CONFIG_NRFX_TWIM was assigned the value y, but got the value n.
Board: nrf5340dk (build board: nrf5340dk_nrf5340_cpuapp) / SDK: v0.16.8 / I'm a complete beginner who touches the nrf board for the first time
My Project: max30101 --(measured data)--> nrf5340 dk --(measured data)--> nrf connect for mobile(bluetooth app)
1. I can send the measured data from max30101 via I2C to nrf5340. Then, I can check the data at Serial Monitor in real time.
2. I can send the Random data from nrf5340 to nrf connect for mobile. Then, I can check the data on app in real time.
But, I can't operate those at the same time. I made the max30101 code that worked well when only I2C worked as a header file and added it to main.c, but when I try to work with ble, I2C is not enabled in the prj.conf file.
<main.c>
/* main.c - Application main entry point */
 * Copyright (c) 2015-2016 Intel Corporation
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/kernel.h>
#include <zephyr/settings/settings.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/services/bas.h>
#include <zephyr/bluetooth/services/hrs.h>
#include <zephyr/bluetooth/services/ias.h>
#include "cts.h"
#include "max30101.h"
/* Custom Service Variables */
#define BT_UUID_CUSTOM_SERVICE_VAL \
	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef0)
static const struct bt_uuid_128 vnd_uuid = BT_UUID_INIT_128(
	BT_UUID_CUSTOM_SERVICE_VAL);
static const struct bt_uuid_128 vnd_enc_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef1));
static const struct bt_uuid_128 vnd_auth_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef2));
#define VND_MAX_LEN 20
static uint8_t vnd_value[VND_MAX_LEN + 1] = { 'V', 'e', 'n', 'd', 'o', 'r'};
static uint8_t vnd_auth_value[VND_MAX_LEN + 1] = { 'V', 'e', 'n', 'd', 'o', 'r'};
static uint8_t vnd_wwr_value[VND_MAX_LEN + 1] = { 'V', 'e', 'n', 'd', 'o', 'r' };
static ssize_t read_vnd(struct bt_conn *conn, const struct bt_gatt_attr *attr,
			void *buf, uint16_t len, uint16_t offset)
	const char *value = attr->user_data;
	return bt_gatt_attr_read(conn, attr, buf, len, offset, value,
				 strlen(value));
static ssize_t write_vnd(struct bt_conn *conn, const struct bt_gatt_attr *attr,
			 const void *buf, uint16_t len, uint16_t offset,
			 uint8_t flags)
	uint8_t *value = attr->user_data;
	if (offset + len > VND_MAX_LEN) {
		return BT_GATT_ERR(BT_ATT_ERR_INVALID_OFFSET);
	memcpy(value + offset, buf, len);
	value[offset + len] = 0;
	return len;
static uint8_t simulate_vnd;
static uint8_t indicating;
static struct bt_gatt_indicate_params ind_params;
static void vnd_ccc_cfg_changed(const struct bt_gatt_attr *attr, uint16_t value)
	simulate_vnd = (value == BT_GATT_CCC_INDICATE) ? 1 : 0;
static void indicate_cb(struct bt_conn *conn,
			struct bt_gatt_indicate_params *params, uint8_t err)
	printk("Indication %s\n", err != 0U ? "fail" : "success");
static void indicate_destroy(struct bt_gatt_indicate_params *params)
	printk("Indication complete\n");
	indicating = 0U;
#define VND_LONG_MAX_LEN 74
static uint8_t vnd_long_value[VND_LONG_MAX_LEN + 1] = {
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '1',
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '2',
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '3',
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '4',
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '5',
		  'V', 'e', 'n', 'd', 'o', 'r', ' ', 'd', 'a', 't', 'a', '6',
static ssize_t write_long_vnd(struct bt_conn *conn,
			      const struct bt_gatt_attr *attr, const void *buf,
			      uint16_t len, uint16_t offset, uint8_t flags)
	if (flags & BT_GATT_WRITE_FLAG_PREPARE) {
		return 0;
	if (offset + len > VND_LONG_MAX_LEN) {
	return len;
static const struct bt_uuid_128 vnd_long_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef3));
static struct bt_gatt_cep vnd_long_cep = {
	.properties = BT_GATT_CEP_RELIABLE_WRITE,
static int signed_value;
static ssize_t read_signed(struct bt_conn *conn, const struct bt_gatt_attr *attr,
				 sizeof(signed_value));
static ssize_t write_signed(struct bt_conn *conn, const struct bt_gatt_attr *attr,
			    uint8_t flags)
	if (offset + len > sizeof(signed_value)) {
	return len;
static const struct bt_uuid_128 vnd_signed_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x13345678, 0x1234, 0x5678, 0x1334, 0x56789abcdef3));
static const struct bt_uuid_128 vnd_write_cmd_uuid = BT_UUID_INIT_128(
	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x5678, 0x1234, 0x56789abcdef4));
static ssize_t write_without_rsp_vnd(struct bt_conn *conn,
				     uint8_t flags)
	if (!(flags & BT_GATT_WRITE_FLAG_CMD)) {
		/* Write Request received. Reject it since this Characteristic
		 * only accepts Write Without Response.
		return BT_GATT_ERR(BT_ATT_ERR_WRITE_REQ_REJECTED);
	return len;
/* Vendor Primary Service Declaration */
BT_GATT_SERVICE_DEFINE(vnd_svc,
	BT_GATT_PRIMARY_SERVICE(&vnd_uuid),
	BT_GATT_CHARACTERISTIC(&vnd_enc_uuid.uuid,
			       BT_GATT_CHRC_READ | BT_GATT_CHRC_WRITE |
			       BT_GATT_CHRC_INDICATE,
			       BT_GATT_PERM_READ_ENCRYPT |
			       BT_GATT_PERM_WRITE_ENCRYPT,
			       read_vnd, write_vnd, vnd_value),
	BT_GATT_CCC(vnd_ccc_cfg_changed,
		    BT_GATT_PERM_READ | BT_GATT_PERM_WRITE_ENCRYPT),
	BT_GATT_CHARACTERISTIC(&vnd_auth_uuid.uuid,
			       BT_GATT_CHRC_READ | BT_GATT_CHRC_WRITE,
			       BT_GATT_PERM_READ_AUTHEN |
			       BT_GATT_PERM_WRITE_AUTHEN,
			       read_vnd, write_vnd, vnd_auth_value),
	BT_GATT_CHARACTERISTIC(&vnd_long_uuid.uuid, BT_GATT_CHRC_READ |
			       BT_GATT_CHRC_WRITE | BT_GATT_CHRC_EXT_PROP,
			       BT_GATT_PERM_READ | BT_GATT_PERM_WRITE |
			       BT_GATT_PERM_PREPARE_WRITE,
			       read_vnd, write_long_vnd, &vnd_long_value),
	BT_GATT_CEP(&vnd_long_cep),
	BT_GATT_CHARACTERISTIC(&vnd_signed_uuid.uuid, BT_GATT_CHRC_READ |
			       BT_GATT_CHRC_WRITE | BT_GATT_CHRC_AUTH,
			       BT_GATT_PERM_READ | BT_GATT_PERM_WRITE,
			       read_signed, write_signed, &signed_value),
	BT_GATT_CHARACTERISTIC(&vnd_write_cmd_uuid.uuid,
			       BT_GATT_CHRC_WRITE_WITHOUT_RESP,
			       BT_GATT_PERM_WRITE, NULL,
			       write_without_rsp_vnd, &vnd_wwr_value),
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA_BYTES(BT_DATA_UUID16_ALL,
		      BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
		      BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
		      BT_UUID_16_ENCODE(BT_UUID_CTS_VAL)),
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_CUSTOM_SERVICE_VAL),
static const struct bt_data sd[] = {
	BT_DATA(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME, sizeof(CONFIG_BT_DEVICE_NAME) - 1),
void mtu_updated(struct bt_conn *conn, uint16_t tx, uint16_t rx)
	printk("Updated MTU: TX: %d RX: %d bytes\n", tx, rx);
static struct bt_gatt_cb gatt_callbacks = {
	.att_mtu_updated = mtu_updated
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed, err 0x%02x %s\n", err, bt_hci_err_to_str(err));
	} else {
		printk("Connected\n");
	printk("Disconnected, reason 0x%02x %s\n", reason, bt_hci_err_to_str(reason));
static void alert_stop(void)
	printk("Alert stopped\n");
static void alert_start(void)
	printk("Mild alert started\n");
static void alert_high_start(void)
	printk("High alert started\n");
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
BT_IAS_CB_DEFINE(ias_callbacks) = {
	.no_alert = alert_stop,
	.mild_alert = alert_start,
	.high_alert = alert_high_start,
static void bt_ready(void)
	int err;
	printk("Bluetooth initialized\n");
	cts_init();
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_le_adv_start(BT_LE_ADV_CONN_ONE_TIME, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static struct bt_conn_auth_cb auth_cb_display = {
	.passkey_display = auth_passkey_display,
	.passkey_entry = NULL,
	.cancel = auth_cancel,
static void bas_notify(void)
	uint8_t battery_level = bt_bas_get_battery_level();
	battery_level--;
	if (!battery_level) {
		battery_level = 100U;
	bt_bas_set_battery_level(battery_level);
static void hrs_notify(void)
    int ret;
    uint8_t data[16];
    uint32_t un_min, un_max, un_prev_data;
    int i;
    int32_t n_brightness;
    float f_temp;
    k_msleep(1000);
    const struct device *i2c_dev;
    i2c_dev = device_get_binding("I2C_1");
    if (i2c_dev == NULL)
        printk("Error: didn't find I2C_1 device\n");
        return;
    // MAX30101 센서 초기화
    init_I2C(i2c_dev);
    check_MAX30101(i2c_dev);
    reset_MAX30101(i2c_dev);
    clearInt_MAX30101(i2c_dev);
    init_MAX30101(i2c_dev);
    n_brightness = 0;
    un_min = 0x3FFFF;
    un_max = 0;
    n_ir_buffer_length = 500;
    // MAX30101 - read the first 500 samples, and determine the signal range
    for (i = 0; i < n_ir_buffer_length; i++)
        maxim_max30101_read_fifo(i2c_dev, (aun_red_buffer + i), (aun_ir_buffer + i));
        if (un_min > aun_red_buffer[i]) un_min = aun_red_buffer[i];
        if (un_max < aun_red_buffer[i]) un_max = aun_red_buffer[i];
        printk("red=%i, ir=%i\n", aun_red_buffer[i], aun_ir_buffer[i]);
    un_prev_data = aun_red_buffer[i];
    // Heart rate and SpO2 calculation
    maxim_heart_rate_and_oxygen_saturation(aun_ir_buffer, n_ir_buffer_length, aun_red_buffer, &n_sp02, &ch_spo2_valid, &n_heart_rate, &ch_hr_valid);
    // Continuously take samples and calculate heart rate and SpO2
    for (i = 100; i < 500; i++)
        un_prev_data = aun_red_buffer[i - 1];
        if (aun_red_buffer[i] > un_prev_data)
            f_temp = aun_red_buffer[i] - un_prev_data;
            f_temp /= (un_max - un_min);
            f_temp *= MAX_BRIGHTNESS;
            n_brightness -= (int)f_temp;
            if (n_brightness < 0)
                n_brightness = 0;
            f_temp = un_prev_data - aun_red_buffer[i];
            n_brightness += (int)f_temp;
            if (n_brightness > MAX_BRIGHTNESS)
                n_brightness = MAX_BRIGHTNESS;
        printk("red=%i, ir=%i, HR=%i, HRvalid=%i, SpO2=%i, SPO2Valid=%i \n", aun_red_buffer[i], aun_ir_buffer[i], n_heart_rate, ch_hr_valid, n_sp02, ch_spo2_valid);
        k_msleep(10);
    // HR 및 SpO2 계산 후 BLE에 전송
    bt_hrs_notify(n_heart_rate);
	struct bt_gatt_attr *vnd_ind_attr;
	char str[BT_UUID_STR_LEN];
	int err;
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return 0;
	bt_ready();
	bt_gatt_cb_register(&gatt_callbacks);
	bt_conn_auth_cb_register(&auth_cb_display);
	vnd_ind_attr = bt_gatt_find_by_uuid(vnd_svc.attrs, vnd_svc.attr_count,
					    &vnd_enc_uuid.uuid);
	bt_uuid_to_str(&vnd_enc_uuid.uuid, str, sizeof(str));
	printk("Indicate VND attr %p (UUID %s)\n", vnd_ind_attr, str);
	/* Implement notification. At the moment there is no suitable way
	 * of starting delayed work so we do it here
	while (1) {
		k_sleep(K_SECONDS(1));
		/* Current Time Service updates only when time is changed */
		cts_notify();
		/* Heartrate measurements simulation */
		hrs_notify();
		/* Battery level simulation */
		bas_notify();
		/* Vendor indication simulation */
		if (simulate_vnd && vnd_ind_attr) {
			if (indicating) {
				continue;
			ind_params.attr = vnd_ind_attr;
			ind_params.func = indicate_cb;
			ind_params.destroy = indicate_destroy;
			ind_params.data = &indicating;
			ind_params.len = sizeof(indicating);
			if (bt_gatt_indicate(NULL, &ind_params) == 0) {
				indicating = 1U;
	return 0;
<prj.conf>
# Increased stack due to settings API usage
CONFIG_BT=y
CONFIG_LOG=y
CONFIG_BT_SMP=y
CONFIG_BT_SIGNING=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DIS=y
CONFIG_BT_ATT_PREPARE_COUNT=5
CONFIG_BT_BAS=y
CONFIG_BT_HRS=y
CONFIG_BT_IAS=y
CONFIG_BT_PRIVACY=y
CONFIG_BT_DEVICE_NAME="Zephyr Peripheral Sample Long Name"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=65
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_SENSOR_LOG_LEVEL_DBG=y
CONFIG_ASSERT=y
# Stacks and heaps
CONFIG_MAIN_STACK_SIZE=16384
CONFIG_HEAP_MEM_POOL_SIZE=16384
# I2C
CONFIG_NRFX_TWIM=y
CONFIG_NRFX_TWIM1=y
CONFIG_HAS_NRFX=y
# Rebooot
CONFIG_REBOOT=n
<code>
# I2C
CONFIG_NRFX_TWIM=y
CONFIG_NRFX_TWIM1=y
CONFIG_HAS_NRFX=y
The following error codes continue to appear in this code.
<error codes>
CONFIG_NRFX_TWIM was assigned the value y, but got the value n. Missing dependencies:
HAS_NRFX || (HAS_NRFX && 0)
