nrf5340 BLE FOTA With QSPI flash
Hi
From the past few days, I have been trying to perform FOTA with BLE using external QSPI flash. However, I'm unsure if I'm creating the proper files and adding the correct configuration.
I need to perform simultaneous updates for both cores of the nRF5340.
This are the configuration i have done
1. prj.conf
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
CONFIG_UPDATEABLE_IMAGE_NUMBER=2
2.cpuapp.overlay
    chosen {
        nordic,pm-ext-flash = &mx25r64;
3. this are the files I have created
child_image folder
under child image
1.hci_ipc.conf
2.mcuboot.conf
3.mcuboot.overlay
4.mcuboot.overlay
   EMPTY FILE
5. hci_ipc.conf
CONFIG_SERIAL=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_MAIN_STACK_SIZE=2048
6.mcuboot.conf
# Enable QSPI drivers for external flash
CONFIG_NORDIC_QSPI_NOR=y
# Increase max image sectors to handle larger slot sizes
CONFIG_BOOT_MAX_IMG_SECTORS=256
# Logging
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_WRN=y
# Enable simultaneous multi-core updates
CONFIG_NRF53_MULTI_IMAGE_UPDATE=y
CONFIG_BOOT_UPGRADE_ONLY=y
CONFIG_PCD_APP=y
# Dependencies for CONFIG_NRF53_MULTI_IMAGE_UPDATE
CONFIG_FLASH=y
CONFIG_FLASH_SIMULATOR=y
CONFIG_FLASH_SIMULATOR_DOUBLE_WRITES=y
CONFIG_FLASH_SIMULATOR_STATS=n
this is the error I am getting right now
I am new to the nRF controller. Kindly let me know what mistakes I am making. Based on the errors I’m seeing, there seems to be a partition issue. I need to know what configurations are required and where I need to apply them.
Additionally, I need to add a secure bootloader to this, and I would like to know how to do that as well.
Kindly support on this!!!!!!!!!!
