Device Manager App now shows app_update.bin as an Invalid Image file. On a previous version of the app (pre-2.0.0) this worked. What changes do I need to make to my prj.conf to correct this issue and/or how would I figure out what is causing it to come up this way? I've always used 'Test and Confirm' and 'Basic' mode for dfu.
As a side note, attempting to use dfu_application.zip instead produces a State of 'Corrupt(9)'. This way of doing a dfu has never worked.
Here is the prj.conf I have:
# Copyright (c) 2020 Nordic Semiconductor
# CONFIG_LOG=y
CONFIG_CBPRINTF_FP_SUPPORT=n
CONFIG_NFCT_PINS_AS_GPIOS=y
CONFIG_NRFX_SPI2=y
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_SPI_SLAVE=y
CONFIG_NRFX_SPIS2=y
CONFIG_BOOT_BANNER=n
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_PM_DEVICE_RUNTIME_EXCLUSIVE=n
CONFIG_PRINTK=n
CONFIG_BT=y
# CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_SMP=y
CONFIG_BT_SIGNING=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DIS=y
CONFIG_BT_ATT_PREPARE_COUNT=5
CONFIG_BT_BAS=y
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_DIS_MANUF="Changed"
CONFIG_BT_EXT_ADV=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# To set bt_dev.name use all of these options:
CONFIG_BT_DEVICE_NAME="Changed"
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
CONFIG_BT_DEVICE_NAME_MAX=65
CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC=y
CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN=n
CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=n
CONFIG_BT_DIS_SERIAL_NUMBER=y
CONFIG_BT_DIS_SW_REV=y
CONFIG_BT_DIS_FW_REV=y
CONFIG_BT_DIS_HW_REV=y
CONFIG_BT_DIS_SERIAL_NUMBER_STR="123456789"
CONFIG_BT_DIS_SW_REV_STR="1.12"
CONFIG_BT_DIS_FW_REV_STR="0.1"
CONFIG_BT_DIS_HW_REV_STR="0.7"
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMAGE_VERSION="2.4.2+0"
CONFIG_DFU_TARGET=y
# Enable MCUmgr and dependencies.
CONFIG_NET_BUF=y
CONFIG_ZCBOR=y
CONFIG_CRC=y
CONFIG_MCUMGR=y
# Some command handlers require a large stack.
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_HEAP_MEM_POOL_SIZE=4096
# Required by the `taskstat` command.
CONFIG_THREAD_MONITOR=y
# Support for taskstat command
CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
# Enable statistics and statistic names.
CONFIG_STATS=y
CONFIG_STATS_NAMES=y
# Enable most core commands.
CONFIG_STREAM_FLASH=y
CONFIG_STREAM_FLASH_ERASE=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
CONFIG_MCUMGR_GRP_OS_ECHO=y
CONFIG_MCUMGR_GRP_STAT=y
CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS=y
CONFIG_MCUMGR_SMP_COMMAND_STATUS_HOOKS=y
CONFIG_MCUMGR_GRP_IMG_UPLOAD_CHECK_HOOK=y
CONFIG_MCUMGR_GRP_IMG_STATUS_HOOKS=y
CONFIG_MCUMGR_GRP_OS_RESET_HOOK=y
CONFIG_IMG_ENABLE_IMAGE_CHECK=y
CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
# Disable features not needed
CONFIG_TIMESLICING=n
CONFIG_MINIMAL_LIBC_MALLOC=n
CONFIG_LOG=n
CONFIG_ASSERT=n
# Disable Bluetooth features not needed
CONFIG_BT_DEBUG_NONE=y
CONFIG_BT_ASSERT=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_GATT_CACHING=n
CONFIG_BT_GATT_SERVICE_CHANGED=n
CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=n
CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
CONFIG_BT_HCI_VS_EXT=n
# Disable Bluetooth controller features not needed
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_CTLR_PHY_2M=n
# Allow for large Bluetooth data packets.
#CONFIG_BT_L2CAP_TX_MTU=498
#CONFIG_BT_BUF_ACL_RX_SIZE=502
#CONFIG_BT_BUF_ACL_TX_SIZE=502
#CONFIG_BT_DATA_LEN_UPDATE=y
#CONFIG_BT_CTLR_DATA_LENGTH_MAX=27
# Enable the Bluetooth mcumgr transport (unauthenticated).
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_AUTHEN=n
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_BT_GATT_DYNAMIC_DB=y
CONFIG_BT_GATT_SERVICE_CHANGED=y
CONFIG_BT_DFU_SMP=y
