Hi
From the past few days, I have been trying to perform FOTA with BLE using external QSPI flash. However, I'm unsure if I'm creating the proper files and adding the correct configuration.
I need to perform simultaneous updates for both cores of the nRF5340.
This are the configuration i have done
1. prj.conf
# Enable the LBS service CONFIG_BT_LBS=y CONFIG_BT_LBS_POLL_BUTTON=y CONFIG_DK_LIBRARY=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_NRF53_UPGRADE_NETWORK_CORE=y CONFIG_UPDATEABLE_IMAGE_NUMBER=2
2.cpuapp.overlay
chosen {
nordic,pm-ext-flash = &mx25r64;
3. this are the files I have created
child_image folder
under child image
1.hci_ipc.conf
2.mcuboot.conf
3.mcuboot.overlay
4.mcuboot.overlay
EMPTY FILE
5. hci_ipc.conf
CONFIG_SERIAL=y CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=4 CONFIG_MAIN_STACK_SIZE=2048
6.mcuboot.conf
# Enable QSPI drivers for external flash CONFIG_NORDIC_QSPI_NOR=y # Increase max image sectors to handle larger slot sizes CONFIG_BOOT_MAX_IMG_SECTORS=256 # Logging CONFIG_LOG=y CONFIG_MCUBOOT_LOG_LEVEL_WRN=y # Enable simultaneous multi-core updates CONFIG_NRF53_MULTI_IMAGE_UPDATE=y CONFIG_UPDATEABLE_IMAGE_NUMBER=2 CONFIG_BOOT_UPGRADE_ONLY=y CONFIG_PCD_APP=y # Dependencies for CONFIG_NRF53_MULTI_IMAGE_UPDATE CONFIG_FLASH=y CONFIG_FLASH_SIMULATOR=y CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y CONFIG_FLASH_SIMULATOR_STATS=n
this is the error I am getting right now
I am new to the nRF controller. Kindly let me know what mistakes I am making. Based on the errors I’m seeing, there seems to be a partition issue. I need to know what configurations are required and where I need to apply them.
Additionally, I need to add a secure bootloader to this, and I would like to know how to do that as well.
Kindly support on this!!!!!!!!!!
