0000000019E9F7B2.
I: 12038 [DIS]mDNS service published: _matter._tcp
E: 27785 [IN]Data received on an unknown session (LSID=38411). Dropping it!
E: 29147 [IN]Data received on an unknown session (LSID=38411). Dropping it!
E: 30256 [IN]Data received on an unknown session (LSID=38411). Dropping it!
E: 32426 [IN]Data received on an unknown session (LSID=38411). Dropping it!
I: 35673 [EM]>>> [E:63190r S:0 M:54146442] (U) Msg RX from 0:5052798BBE69948A [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 35684 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005e50
I: 35692 [EM]<<< [E:63190r S:0 M:51696349 (Ack:54146442)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::ae67:84ff:fe35:31f8]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 35709 [SC]Received Sigma1 msg
I: 35717 [EM]<<< [E:63190r S:0 M:51696350 (Ack:54146442)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::ae67:84ff:fe35:31f8]:5540] --- Type 0000:33 (SecureChannel:CASE_Sigma2Resume)
I: 35746 [EM]>>> [E:63190r S:0 M:54146443 (Ack:51696350)] (U) Msg RX from 0:5052798BBE69948A [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 35759 [SC]Success status report received. Session was established
I: 35770 [SC]SecureSession[0x20004530, LSID:32755]: State change 'kEstablishing' --> 'kActive'
D: 35778 [IN]SecureSession[0x20004530]: Activated - Type:2 LSID:32755
D: 35784 [IN]New secure session activated for device <000000004E8206DB, 1>, LSID:32755 PSID:27606!
I: 35793 [IN]CASE Session established to peer: <000000004E8206DB, 1>
D: 35800 [IN]SecureSession[0x200045f0]: Allocated Type:2 LSID:32756
I: 35806 [EM]<<< [E:63190r S:0 M:51696351 (Ack:54146443)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::ae67:84ff:fe35:31f8]:5540] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 35824 [EM]>>> [E:63191r S:32755 M:180485541] (S) Msg RX from 1:000000004E8206DB [53C0] --- Type 0001:03 (IM:SubscribeRequest)
D: 35838 [IM]Received Subscribe request
I: 35842 [DMG]Final negotiated min/max parameters: Min = 0s, Max = 30s
E: 35854 [DMG]Error retrieving data from clusterId: 0x0000_0028, err = b
I: 35868 [EM]<<< [E:63191r S:32755 M:237850087 (Ack:180485541)] (S) Msg TX to 1:000000004E8206DB [53C0] [UDP:[fe80::ae67:84ff:fe35:31f8]:5540] --- Type 0001:05 (IM:ReportData)
I: 35995 [EM]>>> [E:63191r S:32755 M:180485542 (Ack:237850087)] (S) Msg RX from 1:000000004E8206DB [53C0] --- Type 0001:01 (IM:StatusResponse)
I: 36008 [IM]Received status response, status is 0x00
E: 36021 [DMG]Error retrieving data from clusterId: 0x0000_0031, err = b
I: 36033 [EM]<<< [E:63191r S:32755 M:237850088 (Ack:180485542)] (S) Msg TX to 1:000000004E8206DB [53C0] [UDP:[fe80::ae67:84ff:fe35:31f8]:5540] --- Type 0001:05 (IM:ReportData)
I: 36441 [EM]Retransmitting MessageCounter:237850088 on exchange 63191r Send Cnt 1
I: 36859 [EM]Retransmitting MessageCounter:237850088 on exchange 63191r Send Cnt 2
I: 37503 [EM]Retransmitting MessageCounter:237850088 on exchange 63191r Send Cnt 3
I: 38494 [EM]Retransmitting MessageCounter:237850088 on exchange 63191r Send Cnt 4
E: 40121 [EM]Failed to Send CHIP MessageCounter:237850088 on exchange 63191r sendCount: 4 max retries: 4
D: 42251 [IN]SecureSession[0x20004530]: MarkAsDefunct Type:2 LSID:32755
I: 42258 [SC]SecureSession[0x20004530, LSID:32755]: State change 'kActive' --> 'kDefunct'
E: 42266 [DMG]Time out! failed to receive status response from Exchange: 63191r
    Are you trying to control the Matter device using the Google Home app on your phone, or are you using something else on your phone to control the device?
    Is the phone on the same Wi-Fi network as the nRF7002 and the Google Nest Mini?
    Marte
  • Yes, I am using the Google Home app on a second phone, a Samsung A30, to control the device. I am adding the device by scanning a QR code. I just checked and found that the nRF7002 is not connected to the network.
    I borrowed an iPhone SE and installed Google Home in the same way, using a QR code to add the device, but I am unable to add the device.
    Thank you for your reply.
    Have you added the test Vendor ID and Product ID to Google Home Developer Console?
    Please follow the steps in the Matter: Testing the nRF Connect platform with Apple, Google and Samsung ecosystems tutorial for detailed setup and testing instructions for testing with commercial Matter ecosystems.
    Marte
  • I just set the test Vendor ID and Product ID in the Google Home Developer Console. After attempting to connect, I encountered an error stating that it cannot connect to the device, even though I have confirmed that the phone is connected to the Wi-Fi network.
    Here is the error log:
    uart:~$ *** Booting nRF Connect SDK 3758bcbfa5cd ***
    I: 157 [DL]BLE address: EF:19:3A:E1:04:DC
    D: 188 [DL]WiFiManager has been initialized
    I: 193 [DL]CHIP task running
    I: Init CHIP stack
    I: 197 [SVR]Subscription persistence not supported
    I: 202 [SVR]Server initializing...
    I: 205 [TS]Last Known Good Time: [unknown]
    I: 209 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48
    I: 217 [DMG]AccessControl: initializing
    I: 221 [DMG]Examples::AccessControlDelegate::Init
    I: 225 [DMG]AccessControl: setting
    I: 228 [DMG]DefaultAclStorage: initializing
    I: 232 [DMG]DefaultAclStorage: 0 entries loaded
    D: 236 [IN]UDP::Init bind&listen port=5540
    D: 240 [IN]UDP::Init bound to port=5540
    D: 244 [IN]BLEBase::Init - setting/overriding transport
    D: 249 [IN]TransportMgr initialized
    I: 256 [ZCL]Using ZAP configuration...
    I: 261 [DMG]AccessControlCluster: initializing
    D: 265 [DL]Boot reason: 1
    I: 268 [ZCL]Initiating Admin Commissioning cluster.
    I: 273 [ZCL]Endpoint 1 On/off already set to new value
    I: 278 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 1
    D: 285 [IN]SecureSession[0x20004530]: Allocated Type:1 LSID:62818
    D: 291 [DL]CHIPoBLE advertising set to on
    I: 294 [DIS]Updating services using commissioning mode 1
    I: 300 [DIS]CHIP minimal mDNS started advertising.
    D: 304 [DL]Using wifi MAC for hostname
    I: 308 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
    D: 317 [DIS]Responding with _matterc._udp.local
    D: 321 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    D: 327 [DIS]Responding with F4CE360024AE.local
    D: 331 [DIS]Responding with F4CE360024AE.local
    D: 335 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 341 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 346 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 351 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 356 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    I: 362 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 847893369ED20FC9.
    I: 371 [DIS]mDNS service published: _matterc._udp
    I: 376 [DIS]Updating services using commissioning mode 1
    I: 381 [DIS]CHIP minimal mDNS started advertising.
    D: 386 [DL]Using wifi MAC for hostname
    I: 389 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
    D: 398 [DIS]Responding with _matterc._udp.local
    D: 402 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    D: 408 [DIS]Responding with F4CE360024AE.local
    D: 412 [DIS]Responding with F4CE360024AE.local
    D: 416 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 422 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 427 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 432 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 438 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    I: 443 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 847893369ED20FC9.
    I: 453 [DIS]mDNS service published: _matterc._udp
    I: 457 [IN]CASE Server enabling CASE session setups
    D: 462 [IN]SecureSession[0x200045f0]: Allocated Type:2 LSID:62819
    I: 468 [SVR]Joining Multicast groups
    I: 471 [SVR]Server Listening...
    I: 474 [DL]Device Configuration:
    I: 477 [DL]  Serial Number: 11223344556677889900
    I: 481 [DL]  Vendor Id: 65521 (0xFFF1)
    I: 485 [DL]  Product Id: 32773 (0x8005)
    I: 488 [DL]  Product Name: not-specified
    I: 492 [DL]  Hardware Version: 0
    I: 495 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
    I: 500 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
    I: 507 [DL]  Manufacturing Date: 2022-01-01
    I: 510 [DL]  Device Type: 65535 (0xFFFF)
    I: 514 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
    I: 518 [SVR]Copy/paste the below URL in a browser to see the QR Code:
    I: 525 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
    I: 533 [SVR]Manual pairing code: [34970112332]
    E: 538 [DL]Long dispatch time: 343 ms, for event type 2
    I: 543 [ZCL]Cluster OnOff: attribute OnOff set to 0
    I: 548 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
    I: 558 [DL]CHIPoBLE advertising started
    I: 561 [DL]NFC Tag emulation started
    I: 30561 [DL]CHIPoBLE advertising mode changed to slow
    I: 30570 [DL]CHIPoBLE advertising started
    I: 103942 [DL]Current number of connections: 1/1
    I: 103947 [DL]BLE connection established (ConnId: 0x00)
    I: 103952 [DL]CHIPoBLE advertising stopped
    I: 103956 [DL]NFC Tag emulation stopped
    D: 104682 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 104689 [BLE]local and remote recv window sizes = 5
    I: 104694 [BLE]selected BTP version 4
    I: 104698 [BLE]using BTP fragment sizes rx 128 / tx 128.
    D: 104753 [DL]ConnId: 0x00, New CCCD value: 0x0002
    D: 104758 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
    D: 104766 [IN]BLE EndPoint 0x2000b188 Connection Complete
    I: 104771 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 131)
    D: 104978 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 105024 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 105032 [EM]>>> [E:32754r S:0 M:158200961] (U) Msg RX from 0:4CE9CE5C990CDE1B [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
    I: 105045 [EM]<<< [E:32754r S:0 M:139726206] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
    D: 105057 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    I: 105065 [SVR]Commissioning session establishment step started
    D: 105113 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 105121 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 18)
    D: 105247 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 105255 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 105263 [EM]>>> [E:32754r S:0 M:158200962] (U) Msg RX from 0:4CE9CE5C990CDE1B [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
    I: 106642 [EM]<<< [E:32754r S:0 M:139726207] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2)
    D: 106654 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    E: 106661 [DL]Long dispatch time: 1406 ms, for event type 16388
    D: 106732 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 106740 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6)
    D: 106822 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 106868 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 106876 [EM]>>> [E:32754r S:0 M:158200963] (U) Msg RX from 0:4CE9CE5C990CDE1B [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
    I: 106888 [EM]<<< [E:32754r S:0 M:139726208] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport)
    D: 106900 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35)
    I: 106908 [SC]SecureSession[0x20004530, LSID:62818]: State change 'kEstablishing' --> 'kActive'
    D: 106917 [IN]SecureSession[0x20004530]: Activated - Type:1 LSID:62818
    D: 106923 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:62818 PSID:43970!
    I: 106932 [SVR]Commissioning completed session establishment step
    I: 106938 [DIS]Updating services using commissioning mode 0
    I: 106943 [DIS]CHIP minimal mDNS started advertising.
    D: 106948 [DL]CHIPoBLE advertising set to off
    I: 106952 [SVR]Device completed Rendezvous process
    D: 106957 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107002 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107010 [EM]>>> [E:32755r S:62818 M:58771215] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107021 [IM]Received Read request
    I: 107026 [EM]<<< [E:32755r S:62818 M:95957429] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107037 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 97)
    D: 107137 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107145 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107153 [EM]>>> [E:32756r S:62818 M:58771216] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107164 [IM]Received Read request
    I: 107169 [EM]<<< [E:32756r S:62818 M:95957430] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107180 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 107272 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107280 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107288 [EM]>>> [E:32757r S:62818 M:58771217] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107299 [IM]Received Read request
    I: 107304 [EM]<<< [E:32757r S:62818 M:95957431] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107315 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 107407 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107415 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107423 [EM]>>> [E:32758r S:62818 M:58771218] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107434 [IM]Received Read request
    I: 107439 [EM]<<< [E:32758r S:62818 M:95957432] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107450 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 107542 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107550 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107558 [EM]>>> [E:32759r S:62818 M:58771219] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107569 [IM]Received Read request
    I: 107574 [EM]<<< [E:32759r S:62818 M:95957433] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107585 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 107677 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107685 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107693 [EM]>>> [E:32760r S:62818 M:58771220] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107704 [IM]Received Read request
    I: 107709 [EM]<<< [E:32760r S:62818 M:95957434] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107720 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 107857 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 107865 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 107873 [EM]>>> [E:32761r S:62818 M:58771221] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 107884 [IM]Received Read request
    I: 107889 [EM]<<< [E:32761r S:62818 M:95957435] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 107900 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 107992 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108000 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 108008 [EM]>>> [E:32762r S:62818 M:58771222] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 108020 [ZCL]OpCreds: Certificate Chain request received for DAC
    I: 108029 [EM]<<< [E:32762r S:62818 M:95957436] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 108041 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 108127 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108135 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 108217 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108225 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 108307 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108315 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 108397 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108405 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 108412 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 57)
    D: 108487 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108495 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 108503 [EM]>>> [E:32763r S:62818 M:58771223] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 108514 [IM]Received Read request
    I: 108519 [EM]<<< [E:32763r S:62818 M:95957437] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 108530 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 97)
    D: 108622 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 108630 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 108638 [EM]>>> [E:32764r S:62818 M:58771224] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 108649 [IM]Received Read request
    I: 108654 [EM]<<< [E:32764r S:62818 M:95957438] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 108665 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72)
    D: 108757 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 110872 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 110880 [EM]>>> [E:32765r S:62818 M:58771225] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest)
    I: 110892 [EM]<<< [E:32765r S:62818 M:95957439] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse)
    D: 110903 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
    D: 110962 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 110970 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 110978 [EM]>>> [E:32765r S:62818 M:58771226] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 110990 [FS]GeneralCommissioning: Received ArmFailSafe (120s)
    I: 110997 [EM]<<< [E:32765r S:62818 M:95957440] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 111009 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 111097 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111105 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 111113 [EM]>>> [E:32766r S:62818 M:58771227] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
    D: 111124 [IM]Received Read request
    I: 111129 [EM]<<< [E:32766r S:62818 M:95957441] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 111140 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 111232 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111240 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 111248 [EM]>>> [E:32767r S:62818 M:58771228] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest)
    I: 111260 [EM]<<< [E:32767r S:62818 M:95957442] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse)
    D: 111271 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43)
    D: 111367 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111375 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 111383 [EM]>>> [E:32767r S:62818 M:58771229] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 111398 [EM]<<< [E:32767r S:62818 M:95957443] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 111410 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 111502 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111510 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 111518 [EM]>>> [E:32768r S:62818 M:58771230] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 111530 [ZCL]OpCreds: Certificate Chain request received for PAI
    I: 111539 [EM]<<< [E:32768r S:62818 M:95957444] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 111551 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 111637 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111645 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 111727 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111735 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 111817 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111825 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 111952 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 111960 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 111967 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 28)
    D: 112042 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112050 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 112058 [EM]>>> [E:32769r S:62818 M:58771231] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 112070 [ZCL]OpCreds: Received an AttestationRequest command
    I: 112105 [ZCL]OpCreds: AttestationRequest successful.
    I: 112114 [EM]<<< [E:32769r S:62818 M:95957445] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 112127 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 112222 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112230 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 112312 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112320 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 112402 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112410 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 112492 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112500 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 112507 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 112627 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112635 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 92)
    D: 112717 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 112725 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 112733 [EM]>>> [E:32770r S:62818 M:58771232] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 112745 [ZCL]OpCreds: Received a CSRRequest command
    I: 112891 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
    I: 112926 [ZCL]OpCreds: CSRRequest successful.
    I: 112933 [EM]<<< [E:32770r S:62818 M:95957446] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 112945 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    E: 112952 [DL]Long dispatch time: 227 ms, for event type 16388
    D: 113077 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 113085 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128)
    D: 113167 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 113175 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 127)
    D: 113257 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 115328 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 115418 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 115508 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 115518 [EM]>>> [E:32771r S:62818 M:58771233] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 115530 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
    I: 115589 [ZCL]OpCreds: AddTrustedRootCertificate successful.
    I: 115596 [EM]<<< [E:32771r S:62818 M:95957447] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 115608 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68)
    E: 115616 [DL]Long dispatch time: 108 ms, for event type 16388
    D: 115687 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 115695 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 115778 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 115868 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 116003 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 116011 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
    D: 116092 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 116100 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 116183 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 116194 [EM]>>> [E:32772r S:62818 M:58771234] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 116206 [ZCL]OpCreds: Received an AddNOC command
    I: 116213 [FP]Validating NOC chain
    I: 116323 [FP]NOC chain validation successful
    I: 116327 [FP]Added new fabric at index: 0x1
    I: 116331 [FP]Assigned compressed fabric ID: 0x7BABAAB43C4053C0, node ID: 0x000000009F0DC373
    I: 116339 [TS]Last Known Good Time: 2023-10-14T01:16:48
    I: 116344 [TS]New proposed Last Known Good Time: 2024-08-15T12:59:53
    I: 116351 [TS]Updating pending Last Known Good Time to 2024-08-15T12:59:53
    I: 116365 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD00010001
    D: 116374 [DL]Using wifi MAC for hostname
    I: 116378 [DIS]Advertise operational node 7BABAAB43C4053C0-000000009F0DC373
    D: 116385 [DIS]Responding with _matter._tcp.local
    D: 116389 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 116396 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 116404 [DIS]Responding with F4CE360024AE.local
    D: 116408 [DIS]Responding with F4CE360024AE.local
    D: 116413 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
    I: 116419 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000009F0DC373.
    I: 116429 [DIS]mDNS service published: _matter._tcp
    I: 116434 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
    I: 116442 [EM]<<< [E:32772r S:62818 M:95957448] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 116454 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    E: 116461 [DL]Long dispatch time: 278 ms, for event type 16388
    D: 116542 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 116550 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 116558 [EM]>>> [E:32773r S:62818 M:58771235] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 116572 [EM]<<< [E:32773r S:62818 M:95957449] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 116584 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 116722 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 116730 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 116738 [EM]>>> [E:32774r S:62818 M:58771236] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:02 (IM:ReadRequest)
    D: 116749 [IM]Received Read request
    I: 116754 [EM]<<< [E:32774r S:62818 M:95957450] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:05 (IM:ReportData)
    D: 116765 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71)
    D: 116857 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    D: 116865 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    I: 116873 [EM]>>> [E:32775r S:62818 M:58771237] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:08 (IM:InvokeCommandRequest)
    D: 116885 [DL]Connecting to WiFi network: Galaxy A54 5G E59B
    D: 116894 [DL]WiFi scanning started...
    D: 119372 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
    D: 119467 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    I: 121507 [DL]Wi-Fi scan done (0)
    I: 123050 [DL]Connection to Galaxy A54 5G E59B requested [RSSI=-48]
    E: 123056 [DL]Long dispatch time: 1549 ms, for event type 3
    D: 123064 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00)
    D: 125571 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3)
    D: 125632 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    I: 127759 [DL]Connected to WiFi network
    I: 127768 [EM]<<< [E:32775r S:62818 M:95957451] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
    D: 127780 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 69)
    D: 127787 [DL]Using wifi MAC for hostname
    I: 127791 [DIS]Advertise operational node 7BABAAB43C4053C0-000000009F0DC373
    D: 127798 [DIS]Responding with _matter._tcp.local
    D: 127803 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 127810 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 127818 [DIS]Responding with F4CE360024AE.local
    D: 127822 [DIS]Responding with F4CE360024AE.local
    D: 127826 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
    I: 127833 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000009F0DC373.
    E: 127846 [DIS]Failed to advertise records: 46
    I: 127851 [DIS]mDNS service published: _matter._tcp
    I: 127855 [SVR]Operational advertising enabled
    I: 127861 [SWU]Stopping the watchdog timer
    I: 127865 [SWU]Starting the periodic query timer, timeout: 86400 seconds
    I: 127871 [SVR]Server initialization complete
    I: 127875 [DIS]Updating services using commissioning mode 0
    I: 127883 [DIS]CHIP minimal mDNS started advertising.
    D: 127896 [DL]Using wifi MAC for hostname
    I: 127900 [DIS]Advertise operational node 7BABAAB43C4053C0-000000009F0DC373
    D: 127907 [DIS]Responding with _matter._tcp.local
    D: 127912 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 127919 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 127926 [DIS]Responding with F4CE360024AE.local
    D: 127931 [DIS]Responding with F4CE360024AE.local
    D: 127935 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
    I: 127943 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000009F0DC373.
    I: 127958 [DIS]mDNS service published: _matter._tcp
    D: 127963 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00)
    I: 127971 [DIS]Updating services using commissioning mode 0
    I: 127977 [DIS]CHIP minimal mDNS started advertising.
    D: 127989 [DL]Using wifi MAC for hostname
    I: 127993 [DIS]Advertise operational node 7BABAAB43C4053C0-000000009F0DC373
    D: 128000 [DIS]Responding with _matter._tcp.local
    D: 128005 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 128012 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 128019 [DIS]Responding with F4CE360024AE.local
    D: 128024 [DIS]Responding with F4CE360024AE.local
    D: 128028 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
    I: 128035 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000009F0DC373.
    I: 128049 [DIS]mDNS service published: _matter._tcp
    I: 128872 [DL]Current number of connections: 0/1
    I: 128876 [DL]BLE GAP connection terminated (reason 0x13)
    E: 140579 [BLE]ack recv timeout, closing ep 0x2000b188
    D: 140584 [IN]Clearing BLE pending packets.
    I: 140588 [BLE]Releasing end point's BLE connection back to application.
    I: 140595 [DL]Closing BLE GATT connection (ConnId 00)
    I: 230996 [FS]Fail-safe timer expired
    E: 231000 [SVR]Failsafe timer expired
    D: 231003 [IN]SecureSession[0x20004530]: MarkForEviction Type:1 LSID:62818
    I: 231010 [SC]SecureSession[0x20004530, LSID:62818]: State change 'kActive' --> 'kPendingEviction'
    D: 231018 [IN]SecureSession[0x20004530]: Released - Type:1 LSID:62818
    E: 231024 [SVR]Commissioning failed (attempt 1): 32
    D: 231029 [IN]SecureSession[0x20004530]: Allocated Type:1 LSID:62820
    D: 231035 [DL]CHIPoBLE advertising set to on
    I: 231039 [DIS]Updating services using commissioning mode 1
    I: 231045 [DIS]CHIP minimal mDNS started advertising.
    D: 231058 [DL]Using wifi MAC for hostname
    I: 231063 [DIS]Advertise operational node 7BABAAB43C4053C0-000000009F0DC373
    D: 231070 [DIS]Responding with _matter._tcp.local
    D: 231074 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 231081 [DIS]Responding with 7BABAAB43C4053C0-000000009F0DC373._matter._tcp.local
    D: 231089 [DIS]Responding with F4CE360024AE.local
    D: 231093 [DIS]Responding with F4CE360024AE.local
    D: 231098 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local
    I: 231104 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000009F0DC373.
    I: 231118 [DIS]mDNS service published: _matter._tcp
    D: 231123 [DL]Using wifi MAC for hostname
    I: 231127 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
    D: 231136 [DIS]Responding with _matterc._udp.local
    D: 231140 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    D: 231146 [DIS]Responding with F4CE360024AE.local
    D: 231151 [DIS]Responding with F4CE360024AE.local
    D: 231155 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 231162 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 231167 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 231173 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 231178 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    I: 231184 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 847893369ED20FC9.
    I: 231206 [DIS]mDNS service published: _matterc._udp
    E: 231211 [ZCL]OpCreds: Got FailSafeTimerExpired
    E: 231215 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
    D: 231222 [IN]Expiring all sessions for fabric 0x1!!
    E: 231227 [FP]Reverting pending fabric data for fabric 0x1
    E: 231232 [FP]Warning: metadata not found during delete of fabric 0x1
    I: 231242 [FP]Fabric (0x1) deleted.
    I: 231245 [ZCL]OpCreds: Fabric index 0x1 was removed
    I: 231250 [DIS]Updating services using commissioning mode 1
    I: 231255 [DIS]CHIP minimal mDNS started advertising.
    D: 231287 [DL]Using wifi MAC for hostname
    I: 231291 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
    D: 231300 [DIS]Responding with _matterc._udp.local
    D: 231304 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    D: 231310 [DIS]Responding with F4CE360024AE.local
    D: 231315 [DIS]Responding with F4CE360024AE.local
    D: 231319 [DIS]Responding with _V65521._sub._matterc._udp.local
    D: 231325 [DIS]Responding with _S15._sub._matterc._udp.local
    D: 231330 [DIS]Responding with _L3840._sub._matterc._udp.local
    D: 231336 [DIS]Responding with _CM._sub._matterc._udp.local
    D: 231341 [DIS]Responding with 847893369ED20FC9._matterc._udp.local
    I: 231347 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: 847893369ED20FC9.
    I: 231362 [DIS]mDNS service published: _matterc._udp
    I: 231378 [TS]Pending Last Known Good Time: 2024-08-15T12:59:53
    I: 231384 [TS]Previous Last Known Good Time: 2023-10-14T01:16:48
    I: 231390 [TS]Reverted Last Known Good Time to previous value
    E: 231396 [FP]Warning: metadata not found during delete of fabric 0x1
    E: 231403 [ZCL]OpCreds: failed to delete fabric at index 1: d8
    D: 231430 [DL]Disconnect requested
    E: 231433 [DL]Long dispatch time: 433 ms, for event type 32782
    I: 231438 [FS]Fail-safe cleanly disarmed
    I: 231445 [DL]CHIPoBLE advertising started
    I: 231448 [DL]WiFi station disconnected
    I: 231452 [DL]NFC Tag emulation started
    I: 232245 [TS]Pending Last Known Good Time: 2023-10-14T01:16:48
    I: 232251 [TS]Previous Last Known Good Time: 2023-10-14T01:16:48
    I: 232257 [TS]Reverted Last Known Good Time to previous value
    I: 232263 [DL]Performing factory reset
      "data": {
        "clientUpdateLog": {
          "matterUpdate": {
            "sessionId": "8438037950733219612"
    	"reportedVendorId": 0
    	"status": "GENERIC_ERROR"
    	"verifiedProductId": 32773
    	"verifiedVendorId": 65521
    	"commissioningState": "CASE_CONNECTION_FAILED"
    	"reportedProductId": 0
    Can you verify that the Google Nest Mini is on the same Wi-Fi network as well?
    Based on the logs, it looks like the commissioning times out. I will do some more digging and get back to you next week.
    Marte
